How about this lift kit ?
Discussion in 'Suspension' started by cajunman_83, Dec 23, 2009.
  1. Dec 23, 2009 at 7:25 PM
    cajunman_83
    cajunman_83 [OP] Well-Known Member
    Kevin
    Cajun country Louisiana
    09 double cab long bed base SR5 4x4
    Tool box, rain guards , decals , K&N CAI , throttle body spacer , FlowMaster exhaust , 4X4 switch mod and tires and rims , pics coming soon !
    2005-2009 Toyota Tacoma 4WD 3" Lift Kit with shocks - Rough Country (Back to product)
    [​IMG]Home » Toyota » Toyota Suspension Lift Kits
    [​IMG]Product ID: 745S
    Manufacturer: Rough Country
    [​IMG]2005-2009 Toyota Tacoma 4WD 3" Suspension Lift Kit includes front upper strut extensions, stud extensions, rear 2" lift block, u-bolts and rear Rough Country Hydro 8000 series shocks PLUS shock boots
    100% Bolt-On Installation
    - Unlike the polyurethane kits, this kit DOES NOT require disassembly of the strut
    - Easy Install - No strut compressor required
    Shock Boot Color:Please Select...SELECT RED YELLOW BLACK BLUE​
    Email Friend Price: $249.95
    « Previous | Next »
    I'm wondering about this kit here . Would be great to get some ideas about it . I am not a true off roader , being down here in Louisiana , we have no heels or mountains lol . I would do some mudding every now and again but drive primarily on the road . I am wondering if this kit would last ? I don't have a lot of money to spend and I am wanting a kit that is easy to assemble . It does seem like this fits what I am looking for , just wondering how much negative things there are about this kit . Any information would be greatly appreciated .
  2. Dec 23, 2009 at 8:27 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  3. Dec 23, 2009 at 8:29 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Get rid of those blocks and replace em with leafs...then it'd be okay :)
  4. Dec 23, 2009 at 8:52 PM
    RicnDenver
    RicnDenver Stop talking and START wheeling
    Denver, Co.
    99 4Runner/04 4runner
    toyteclift, budbuilt, stubbs,
    x2 pass the popcorn would ya lol
  5. Dec 23, 2009 at 9:34 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    Those strut extenders can cause your upper ball joints to break, I would get a set of bilstein 5100s up front for $180 and call it a day. The rear doesn't need to be lifted. Just lift the front 1.75 inches and put on some 275/70/17 tires and you will have the best setup possible
  6. Dec 23, 2009 at 10:01 PM
    cajunman_83
    Kevin
    well that doesn't sound too bad neither there, I know that I don't have much experience with lift kits , but what is sad is that my 06 taco 2 wheel drive was hire that my 09 4x4 lol !
  7. Dec 23, 2009 at 10:04 PM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    go big or go home!!!! 6 in procomp haha jk man
  8. Dec 23, 2009 at 10:39 PM
    ExpoSpy
    ExpoSpy Well-Known Member
    Brian
    Temecula
    x2
    Check out Downsouthmotorsports.com...Sonny gives us TW members a discount.
    Good luck!
  9. Dec 23, 2009 at 10:43 PM
    ColtsTRD
    Scott
    AZ
    x3 :cool:
    5100s FTW then you can always add new leafs and OME 885 coils down the road :)
  10. Dec 23, 2009 at 11:12 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    '20 Grey TRD Off-Road 6spd
    TC +2 LT, Kings, BAMF Armor, 35s, gears
  11. Dec 24, 2009 at 5:48 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    I would go with the 5100's and AAL [​IMG]
    Or go for the all out man! :drool: [​IMG]
  12. Dec 24, 2009 at 7:01 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    both the last two options are good ones!
  13. Dec 24, 2009 at 8:11 AM
    cajunman_83
    Kevin
    What about this kit here , seems that it's something that I can put together at home . I don't have a carrage so I will be working outside with jacks and whatever else I might need, I just don't want to have to worry about spring compressors . This kit caught my eye , seems that it gives me all of what I am looking for , just hoping the front spacers are ok , and I am sure that the AAL's would be well worth it . Opinions please ?
    BEST SELLER! 3" Lift w/front spacers
    Price per Unit (1kit): $229.99
    Number 1kits in packaging:1
    Number 1kits in box:1
    TAC3-05----
    Included in kit:
    FRONT: 3" Front Lift Spacer Kit-- CNC Machined From 6061 T-6 Aluminum
    (Available with Black anodized finish for $20.00 additional).
    6 longer top plate spacer bolts.
    REAR: 2" lift ToyTec Rear Add-A-Leafs made by Alcan Spring-- With OEM Style anti-friction Pads, these are a long add-a-leaf for the best ride. New Leaf Spring Center Pins.
    ***Also available with 1 1/2" rear block kit instead of rear add-a-leafs for the same price, select from options below
    Will not work on the 5-Lug Tacoma.
  14. Dec 24, 2009 at 8:14 AM
    DaytonLax14
    DaytonLax14 Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    spacers are a no go
  15. Dec 24, 2009 at 10:07 AM
    ExpoSpy
    Brian
    Temecula
    x2
    I had spacers on my '98 and i went through ball joints twice and ripped a cv boot...don't do it!
  16. Dec 26, 2009 at 12:49 PM
    cajunman_83
    Kevin
    Thanks a lot about that there guys . Just the lack of my experience I knew would deffinitely hurt me later . I am just looking for an easy fix that I could do at home . I didn't want to have to worry about compressing any springs or what not so I guess that I why I thought that the spacers would be the easiest . Thanks again fellas .
  17. Dec 28, 2009 at 7:07 AM
    Toytec Lifts
    Rocky Mountains
    Just curious, who's spacer lift did you have on?
    I haven't heard of anyone having this problem with our spacers. There are completely two different designs when it comes to spacers....
  18. Dec 28, 2009 at 8:58 AM
    DaytonLax14
    Corey
    Ohio
    Really? I'm actually very curious as to how your spacer kits are better.
    edit-I'm not trying to argue with you, I'm honestly curious. I'm looking to get a lift of my own very soon.
  19. Dec 28, 2009 at 8:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have seen BJ's screwed up by Revtecs, and most all top plate spacers. Some shot in less than 5k miles.
  20. Dec 28, 2009 at 5:45 PM
    cajunman_83
    Kevin
    Just being curious here though , I know down here in south Louisiana , there aren't no mountains are any tall hills that we would be riding over to use our 4 wheel drive, just practicly mud pits . I am sure that jumping over hills with the taco's is pretty hard on the front end for the spacers , but for those of use that do not use our trucks for jumping hills or climbing rocks and stuff of that nature , I am just wondering how those spacers would give out so easily and cause so much damage as listed by Soundman1463 ?
