How about two K & N Filters
Discussion in 'Technical Chat' started by Taco Pastor, Apr 8, 2020.
  1. Apr 8, 2020 at 10:15 AM
    Taco Pastor
    Taco Pastor [OP] Well-Known Member
    Brian
    2009 Tacoma V6 access cab 6spd Barcelona rec
    I was wondering and had a modification idea. I have a 2009 Tacoma V6 and was wondering what anyone thought about 2 K&N filters...........one in the airbox and then removing the charcoal filter and putting the 2nd one in place of the charcoal filter? Bad idea? Good idea?
    I have never tried those other filters that are dry( or whatever they're called). Just trying to get more airflow. I do think how Toyota designed the air intake is A CIA, but just want to get more airflow and some mpg's.
    If not K&N filters, which of the dry filters does anyone recommend? I also thought, maybe a K&N in the box and a dry filter for the charcoal filter, might help absorb the K&N oils.
    I also thought about using that quick seal or whatever were the guy glues the boat out of glass and puts it on the water and rides in it. Is that sensor safe?
    Any help would be appreciated and thanks.
    Brian
  2. Apr 8, 2020 at 4:06 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    If you add air, the ECU will add fuel. Correct? Also, K&N air filters have been know create havoc with Mass Air Flow Sensors...Just food for thought.
    Zim
  3. Apr 9, 2020 at 9:00 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    I had K&N on multiple tacomas without any problem. Even checked the throttle body and MAF at 75k amd clean as hell.
