hoverlover’s “there are many like it, but this one is mine” extra long title bs thread and build too
Discussion in '2nd Gen. Builds (2005-2015)' started by hoverlover, Apr 22, 2018.
  1. Oct 22, 2019 at 12:56 PM
    #2761
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I am now just got home a few min ago I dipped out early got a massive headache outta nowhere.
  2. Oct 22, 2019 at 1:57 PM
    #2762
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Nice looking tars!!
  3. Oct 22, 2019 at 1:58 PM
    #2763
    BassAckwards
    Afternoon gents
    hoverlover[OP] likes this.
  4. Oct 22, 2019 at 2:17 PM
    #2764
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    I've been thinking about them because they're now in Texas, but it's hard when they're called "Cali" raised lol. I know he stands by his products and is a good dude but the performance of Rigids and BDs just crushes those Chinese lights.
  5. Oct 22, 2019 at 3:10 PM
    #2765
    hoverlover
    hoverlover [OP] Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Damn, that sucks. Hope it quits for you soon.
    Thanks! I'm happy with them :)
    How's it going Robert? You've replaced your TOB right? I think mine is beginning to shit the bed.
    I've got the Rigid cubes on my XJ and the CaliRaised side shooter cubes on my Taco, I think I like the Cali's better than the Rigid's. But the BD do dominate both, hands down.
  6. Oct 22, 2019 at 3:15 PM
    #2766
    Beretta4x4
    Josh
    Temple, TX
    Word, I'm only going by word of mouth on the Caliraised, but it's good to see that they do great!
  7. Oct 22, 2019 at 3:16 PM
    #2767
    hoverlover
    Mostly Zip-Ties
    I'll see if I can get some pics if you like.
  8. Oct 22, 2019 at 3:18 PM
    #2768
    Beretta4x4
    Josh
    Temple, TX
    Yeah, I'd like that.
  9. Oct 22, 2019 at 3:45 PM
    #2769
    BassAckwards
    Yes sir sure have! Clutchmasters makes a killer hydro bearing to fix the 2nd gen TOB issue. I have the URD/PDM stainless repair sleeve & larger TOB in mine right now, but it has never chirped since i bought the truck
    Beretta4x4 likes this.
  10. Oct 22, 2019 at 3:47 PM
    #2770
    BassAckwards
  11. Oct 22, 2019 at 3:49 PM
    #2771
    Beretta4x4
    Josh
    Temple, TX
    So there's a fix?! :eek::D
    At this point I don't care about the noise lol. What's so different about the bearing?
  12. Oct 23, 2019 at 4:44 AM
    #2772
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Morning Alex
  13. Oct 23, 2019 at 5:55 AM
    #2773
    hoverlover
    Mostly Zip-Ties
    The URD kit comes with a sleeve to actually fix the problem.
    Hey Matt
  14. Oct 23, 2019 at 6:45 AM
    #2774
    Beretta4x4
    Josh
    Temple, TX
    Morning, Alex
  15. Oct 23, 2019 at 6:45 AM
    #2775
    Beretta4x4
    Josh
    Temple, TX
    :eek:
  16. Oct 23, 2019 at 7:04 AM
    #2776
    hoverlover
    Mostly Zip-Ties
    The design of the throw out bearing assembly used on Toyota trucks can cause uneven wear on the aluminum shaft that the throw out bearing rides back and forth on. The release fork can cause side loading of the bearing as it rides back and forth on the shaft and that can cause uneven wear. When this occurs the throw out bearing becomes loose and can rock back and forth, bind and can cause excessive noise.
    Check it out.
    https://www.urdusa.com/throwout-bearing-upgraderepair-kit-2005-tacoma-v6-6-speed/
    I'd really like to install a URD heavy flywheel when I do this mod...
  17. Oct 23, 2019 at 7:13 AM
    #2777
    Beretta4x4
    Josh
    Temple, TX
    Nice, I like. I don't think I'd use a heavy flywheel. my revs are fine between gears.
  18. Oct 23, 2019 at 7:58 AM
    #2778
    hoverlover
    Mostly Zip-Ties
    Helps off road a lot
  19. Oct 23, 2019 at 7:59 AM
    #2779
    BassAckwards
    Hydraulic TOB that gets rid of the clutch accumulator and slave cyl. The lines for this feed through the bell housing where the slave cyl used to sit. So this would also eliminate your shift fork
  20. Oct 23, 2019 at 8:00 AM
    #2780
    BassAckwards
    Good morning gents :D
