Houston, think we have a problem...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jboudreaux1965, Jun 1, 2016.
  1. Jun 4, 2016 at 2:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How did you conclude that it was a head gasket?
  2. Jun 4, 2016 at 4:15 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    I had a friend who's family has owned a mechanic shop for a couple of generations come over. He has been working as a mechanic for probably 40 years. We tried everything else. Wasn't thermostat, wasn't fan clutch, no leaks in hoses, there was pressure in the lines, flushed system 4-5 times, no restitutions noticed. Water pump shaft is solid. And started hearing gurgling noises in the interior coming from under the dash when I started it.
    By this time coolant would almost immediately start filling overflow reservoir when I started it.
    Finally as last resort we put Bar's professional grade in the system... About 45 minutes later, symptoms were gone and she has been running like new ever since.
    Basically process of elimination. Planning to basically rebuild the engine when I have the money for all the parts. When we pull the heads I guess we will know for sure, but we are both 99% sure the problem is head gasket.
  3. Jun 4, 2016 at 4:20 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Plus tacomas are legendary for head gasket blowing in the area of cylinder 6 when pushed REALLY hard for long periods of time, I.E. high RPM's for 100 - 200 miles at a times many, many, many, many times
  4. Jun 4, 2016 at 8:17 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sorry for your loss. Sounds like you have it nailed.
  5. Jun 4, 2016 at 8:23 PM
    49erfan
    49erfan Well-Known Member
    Kevin
    Dallas
    04 DC Prerunner Lunar Mist
    Knowing this, why drive like a jackass and push your truck
    4x4Taco09 likes this.
  6. Jun 4, 2016 at 8:42 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I've heard Toyota redesign the head gasket or something between 2006 - 2007.
    Can anyone confirm this?
    I have 2007, I hope mine is "upgraded".
  7. Jun 4, 2016 at 9:18 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I have a stupid comment... If you are killing the average vehicle in 5 years you are doing something way wrong.
  8. Jun 4, 2016 at 11:23 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes there was a design change in the head gasket.
  9. Jun 4, 2016 at 11:29 PM
    TnShooter
    Deogee
    STOCK
    Do you happen to know a more specific time frame?
  10. Jun 5, 2016 at 5:41 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Sadly I do not. I just remember reading about it.
  11. Jun 5, 2016 at 6:23 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I'm with you, killing anything in 5 years should raise some warning alarms that you're doing something wrong. Just wondering, why over 90 mph?
  12. Jun 5, 2016 at 7:17 AM
    Pigpen
    Dan
    Northwest Montana
    I totally agree, but...
    The speed limit on some of our roads is 80 mph so, even though I prefer to be closer to 60 most of the time, I can understand driving over 90. In my Taco I don't feel it's worth driving that fast for fuel economy and safety reasons - my truck isn't built for stability at speed, some vehicles are though.
  13. Jun 5, 2016 at 11:30 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Make sure to buy new head bolts. DO NOT reuse the old ones.
  14. Jun 5, 2016 at 11:33 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Guess I'm just never in that much of a hurry, I feel good around 70-75, 80 for passing.
    todras likes this.
  15. Jun 5, 2016 at 11:34 AM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Mine feels fine at 110. :p
  16. Jun 5, 2016 at 12:18 PM
    #36
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    ... the gasket in his head is blown.
    ... and more like a lead foot.
    Keep blowing it up, that'll keep you off the road.
    Admitting to dangerous driving and racing is against the TW COC.
    @tcBob
    Jester243 and 327 like this.
  17. Jun 5, 2016 at 2:20 PM
    #37
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I did not know that rule, thank you for letting me know! I'lll make sure I do not do it again!
    taczilla[QUOTED] likes this.
  18. Jun 5, 2016 at 2:47 PM
    #38
    Pigpen
    Dan
    Northwest Montana
    Problem solved (well, not the gasket - yet)
  19. Jun 16, 2016 at 7:24 PM
    #39
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I was about to pull the trigger on buying another wrecked 2nd gen and swapping the engines. Decided not too. Since I plan on pretty much rebuilding this engine, can you guys recommend any mods or aftermarket parts to consider for better performance, more HP? Cam, headers, etc? I found out today we came to a settlement about my accident about a year and a half ago. After medicaland other bills, money set aside for savings, I plan on having $3,000 I can spend. Will be doing the work myself with aid of my friend who owns a shop. Also anyone who would happen to have a parts list for everything I need to buy before we start this project, if you could post it, I'd very much appreciate it!
  20. Jun 16, 2016 at 9:18 PM
    #40
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    One unexpected thing I have seen is that the water pump impeller can "dissolve" over time. And when this happens, it doesn't push much water. A test for this, which will obviously cost you some anti-freeze, is to let it cool off, remove t-stat and reinstall housing, then fill with water and remove upper radiator hose from radiator. Crank. It should blow out a heavy stream of water. A trickle is a problem.
    I didn't see how old your truck is, whether you had followed coolant replacement schedule, etc. The dissolved impeller I saw was the direct result of driving about 100K+ miles with no coolant / antifreeze change, over a period of maybe 5 years. If your fluid has been changed, to keep the acidic crap down, this should not happen. but it is not that hard to test, and if you have not flushed/drained recently, this is a good test to run since you need to drain and refill after this test anyway.
    Other possible problems include a bad fan clutch that doesn't pull air at slow speeds after driving at 90+ and really getting things hot (transmission included). Or a bad t-stat that sticks. Or a dead buzzard stuck in front of the radiator. :) That last is a true event, BTW. Sort of like the Farmer's insurance commercials where they saw "we know a thing or two because we've seen a thing or two..." ;)
    jboudreaux1965[OP] likes this.
