How are you guys getting 20+ MPG V6 4x4s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnson8537, Dec 30, 2008.
  1. May 25, 2014 at 10:02 PM
    #401
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    ^ Ditto
    It's a midsize pickup. It should get better MPGs... If I didn't care about mpgs I would have gotten a V8 dually or a Hummer...
  2. May 26, 2014 at 2:36 AM
    #402
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Slow down to 65 mph and you'll get another 1-2mpg more. Wind resistance is a bitch which is why a lot of the newer trucks have little ground clearance and are not running large heavy tires.
    With my stock sr5 (non-offroad) and manual trans I pull 20 mpg when I cruise at 60-62mph on flat ground even with a couple dirtbikes in the back.
    Usually I say screw it and go 75mph and get about 16-17 with bikes in the back, 18.change or so when it's empty. Going up mountains the mileage goes down a bit but not too bad.
  3. May 26, 2014 at 2:42 AM
    #403
    Hawkeye888
    Hawkeye888 Well-Known Member
    I checked my mpg a couple weeks ago and made it 380 miles from full to low fuel light. Mix of highway and city. I have a 07 DCSB 4x4 with 160k
  4. May 26, 2014 at 3:47 AM
    #404
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
  5. May 26, 2014 at 4:35 AM
    #405
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I haven't been able to Crack the 20 mile barrier. 18.3 was the best I could do. I know speed was the biggest factor in even getting that.
  6. May 26, 2014 at 5:00 AM
    #406
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Tepends a lot on the outside temperature, gas, mods...I'm at 240mls and have 1/2 a tank left right now. I did not drive on the highway once this time...guess I will be getting 360 to the tank
  7. May 26, 2014 at 5:12 AM
    #407
    fau8823
    fau8823 Well-Known Member
    Tom
    Hampton Roads, VA
    2010 Tacoma Sport 4x4
    Tint-20%, Kenwood 2 meter radio, firestik 2 meter antenna on a BAMF tailgate mount, Extang Solid Fold , Pioneer bhs-3500 HU, clazzio leather seats, Scangauge II
    ^^^^all these. I LOVE my truck, but it's pathetic that it doesn't get any better gas mileage than a full size truck. Then again, that's why the new Chevys and Rams might as well be cars when it comes to stock tires and ride height.
    I'm getting about 17 combined with a leveling kit and 265 70r17 Hankook ATMs. I can get near 20 on the highway going around 65 on flat ground. In the mountains, I'm lucky to get 16 mpgs.
  8. May 26, 2014 at 6:00 AM
    #408
    UrPebkac
    UrPebkac Well-Known Member
    David
    RI
    2016 GMC SIERRA
    Get 20+MPGs in my eyes has so many factors.
    Many of those factors are things such as weather, terrain, traffic, altitude, tires+pressure, modifications, maintenance, speed, driver, and gas type. Among others.
    Getting 20 mpg is easy! Averaging 20+ is a different ball game.
    Background info:
    2007 Toyota Tacoma
    4.0l v6 DCLB automatic 87007 miles.
    Before lifting with my michelins LTX ms2 (35lbs tire) I was averaging 17.5 mpg all day every day. I have a 2 mile commute to work below 25 mph, 7 stop signs/lights. If I do any highway driving it will likely be only highway(trip mileage). My all highway average over a 6000 mile trip I averaged 21.8 mpg. Or 358 miles to 16.4 gallons. Mostly I-95. My ave speed was 66 mph at 1945-1975 rpms.
    My averages did not change after lifting 2.5".
    After putting on 285/70/17 my mpg dropped dramatically (62 lbs tires). But I knew that would happen until the ecu adjusted to the tires. My first tank was 13.3 mpg. After putting 1000 miles on the tires, adjusting the pressures up to 42 psi, correcting the distance on the ultra gauge for the additional tire height and summer gas is here. In town driving to and from work I average 15.8 mpg in town. Only highway driving, I average 20.2 mpg. Or 326 miles to 16.1 gallons. Ave speed 69 mpg at 1945-1975 rpms via ultra gauge (speedo on dash is wrong now still thinks I am doing 66 mph, and odometer on dash is wrong now for distance)
    My mixed driving mpg over 10k miles is 18.3 mpg.
    I also have a k&n drop in filter and have removed the secondary air filter.
    Hope this help someone else.
  9. May 26, 2014 at 6:03 AM
    #409
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    Skinny tires and 16" wheels
  10. May 26, 2014 at 7:19 AM
    #410
    Mikeyjd
    Mikeyjd MPG Enthusiast
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    Grill Block, Front Belly Pan, 3 inch lift shims in front, AAL rear suspension lift, Ultragauge Instrumentation, Flush Topper, Full Synthetic Fluids
    Here is what I learned from my UltraGuage recently regarding speed vs fuel economy. These results are instant readout during flat terrain constant throttle driving. All results were taken after the vehicle was thoroughly warmed up on a wind free 70f day. One way to increase economy significantly on shorter runs would be to install pre-heating systems to bring the vehicle to operating temps asap.
    03-30-2014
    Speed MPG Load RPM
    45mph 32.7 26.1 1775
    50mph 32.2 26.3 1975
    55mph 29.9 28.0 2075
    60mph 27.3 31.4 2350
    65mph 26.5 32.2 2525
    70mph 23.9 35.7 2800
  11. May 26, 2014 at 8:57 AM
    #411
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    My commute is 10 miles of 45-50 speed limit, and I keep it to 50, your results show I'm at the sweet spot.
  12. May 26, 2014 at 9:11 AM
    #412
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    On a 10 mile commute a block heater would help significantly. I'm betting you'd net 2-3mpg from a 1 hour preheat summer and 4-5mpg in the winter :)
  13. May 26, 2014 at 11:10 AM
    #413
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The thing is.... alllllll of your information is skewed / irrevelant.... you are running a 1st gen 97 taco w/ the 3.4 w/ manual trans and probably manual hubs ... vastly different, and a much better platform for hypermiling than the 2nd gen v6
  14. May 26, 2014 at 1:53 PM
    #414
    worthywads
    Not really, most vehicles are geared to produce very similar results speed vs mpg. Most vehicles get best mpg at 50 and it goes down from there.
    Hardly *irrelevant
  15. May 26, 2014 at 2:37 PM
    #415
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    I am only getting 16.5 to 17 mpg in city driving.
    When I get out on the open road it does better.
  16. May 26, 2014 at 3:53 PM
    #416
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    /\/\THIS/\/\/\
    Highway test is done at 55 MPG on new vehicle, stock straight out of factory. So to get 21 MPG on v6 4x4 on Highway people needs to be in 50-55 MPH range all the time. If you above that stop complaining about MPG's because you are out of range.
    I had my truck for 8 years and it still does 21+ on highway.
    Easy city driving drops to 18 MPG on average. (those numbers are summer on premium)
    This has nothing to do with Toyota, those are laws of physics. :rolleyes:
  17. May 26, 2014 at 6:11 PM
    #417
    menof2amendment
    menof2amendment Well-Known Member
    Robert
    Simpsonville, SC
    Tocoma TRD off road
    stock, no mods
    My fuelup yesterday showed 23mpg. 2014 TRD V6 dblcb about 6100 miles on it. no mods Just calm normal driving all interstate. Mileage was 18.5 or so when I first got it Dec, 24 2013. Accumulating miles on the engine and summer blend gas, mileage is improving. The performance chips don`t work, if they did EVERBODY would be using them.
  18. May 26, 2014 at 6:56 PM
    #418
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    For the physics lesson. :rolleyes:
  19. May 30, 2014 at 7:40 PM
    #419
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    I commute about 50 miles per day and I've tried to see how high I can get MPGs on my truck, which currently has around 1600 miles on the clock (stock aside from a bed cover). You can see where I'm currently at in my signature block and I'm pretty confident it'll get past the 20mpg mark if I drive it accordingly. That said, I've dusted off my wife's trusty old 2006 Corolla with 180k miles and that'll be my commuter moving forward...money saved at the pump = more stuff for the truck.
  20. May 30, 2014 at 9:19 PM
    #420
    Rafiki
    Rafiki Member
    Tucson
    14 TRD
    2014 TRD OR with 7,000 miles. I get 21 consistently. I go the speed limit up to about 65. We have a couple of highways here with a 75 MPH speed limit and I still go 65. People are not happy with me, but mileage is somewhat important to me and I would go 55 if I could. I also take it easy off of traffic lights. Piss people there too. I piss a lot of people off.
