How are you supposed to drive uphill?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tehkoema, Jul 15, 2018.
  1. Jul 16, 2018 at 7:19 PM
    #61
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I'd like to ride with some of you manual guys up a 8% grade in 5th gear and see what happens if you want to speed up. 100% certain you are gonna downshift, just like the auto...
    I drove over the Appalachians a few weeks ago with my trailer and the dead peddle was my only complaint. That's not an auto problem, it's a drive by wire problem. The problem with the auto is it doesn't immediately kick down and then when it does it really kicks down. The manual certainly has the advantage there. Limiting the auto using S mode largely fixes the issue.
    Alden and m603holden like this.
  2. Jul 16, 2018 at 7:21 PM
    #62
    eurowner
    eurowner Duke Sky
    Scoty
    This V6 with its variable valve timing likes to rev, so git the pedal to the carpet in S Mode!
  3. Jul 16, 2018 at 7:22 PM
    #63
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    What speed you thinking Dangle?
    In 5th at 70mph I'm at 2900rpm. If I'm not loaded it zips right up the hill.
    Don't forget how low geared the transmission AND rear end are.
  4. Jul 16, 2018 at 7:24 PM
    #64
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Manual transmission is better for everything except sipping coffee on the way to work...
    honda50r and rsimi72 like this.
  5. Jul 16, 2018 at 7:26 PM
    #65
    Lt. Dangle
    Ohio
    I wasn't referring to your post when I posted mine, we just happened to use the same speed lol.
    I am just thinking back on my trip over the mountains pulling a trailer, but unloaded on flat ground I don't think either truck need downshifted if you roll into the throttle at that RPM. The manual does have the advantage of being a whole gear (virtually) lower than the auto though. That's why S mode works so well, but so few people use it for some reason.
  6. Jul 16, 2018 at 7:48 PM
    #66
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Yeah, no. I'm 4th on hills. All day.
    Alden likes this.
  7. Jul 16, 2018 at 7:49 PM
    #67
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    It wasn't called S mode in the 2nd gens, but in my 2011 SR5 AT driving around the Black Hills or the Appalachians I'd drop it into 4th and leave it. When my wife took over driving and we started up a hill I pushed the knob over to 4 she was perplexed.
    On the flip side, everytime shes in my 2017 she acts like 6th doesn't exist... weird.
  8. Jul 16, 2018 at 7:51 PM
    #68
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    Whatever works for you, dude.
  9. Jul 16, 2018 at 7:51 PM
    #69
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    ovtune and 4.88's next big mod
  10. Jul 16, 2018 at 7:56 PM
    #70
    m603holden
    Marteeen
    New England
    100% accurate. I do 4th on real hills. Maybe 5th on highway hills. I've dropped to 3rd with the boat under 10+ no issues. But I've never had power issues.
    Alden likes this.
  11. Jul 17, 2018 at 3:46 PM
    #71
    Tehkoema
    Tehkoema [OP] Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    So I went on the highway again today and using S5 with ECT and it was a huge improvement. I tried S4 briefly but it felt like overkill. Locking out 6th was all I needed to do it seems.
    Crazy how simple that was. 6th gear is kinda useless I guess unless you're driving in Saskatchewan or some really long flat road.
    Beer:30 likes this.
  12. Jul 17, 2018 at 4:36 PM
    #72
    Lt. Dangle
    Ohio
    Pretty much.
  13. Jul 17, 2018 at 5:04 PM
    #73
    Taco_17
    Taco_17 Active Member
    2017 SR5 DCSB MGM
    Long long road with a slight downhill grade! ;)
  14. Jul 17, 2018 at 6:18 PM
    #74
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    I used to put my '15 4.0 auto in the 4 position on long grades and in the mountains, doesn't seem like much has changed to be honest...you're locking out 5th and 6th instead of just 5th. And 6th is just a fuel mileage gear for fairly level highway cruising as far as I'm concerned, auto or manual.
    People seem obsessed with not revving engines, I don't get it. It's better to let the thing rev a little and be in the powerband than lug the things around. I drive my truck and Harley the same way, I don't bother with 6th gear until I'm doing at least 65-70 mph and just cruising along.
    I'm pretty happy with the 3.5 6MT combo, the way I see it is if I have to be thinking about what gear I'm in all the time anyway I might as well have the fun of a clutch and stickshift. Plus nobody asks to borrow it. Double win!
  15. Sep 25, 2019 at 9:24 AM
    #75
    glockner
    glockner Well-Known Member
    Scottsdale, AZ
    2006 Tacoma TRD Sport 4x4
    Have a 4.0 auto and recently took a trip over labor day through some pretty steep grades. I kept it in overdrive the whole time and I did not like all the searching it was doing. Found this thread so now I will try putting it into the 4th position when climbing up steep grades at highway speeds (65-70 mph). My question is, after the climb is done, do you all put it back to overdrive for the flat/down grades or just keep it in 4th until you are free and clear of grades?
  16. Sep 25, 2019 at 9:56 AM
    #76
    aleja_333
    aleja_333 Well-Known Member
    Colorado
    19’ Pro AT, 5.29's, Fox 2.5 RR, Alcan, PowerBrake
    Magnuson, Stryker tune, C4, Archive Garage HH, Alucab CC
    This!! I totally feel you.
  17. Sep 25, 2019 at 10:32 AM
    #77
    Nightscape
    Nightscape Well-Known Member
    SoCal
    2017 TRD Sport DCLB
    I don't mind high rpm driving. Drove an Integra gsr for 5 years so very much used to it. 3200-3400 rpm feels similar to VTEC from the B18 Honda motor. Let it rip.....
  18. Sep 25, 2019 at 10:34 AM
    #78
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    If back on flat road, go back to D. As long as the tranny isn't hunting or you find you can't keep you speed under control without constantly braking, D is fine. For downgrades use whichever lower gear gives you enough engine braking to avoid having to keep mashing the brakes over and over. For upgrades use whatever lower gear keeps you in the powerband and avoids gear hunting. With my 2016 (3.5L 6AT), I will often ascend and descend the local canyons where speed limit is 35-45 in S3. With my old 4th Gen 4Runner (4.0L 4AT), those same canyon roads would likely have me limiting the tranny to 2nd or 3rd gear all the way up and back down. If climbing and the tranny keeps having to downshift, your allowed top gear is too tall, drop it down one and see how it does. If going downhill and you find your speed is not being controlled by the engine and you have to keep hitting the brakes, same deal. Drop down a gear and see if it improves. On really steep downgrades you will find that engine breaking alone will not be able to keep your speed under control without risk of overrevving and will have to periodically use the brakes to slow your momentum.
    TacoTerrier and glockner[QUOTED] like this.
  19. Sep 25, 2019 at 10:34 AM
    #79
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    With your foot on the gas:notsure:
    Junkhead and auskip07 like this.
  20. Sep 25, 2019 at 10:36 AM
    #80
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i typically like to speed up before i hit a hill and let it lose a little speed. Thats how i drive up hill. I also like to slow down before i reach the stop sign so i dont have to slam on the brakes. Im pretty good at driving
    Junkhead likes this.
