How air goes thru your engine.....(basic)
Discussion in 'Technical Chat' started by chris4x4, Nov 30, 2008.
  1. Nov 30, 2008 at 2:16 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Have you ever noticed that if you make a quick "puff" at a candle from a short distance, that the air, even though you are not blowing anymore, still makes it to the candle and blows it out? That's because air has "mass", and when in motion, it must be acted upon to stop it. Have you ever noticed that as a kid when blowing bubbles, if you try to blow a bubble to keep it aloft, it seemed that sometimes the bubble would be passed by the air, only to wiggle around, and then "follow" the air you just blew? These little things also apply in an engine.
    As the air is going through the intake, and through the throttle body, there is a bit of turbulence created by the throttle plate. As it continues on to the intake runners, the air is straightened out into a nice laminar flow, as the intake valves open, and the piston is rapidly moveing downward, the air rushes in to fill the combustion chamber, flowing down the sides of the cylinder wall, hitting the top of the piston and moving up the other side and thru the middle, and swirling. as the intake valves close very fast, its like a door slamming shut. The air that was following in to the combustion chamber is now suddenly stopped. This sends a "shock wave" backwards through the intake runners, and if timed properly, this "shockwave" or "Pulse" is now helping to "push" more air into another cylinder.
    Meanwhile, as the air in the first cylinder is being ignited, and producing power on the downward stroke, the piston now begins its upward stroke. The exhaust stroke.This is where scavenging comes into play. Scavenging is when the exhaust valves open and the exhaust exits the cylinder leaving a vacuum behind it. At that point the piston moves the exhaust out rapidly in a "puff". This puff, once again has mass. There is a high pressure area leading the way in front of the exhaust pulse, and when the exhaust valve closes, it happens abruptly, creating a low pressure area behind the exhaust pulse. This pulse travels down the exhaust, and past another cylinder. The low pressure of the pulse "pulls" the exhaust gasses from the next cylinder, when doing this, it creates a vacuum in the combustion chamber helping to "pull" more air into the cylinder as the intake valve is starting to open while the exhaust valve is still open, this is called overlap.
    All these pulses need to keep up their velocity to remain efficient. They do this by staying hot, and by the size of the exhaust pipes. Newer vehicles with variable valve timing (VVT) keep these pulses timed throughout the rpm range. There is a "Goldie Locks" effect taking place. Too large of a pipe, and the pulses slow, exhaust cools too fast, and the engine looses efficiency. Too small of a pipe, and the exhaust is sped up beyond how the timming of the valves was designed, the exhaust temps rise, and the engine looses efficiency. Any change in the system, be it a larger exhaust, or whatever, has an effect on it. Sometimes positive, as the auto makers have to abide by emissions standards, but many times negative, as some aftermarket manufactures just want it to "sound cool".
    When installing a Turbo, or Supercharger, the scavenging effect is not as important, as the higher pressure "pushes" everything through the system, in which case, a larger free flowing exhaust would be the most beneficial.
    I have oversimplified this just a bit, as I don't have time to go into EVERY thing, or break down the physics involved, but thought it would be a good read for those thinking about changeing their exhaust system and wondering how the new exhaust may affect performance. :)
    Special thanks to 007Tacoma for adding the hyperlinks, and editing for me. :)
    Found on a different site about "Back Pressure":
    digitaLbraVo likes this.
  2. Nov 30, 2008 at 2:23 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Nice writeup Chris. Thanks!
  3. Nov 30, 2008 at 2:45 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    awesome job.
  4. Nov 30, 2008 at 3:43 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    AWESOME write-up! :cool:
  5. Nov 30, 2008 at 3:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    great writeup chris!!!:D
  6. Nov 30, 2008 at 4:49 PM
    Brunes
    Brunes abides.
    Rotorhead
    Bored a bit chris??
    Nicely done...
  7. Nov 30, 2008 at 4:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL. I wrote one up a while ago, but it was too long, and the system told me to shorten it. In the process, I became pretty frustrated so I just said F it. I had some time this morning, so I thought I would throw it out. Seems alot of people think that you can do whatever you want to an exhaust and get 4000 more h.p., so I wanted to give a little insight into how things work.
  8. Nov 30, 2008 at 5:23 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Yup Chris explained this process to me on the phone like 3 times. Read his post till you get it and you will know way more than most everyone how an engine runs and what NOT to do to your intake and exhaust until you know how it will affect the balance of that process. Unless youre just doin it for sound or bling:D great knowledge as usual Chris:)
  9. Nov 30, 2008 at 5:32 PM
    Ridgerunner
    Frank
    San Francisco
    I move we make this a sticky especially because it has the most comprehensive explanation of the combustion process from nose to tail and in fine detail too.
  10. Nov 30, 2008 at 6:12 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Good explanation chris. Nice and easy. Thanks.
  11. Dec 17, 2008 at 2:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bumpin it up for the new folks. :)
  12. Dec 17, 2008 at 2:07 PM
    Packman73
    2007 TRD Off Road
    Should be a sticky...:cool:
  13. Dec 17, 2008 at 2:14 PM
    crawfishsoul
    crawfishsoul Look at my member
    Removed front mud flaps.
    x2
  14. Dec 17, 2008 at 2:17 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX/ Lawrence, KS
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights
    Nice writeup!
  15. Mar 3, 2009 at 6:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bumpin for new members. :)
  16. Mar 3, 2009 at 6:47 AM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    nice write up chris i would give you +1 but i cant because i gave it to you like three times this week. haha
  17. Mar 3, 2009 at 7:11 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Great writeup Chris, but I'd like to add a few things here
    You won't see laminar flow going into the engine. There are too many surface variations that create a turbulent flow. It's not really important whether the flow is turbulent or laminar for fuel injected engines, I just don't want people to get confused over this issue.
    I understand you are keeping it simple, but it might be beneficial to point out that the turbocharger is the ultimate scavenger. Also, I would venture to say that the turbocharger creates some back pressure due to that scavenging. The supercharger does not create any back pressure.
  18. Mar 3, 2009 at 7:59 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Whoa, thats what she said!
  19. Mar 3, 2009 at 8:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It is important if the air is turbulent or not. The intake runners are designed to straigten the air flow as much as possible before going into the combustion chamber. A laminar flow will more efficiently fill the combustion chamber than a turbulent flow. In the old days of carburation, turbulence was a goodthing, as it helped to atomize the fuel. Now, with Fuel Injection, a laminar flow is best, and is what the manufatures strive for.
    Yes...the turbo IS, in fact, the unltimate "scavenger". And I have pointed out that a turbo does have a parasitic drag on the engine in the form of an exhaust blockage. However, Scavenging is what I described in the first post.
  20. Mar 3, 2009 at 8:01 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I still think this has some validity
