How bad are leveling kits for off road use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KushKing420, Nov 4, 2020.
  1. Nov 4, 2020 at 2:27 PM
    KushKing420
    KushKing420 [OP] New Member
    Ricky
    13 Tacoma Access-cab (4x4)
    Camper shell
    I like the look of leveling kits but can't help but notice how bad people harp on the ride quality. Is it really that much worse than factory? Also do they do off road? Nothing technical, rather just deep mud and puddles on washed out back roads. Mudding I guess? I'm looking at putting 33s on it.
  2. Nov 4, 2020 at 2:39 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    It’s not all “leveling kits” that are getting ragged on. Generally, its spacers and blocks people rage about.
    Island Cruiser likes this.
  3. Nov 4, 2020 at 2:44 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, exactly this.
    Not all leveling kits are created equal.
    I would recommend the 5100’s at a minimum.
  4. Nov 4, 2020 at 5:54 PM
    USACEPrkRngr
    USACEPrkRngr Member
    Isaac
    2011 Grey Tacoma TRD Sport
    K&N Intake, Full Boar cat-back dual side exit exhaust, Iron Man 4x4 3" suspension (coils, shocks, leafs), Iron Man UCA's, Helo 17x9" wheels 12mm backspace, 285/70-17 tires, black headlight assemblies (stock design, black backing), ditch lights.
    I had pucks/blocks for a while. Ride got a lot stiffer and off road performance was fine, about the same as stock. You definitely don't gain any performance from it. I recently upgraded to a full suspension kit and it made a world of difference, both in looks and performance.
  5. Nov 4, 2020 at 5:59 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Maybe with quality new springs. With conpressed factory springs those billies ride 100% worse than a spacer lift.
    TnShooter[QUOTED] likes this.
  6. Nov 4, 2020 at 6:01 PM
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Las Vegas NV
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    I used them until I got my lift. Never had a problem, never broke a shock, nothing. I was rough on my trucks. I had it on 2 different trucks and nothing. People say that you will break a shock in half, well I seen fox and kings broken a lot as well.
  7. Nov 4, 2020 at 6:06 PM
    Bishop84
    Bishop84 Well-Known Member
    Just do it, they are easily reversed. Just don't bounce off rocks and you'll be good.
  8. Nov 4, 2020 at 7:14 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^
  9. Nov 4, 2020 at 7:22 PM
    TacoTuesday1
    FL
    you're probably replacing worn shocks with liftable 5100's anyway.
    springs don't cost much more, $200. vs a $50 front spacer.
    And an add a leaf can lift the rear; those are also cheap.
    Kind of weird to drop $18k on a newer truck and then trip over cheap springs.
    Spacers are good at announcing to the world "owner of this truck is dumb"
    same goes for nerf bars
