How are you guys getting 20+ MPG V6 4x4s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnson8537, Dec 30, 2008.
  1. Dec 30, 2008 at 11:31 PM
    Johnson8537
    Johnson8537 [OP] Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    How are you guys getting in or near the 20's with the v6 4x4s?
    I have a longbed DC
    and I towed my jetski on a double trailer up to Eugene from my house and got 14.5 towing have a few 6% grades to go up but normal Oregon Freeway!
    then up tp PDX and back to Eugene got about 17.5 (NOT TOWING). (flat part of oregon) with a few stops
    then from Eugene home to medford got 16.5 (not towing)
    I set the cruise at 72ish and go.
    I take off the cruise to go up any big hills so it does not RACE CAR it up the hills and I drop the speed a little (even though it can do it at 70+)
    Avg RPMs around 2100-2300 i would guess.
    I do have the bigger tires but the GPS is RIGHT ON to speedo so i go what the trip meter says for mileage.
    (this makes me want my Full Size Chevy back... More room and better MPGS ) 15-20 all the time!
  2. Dec 30, 2008 at 11:41 PM
    shootermcgavinyo
    shootermcgavinyo Well-Known Member
    Rockford, IL
    '08 double cab 4x4 v6 trd off road
    I think you get 20+ mpg by coasting downhill with a 40 mph wind behind you.
  3. Dec 30, 2008 at 11:41 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Won't lie, when I got the truck the mileage was poor. Let it break in and the mileage got better, however I am getting 17-18.6 on a regular basis. I have seen 21.4 with my 3" lift and 33s driving to Texas from Louisiana, around 5hrs with some hills. To answer your question hell if I know.
  4. Dec 30, 2008 at 11:48 PM
    BlueXenon
    BlueXenon Well-Known Member
    Los Angeles and Newport Coast
    2024 Solar Octane TRD Sport (current) 2022 Lunar Rock TRD Sport (SOLD) 2020 Cement TRD sport (SOLD) 2009 Magnetic gray TRD sport (SOLD) 2004 Radiant Red TRD Off Road (SOLD)
    I believe it has a lot to do with elevation, weather,towing, and how you drive. I can get really great milage or, i can get really crappy milage. It all depends on those factors I just listed.
  5. Dec 31, 2008 at 12:02 AM
    Johnson8537
    Oregon
    Its crazy.. I think for the most part I drive like a Grandpa! Like there is an Egg under teh accelerator. Very Soft and smooth.
    I agree the above will change things but on a regular basis I see about 14-15 in town and 16-17 on the freeway. ( I did fill it up go drive about 20 miles or so anf fillback back up and got 22MPG driving was mainly under 50mph and flat level ground with my v6 4x4 AC)
    I just thought these trucks were suppose to get better than I get.
    (does the Factory speedo errors have much to do with peoples numbers?)
    Like I said my 33's now make my speedo RIGHT ON according to my GPS.
    I should have my buddy (Trooper) radar me at 60 65 and 70 to see if it is accurate?
  6. Dec 31, 2008 at 12:16 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    johnson- the cold weather seems to have affected my mileage a bit now. Also, speed greatly decreases the fuel economy with the greater wind resistance, especially being a lifted truck. when i tested a while back with my scangauge(calibrated accurate to within a %!) the speed affected my mileage something like this:
    70 mph:13-16.5mpg
    65 mph:16-18.5mpg
    60 mph:19-21mpg
    55 mph: 19.5-22mpg
    this was in the warmer weather on some pretty flat sections of road(101, 140, I5) any headwinds and it dropped maybe 10-30% from there too. My truck is a V6 6speed though so the automatics are supposed to do a little better even. setup was 32's running 35PSI all around and running chevron regular with my K&N drop in filter installed too. as a side note- i've noticed i can get 5% or so better MPGs by NOT using the cruise and using a lighter foot.
    Also, when you calculated did you factor in your larger tire size? with the bigger tire you travel father than what your ODO says, probably 5% or so.
  7. Dec 31, 2008 at 12:29 AM
    HILOTOY
    HILOTOY HILOTOY
    From Big Island
    05 trd 4wd off road,tow pack
    55-60mph..........21 mpg:)
  8. Dec 31, 2008 at 1:26 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I'd get run over trying to drive that speed around here :eek:. I'd made the assumption that speed was my greatest loss of mpg, of course it went down even more when I put on heavier/bigger wheels and tires. I get around 17-18mpg on average with my rough calculations and that is about half highway at ~70 and half city at ~50mph. When I had Dunslops I was getting 19 almost 20, but never over 20mpg with the same driving.
    I don't think we get winter gas in Vegas :confused:.
  9. Dec 31, 2008 at 2:39 AM
    HILOTOY
    HILOTOY HILOTOY
    From Big Island
    speed limits change a lot.........45.........55.......45.........55....and the sharks usually hang at the changes:)
  10. Dec 31, 2008 at 2:45 AM
    Greenblazer
    Greenblazer Thread Killer
    Phoenix. Aridzona
    07 PreRunner Dblcab SR5 Black
    Home Made Tonneau, The Baba Booey Mod... Sirius Satellite Radio
  11. Dec 31, 2008 at 4:39 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Yeah my scangauge mileage is 17.5 pretty regularly when I am not towing. Towing I do not want to discuss it! Plus my driving, winter, elevation isn't helping. Truck has 25k now. This was the same mileage I got with my 4.7 V8 Tundra. Oh well... still love the truck. :D
  12. Dec 31, 2008 at 4:44 AM
    missileman125fw
    missileman125fw Well-Known Member
    I got 20mpg when I first bought my Tacoma. I drove extra carefull and took off rather slowly. Now, I drive balls to the wall at the speed of heat. Mpg now is about 18-19 with half city and half highway.
  13. Dec 31, 2008 at 4:56 AM
    CanTac
    CanTac Well-Known Member
    Peterborough On./Ocala Fl.
    23 TRD Sport 4X4 D/Cab Long Box
    I often get over 20mpg. Various speeds and towing do make a difference though. Over 70 or towing will usually bring you below 20mpg. I now have about 10,000 smiles on the truck and I do really like it so far.
    CanTac
    Hal
  14. Dec 31, 2008 at 5:24 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    hehe I get the 2.7 around 75-80 I get 18MPG lol good ol Regear!
  15. Dec 31, 2008 at 5:43 AM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    what did you regear to?? i still have stock 4.10 and i'm getting 15.5 MPG with my 33x12.5. thats all city driving
    i want to regear to 4.56 but the only place that has them for sale is all pro.....and i'm not ready to spend $1,100 bucks just on parts
  16. Dec 31, 2008 at 5:50 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Best milage I got was 21, and that was about a year after I bought the truck. Made a trip to TN, around 2 AM NO traffic, no wind. Straight shot driving.
    With my lift my speedo is off, but I found that the type of gas you burn has alot to do with it. Maybe I am off base and fooling myself, but I have found BP to run better in my ride.
    For me everytime I want to test for milage, traffic is bad, construction, or weather.
    On another note, I don't drive mine alot, I haven't put 100 miles on it in the last month.
  17. Dec 31, 2008 at 6:47 AM
    jrw1965
    jrw1965 Well-Known Member
    Southern Maryland
    '08 dbl cab long bed 4 x 4
    Front tint, Stainless steel nerf bars, Leer tonneau, Rear spring TSB, Michelin LTX A/T2 265 70 16, Pioneer AVIC X910 so far
    I get somewhere between 17 and 19 city, and 20+ highway. I checked the numbers for about a month. Dont know how I get it, but I'm happy.
  18. Dec 31, 2008 at 6:52 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    My truck setup is a stock DC LB, and I'm averaging 19 mpg city/highway w/ pretty fast driving habits. No jack-rabbit starts, and I try to coast alot through traffic. I babied it during the first 2k, and got around 20 mpg city/highway. There are so many factors in gas mileage that it's not funny.
    Hell, I think that my hood scoop adds a couple mpg. :D
  19. Dec 31, 2008 at 6:56 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    i got about 325 with my tank, with super too.
  20. Dec 31, 2008 at 8:00 AM
    JTDTacoma
    JTDTacoma Well-Known Member
    08 4X4 Double Cab TRD Sport
    Make sure you calculate for tire size too. Best I can get is 19 c/h mix. Now that gas is 1.45/gal I don't even calculate mpg. The lower the gas prices the heavier my right foot gets.
