How Accurate is the TPMS?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Winch, Nov 10, 2020.
  1. Nov 11, 2020 at 7:44 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yeah you are correct. Instead of "samples" I should have said "update display." It has to sample continuously in case of a delta P from a puncture or something. Thanks Tony!
  2. Nov 11, 2020 at 7:46 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Depends on the gauge you're using too. I've found several PSI difference between different gauges I've used. I just know the dealership always fills them to 35. I haven't bothered to compare to my topeak bicycle gauge though.
  3. Nov 11, 2020 at 7:48 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cheers!
    hiPSI[QUOTED] likes this.
  4. Nov 11, 2020 at 7:52 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I haven't noticed the TPMS signals adjusting or changing after a reset. I'm pretty sure the sensors output engineering units, like most TPMS units I know of, so all the calibration is internal to the sensor and changing it would require adjusting a gain value in the software of the sensor. Now you could easily implement a pressure offset if the truck measured atmospheric pressure somewhere and then adjusted the TPMS absolute pressures value to gauge pressures. This is very feasible. And that would help match pressures you measure manually as tire pressure gauges measure gauge pressures. I guess it could do this all the time or just during a reset. Or never. Just thinking out loud.
    What does change when you do a reset is the low threshold pressure and this is why you set the pressures first. It reads the new pressures after reset and then creates the low threshold some fixed amount below those new baseline pressures. So your low pressure threshold triggers the warning based on the baseline pressure and not some fixed pressure.
    RichVT, G8R_Taco[QUOTED] and tonered like this.
  5. Nov 11, 2020 at 8:04 AM
    Brogie
    Brogie Well-Known Member
    Mark
    Columbus, OH
    2014 4wd standard cab silver sky
    Reminds me of the old saying:
    The man with one watch always knows what time it is, the man with two is never really sure.
    Kolache007, IrishRed, Knute and 7 others like this.
  6. Nov 11, 2020 at 6:29 PM
    CXYyuppie
    CXYyuppie Sarcasm Master
    Craig
    SE.LA
    2019 TRD Sport DCSB - Cement
    Stuff with some other black things
    Does it have anything to do with tire size? Maybe mine are not sized for the tires I have. My tires are a little larger than stock, 265/70/17. I thought it just sensed pressure no matter of the tire size.
  7. Nov 11, 2020 at 6:36 PM
    ShimStack
    Ben
    NC
    No.
    G8R_Taco and CXYyuppie[QUOTED] like this.
  8. Dec 23, 2021 at 8:57 PM
    tacomalex1949
    tacomalex1949 Well-Known Member
    Alex
    2021 Tacoma DCSB
    I aired up today using a machine the auto cuts off at the set PSI. Set it to 34psi.
    After 30
    Minutes of driving my tpms read 32,36,29,33
    How on earth could they all be so far off from each other…
  9. Dec 23, 2021 at 9:02 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I was wondering myself here on the Washington state coast I see a difference in 4 to 5 lbs of air when I travel from my house to work. Morning truck is at 31 psi and when I get to work 35psi
  10. Dec 23, 2021 at 9:05 PM
    tacomalex1949
    Alex
    2021 Tacoma DCSB
    That’s because your tires heat up as you drive and your pressure goes up. Totally normal
  11. Dec 23, 2021 at 9:08 PM
    shotgunbilly420
    Got sidetracked lol yeah I was just noting my results. I was also wondering how accurate our tpms is . I have multiple tire gauges and they all read different
  12. Dec 23, 2021 at 9:09 PM
    shotgunbilly420
    I understand that my tires warm up lol
  13. Dec 24, 2021 at 7:12 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    Lots of variables here. Do you know for sure that the auto cut off is actually cutting off correctly? You'd need to check that with a reliable gauge. If you verify cut off is correct, then there may be issues with the TPMS. Again, check the TPMS reported pressure against a direct read gauge. TMPS do go bad after awhile.
    Chew likes this.
  14. Dec 24, 2021 at 7:18 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    How many psi from normal to being too low before the dash warning led comes on? Seems this winter i checked my tire pressure and it was between 5-6 psi low from the 30 psi i set it at this summer.
  15. Dec 24, 2021 at 7:25 AM
    #35
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    There's a very good chance the auto off (cut off) is less accurate on cheap Chinesium compressors than a simple gauge or the factory TPMS. I've never had a vehicle that's been more than a couple psi different from known good gauge,,, but I'll still keep in mind, the TPMS system is designed for tire failure and to alert of significant differences for efficiency and early failure warning. If one needs to tune exact tire pressures for that track day balance, he/she should still be using a known good gauge.
    Knute likes this.
  16. Dec 24, 2021 at 8:02 AM
    #36
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Pick one gauge to set your COLD tire pressures. Be consistent using that gauge, then ignore the other gauges.
    FWIW, the term "accuracy" is a misunderstood term. There are many things to define the "accuracy" of a gauge, such as Repeatability, Hysteresis, Linearity. The readout device (display) also plays a part, Resolution, Refresh Rate. The signal from the sensor to the antenna has errors also. The software translating the signal into units can have errors, 12-bit, 16-bit. I spent multiple years in a test lab handling gauges and data acquisition.
    I suspect the sensor system has an overall error level of roughly +/- 1% of reading. So, a display of 30 psi the pressure could actually be anywhere between 29.7-30.3 psi.
    The good expensive pencil pressure gauge is likely +/-2% ( +/-5% is possible) of full scale for accuracy. So a 50 psi pencil gauge (+/-2%) indicating 30 psi, the actual pressure could be anywhere between 29-31 psi. If the +/-5% FS, the actual pressure is between 27.5-32.5 psi.
    My point.....don't get all wound up on the "accuracy" of these devices. You are overly concerned about small differences.
    Example: I was running a test on a high pressure machine using 0.1% Full Scale accuracy on a 100,000 psi pressure transducer. The "gauge" had an error level of +/- 100 psi. The readout on the computer would fluctuate in the 100 digits, meaning 100,xxx the x would move. The design engineer was very concerned about the xxx digits. Did not matter to him that the system was operating within limits. So, I changed the program to use a larger sample of points in the signal averaging and slowed the display refresh to 1/2. The Design Engineer was now happier, because the "hundreds" digit settled for a few moments. The test pressures were in the 70-80,000 psi range. To me, the engineer was silly for worrying about 100 psi error on a 70,000 psi test. Oh well......I was just the Test Engineer.....what would I know......
    Remember, as Winter temperatures fall so will the tire pressure. The same for Summer rising temperatures, the pressure will rise. This is all based in Pressure, Volume, Temperature relationship. In this case the Volume is fixed.
    Chew and zoo truck like this.
  17. Dec 24, 2021 at 8:23 AM
    #37
    shotgunbilly420
    This winter / fall mine has read 31 psi with low tire light on . After a few minutes of driving it goes away
  18. Dec 24, 2021 at 8:41 AM
    #38
    zoo truck
    None
    Well mine tire pressure has dropped as low as 25 psi this winter, but my warning light hasn't come on yet, so i have no clue whats up with this warning system. Maybe needs to drop another 5 psi...who knows.
  19. Dec 24, 2021 at 9:13 AM
    #39
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    On my, the threshold of Low Pressure (lower limit) is 23
  20. Dec 24, 2021 at 9:49 AM
    #40
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    You could always experiment with it and keep letting air out until it triggers the light then you would know for sure, however l think it's programmed to light up after about a 25% drop.
