How are you mounting your kayaks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jquest, May 23, 2018.
  1. Sep 10, 2021 at 2:14 PM
    #81
    BobbyTacoTRD
    BobbyTacoTRD Skewps Ahoy!
    2021 TRD Off Road
    That's brilliant....simple and highly effective. Thanks for the photos.
  2. Sep 11, 2021 at 1:14 PM
    #82
    pwgunny
    pwgunny Well-Known Member
    Patrick
    Charleston, SC
    2021 TRD PRO LR, 2020 T4R SR5, 2004 T4R Sport V6( Sold)
    Newwt and Junkhead like this.
  3. Oct 6, 2021 at 4:11 PM
    #83
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    J cradles mounted on BillieBars. I also have the Bakflip MX4 which so far has remained weatherproof even with the billiebars…
    Junkhead likes this.
  4. Oct 6, 2021 at 4:37 PM
    #84
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Goes on my OEM roof rack. Works great so far.
    Road_Warrior likes this.
  5. Oct 6, 2021 at 4:53 PM
    #85
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    That is super cool, very creative. Love it.
    Amuzed2death[QUOTED] likes this.
  6. Oct 6, 2021 at 4:57 PM
    #86
    Rollo67
    Rollo67 Well-Known Member
    Standard Yakama rack but a couple of pieces of PVC that run enough length of the hull not to cause a divot or warp. I always load my boat hull down since I usually keep my seat mounted and a bunch of crap under it.
  7. Oct 6, 2021 at 5:12 PM
    #87
    van6ogh
    van6ogh New Member
    2021 Tacoma OR DCSB
    just curious, why not use the roof rack? Over 100 pounds?
  8. Oct 6, 2021 at 5:38 PM
    #88
    Amuzed2death
    Amuzed2death Well-Known Member
    17 mgm dcsb trdor
    Ask my accountant
    Right at 100 lbs with two kayaks, yes, but also a bit too high to load easily. I have actually added 2 inflated 11’ paddle boards and the two kayaks on the rack and a bed full of camping shit, so its kindof an overflow. Works quite well as a tie point for camping tarp. Also, part of the reason for the roofrack was to stop the channel filler from blowing out all the time.
    J bars are adjustable for angle.
    van6ogh[QUOTED] likes this.
  9. Nov 8, 2021 at 1:40 PM
    #89
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    I just ordered an RCI roof rack and need to mount some j-bars to it so I can haul two, maybe three kayaks while I have my camper on the hitch. In the past I saw a member had made some flat brakets that made it easy to bolt the j-bars to the 80/20 rack instead of clamping them around the 80/20. I tried searching through a bunch of the kayak threads, but couldn’t find it again. It’s a long shot, but does anyone know of anything like that or remember what I’m talking about and which member made them?
  10. Nov 8, 2021 at 2:05 PM
    #90
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    i dont recall what you're talking about, but cant you just put the t nuts into the aluminum and put the bolt through the top part of the j hook mount? and not use the bottom?
  11. Nov 8, 2021 at 2:09 PM
    #91
    Absolut_Boost
    Cincinnati, OH
    From what I remember the spacing is too wide for the 80/20. The bracket they made bolted to the 80/20 and gave holes at the correct spacing for the j mount
  12. Nov 8, 2021 at 4:01 PM
    #92
    Amuzed2death
    17 mgm dcsb trdor
    Ask my accountant
    I got some flat 1/4 aluminum plate from onlinemetals.com
    Bolted the plate to the t-slot then the j bars to the plate. Makes it real sturdy. Used the system 3-4 times a week all summer.
  13. Nov 10, 2021 at 2:06 AM
    #93
    Absolut_Boost
    Cincinnati, OH
    that will probably be the route i end up going, i appreciate the pictures
  14. Nov 10, 2021 at 6:22 AM
    #94
    CLT_Rick
    CLT_Rick Well-Known Member
    Nevada
    2021 TRDOR / 2016 TRDOR
    Thule Hullavator on Rhino Rack bars with quick disconnects.
  15. Feb 18, 2022 at 8:56 AM
    #95
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Questions for you:
    1. How much of a PITA is it to get those up onto the roof? How do you do it? I have the same setup (roof rack, TBD on the kayak mounts but looking at similar). Wondering if it will tweak my back to do it. I have the same/similar weight and size boat.
    2. You didn't have luck with the 2 by bars? My wife does not currently have a boat, but I was thinking about getting a 2 by setup anyway in case that does happen, future proof it, sort of thing. But if they're janky then I will reconsider.
    So you just put noodles on there, put them flat and strapped them down? No mounts, racks, etc?
    I have the same roof rack - just trying to get a decent plan for this year. I have a rack similar to this, my plan was to do J bars like above.
    Are these one of those ones that slides down and makes it easier to load? If so, how do you like that? From my comments above, I'm just skeptical about lifting a boat over my head every day (I use it on a very frequent basis to take the dog swimming).
  16. Feb 18, 2022 at 9:52 AM
    #96
    CLT_Rick
    Nevada
    Yes - they drop down to about waist level for loading, then are spring loaded / assist to move up into position. They're ok...what I don't like is the noise the mounts make that are on the crossbars. The yak racks themselves disconnect pretty easy (1 pin) from the mounting bracket, which is semi-permanently mounted in the crossbar. I tried keeping the crossbars on my truck, just to declutter garage a bit more, but the wind whistling is too much...so I have to remove crossbars and store with the yak racks.
    GarlicFarts[QUOTED] likes this.
  17. Feb 18, 2022 at 10:40 AM
    #97
    GarlicFarts
    Lil Rhody
    Woof. I just looked up the price. :boom:
    Cool, but I'll see if I can make do without these for now. For that I can get a HF trailer and set up for the same cost, too, so TBD. Thanks for the input though!
  18. Feb 18, 2022 at 10:55 AM
    #98
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    I use my Martin Offroad rack with some j bars, they came with the kayaks. Kind of a pain to get them up there but I am working on something to make it easier
    yG7uu2YMa6-ClbfNQ89eKHKrvVLROqhLjGR9SGj1_95b9426496f45cb99f8057d4dc9c2de4588f0387.jpg
  19. Feb 18, 2022 at 10:56 AM
    #99
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Mounting yaks on the roof is definitely a young man's game! :) My back and knees just could not handle that anymore! That is why I bought a used jet ski trailer for cheap on Craigslist. Slide the boat on the trailer, strap her down and off you go!
  20. Feb 18, 2022 at 11:09 AM
    #100
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Right there with ya. I got a roof rack for my kayaks, tried once to put them up there and gave up. Now the J racks live in the basement and the kayaks go in the bed. I need to come up with a better way to carry 2 10 foot fishing kayaks and 2 6 foot kids kayaks (sometimes 3 10 footers and 2 6 footers). I think a trailer is in my future soon, as a added bonus, the swimming lake has no parking for trailers, so I get to park it in the drop off area and leave it there.
