hoverlover’s “there are many like it, but this one is mine” extra long title bs thread and build too
Discussion in '2nd Gen. Builds (2005-2015)' started by hoverlover, Apr 22, 2018.
  1. Oct 29, 2019 at 12:21 PM
    #2881
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Holy crap it should not be that bad
  2. Oct 29, 2019 at 12:23 PM
    #2882
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  3. Oct 29, 2019 at 3:19 PM
    #2883
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    I did some reading this morning during coffee time, and even though a lot of places want to find an engine lean code, the most common thing that kept appearing, would not necessarily be obvious, and could be caused by just bumping any "old" hose - VACUUM leak? Really makes mileage blow, would not seem mechanical, and definitely makes things feel anemic? And man people found leaks all over the place. But a squirt bottle after a quick gauge check....
  4. Oct 29, 2019 at 3:22 PM
    #2884
    Bigdaddy4760
    Maner
    Poolville Texas
    That’s great, the price on these have really came down from when I first started looking into them
  5. Oct 29, 2019 at 4:31 PM
    #2885
    hoverlover
    hoverlover [OP] Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    No complaints! I stayed inside and challenged my students to really use their brains today. I enjoy engaged lessons like that a lot.
    It very well could be, sounds similar. This is going to be a new one for me on this truck as I’ve never done any work on the engine besides the snorkel and spark plugs. Where would you start? What would you do to find a leak?
    I’m not opposed to it, I’ve seen the videos with the borescope, that shit works!
    No kidding! I’ve seen guys in 37’s do better. If that’s what it’s going to be I’ll just buy the 37’s now!
    I never would have thought they cost what they do. I always thought they were way out of my budget. My next shop will definitely have one!
  6. Oct 29, 2019 at 4:37 PM
    #2886
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    Typically I just lurk... but damn son. That's like 8.5mpg if my mental mathz are correct. That's what I get... in the hill country with a whimp motor and stock gears pushing 35s
  7. Oct 29, 2019 at 4:50 PM
    #2887
    BassAckwards
    As do i! Those are the kind that i learn the most from. I have to be engaged for it to stick for me
    I would start by having the hood open and let the truck idle. Start going around the engine bay and listen for any hissing noises and any hoses that look like they may have been dislodged, or are out of place.
    next id turn the truck off and start looking for hoses that could be getting dried out. Sometimes the ends of the hoses get dry and crack right near the ends where they connect, which can cause leaks. id take your time and take off each one of the easily accessible vacuum hoses one by one and inspect and then reinstall before moving to the next one.
    Also, while having the truck running again, you can get some throttle body/intake cleaner and spray it around areas that have rubber hose or seals and if there is a vacuum leak, it will suck that in and the idle will fluctuate/increase. If the idle remains the same when spraying, then theres no leak. Let me know if you have any questions or need any pics. I have a 4.0 too and can get some pics for reference if needed
  8. Oct 29, 2019 at 4:52 PM
    #2888
    CedarPark
    Dylan
    Cedar Park, TX
    Good advise here. Could be spark plugs as well. I'd start there (plugs) then check for leaks personally.
  9. Oct 29, 2019 at 4:53 PM
    #2889
    BassAckwards
    Good point! Plugs are a solid starting point!
  10. Oct 29, 2019 at 4:53 PM
    #2890
    CedarPark
    Dylan
    Cedar Park, TX
    What do you teach?
  11. Oct 29, 2019 at 8:30 PM
    #2891
    hoverlover
    Mostly Zip-Ties
    Lurkers welcome!
    ya. it’s shit right now :rain:
    plugs are less than 10k
    advanced porn acting :thumbsup:
  12. Oct 29, 2019 at 8:31 PM
    #2892
    hoverlover
    Mostly Zip-Ties
    I’m a commercial helicopter pilot and certified flight instructor, I teach people how to fly helicopters.
  13. Oct 29, 2019 at 8:31 PM
    #2893
    Beretta4x4
    Josh
    Temple, TX
    I get 12-13 in Colorado mountains and 15-16 combined here on 35s and stock gears. Something is not right.
  14. Oct 29, 2019 at 8:33 PM
    #2894
    hoverlover
    Mostly Zip-Ties
    Agreed. Just need to find out what it might be. I’ll pull and check the plugs, verify they’re gapped correctly and see what they have to say.
    I’ll clean the MAF sensor and run some seafoam through it as well just for funsies
  15. Oct 29, 2019 at 8:35 PM
    #2895
    Beretta4x4
    Josh
    Temple, TX
    Hopefully it gets fixed. :fingerscrossed:
  16. Oct 29, 2019 at 8:36 PM
    #2896
    hoverlover
    Mostly Zip-Ties
    Hopefully.
    Or hopefully it explodes and I can do my diesel swap. Either way I need it to get a lot better or as bad as possible.
  17. Oct 29, 2019 at 8:38 PM
    #2897
    Beretta4x4
    Josh
    Temple, TX
    Diesel swap. :drool:
  18. Oct 29, 2019 at 8:39 PM
    #2898
    hoverlover
    Mostly Zip-Ties
    :fingerscrossed:
  19. Oct 29, 2019 at 8:39 PM
    #2899
    Oldie2007
    Kurt
    Lockhart, TX
    or you just find that cracked vacuum hose, being 6 years old and all....
  20. Oct 29, 2019 at 8:40 PM
    #2900
    hoverlover
    Mostly Zip-Ties
    Or I shove an M80... somewhere.
