How bad did I break it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BlueFox18, Nov 11, 2022.
  1. Nov 11, 2022 at 10:11 PM
    BlueFox18
    BlueFox18 [OP] Well-Known Member
    Wade
    2018 Cavalry Blue Tacoma TRD Pro
    Went for what was supposed to be a nice scenic drive with the wife that turned into anything but.
    got to the top of the scenic road just to find it gated for the winter and decided to take the side road that was marked as a campground. The thought was I’d find some cool spots for another time and be able to turn the truck around. Well, there weren’t any good turn out spots and we found ourselves on a snow covered trail with a steep drop off on the passenger end. Proceeded to slide into a rut and get stuck against a rock and my sliders. (Thanks CBI for the protection for the body of my baby).
    In the process of getting unstuck I think I really did some damage.
    The truck situation was this:
    Passenger side low and weight against a rock.
    I was able to dig out and place traction boards behind the wheels.
    Some friendly hunters in a Yamaha UTV came along and helped winch me back.
    We got the truck unstuck but in the process of getting it back forward on the trail bad things happened. I had the truck in 4L with the rear differential locked. Put it in drive and was getting very little. All of a Sudden BOOM and I felt something in the truck change. The face of the man helping about crushed me. I jumped out and looked and there’s some sort of oil or synthetic looking substance leaking around the skid plate. There’s no Power being delivered to the front wheels. Im thinking I just blew my front differential.
    we were eventually able to get the truck back on the trail and had to continue forward down a ways to get to a turn around spot. Going in reverse in the snow is a no go because I have no power to my front wheels. Had to get a ride out tonight and planning to go back with some friends tomorrow to try and tow it out.
    Give it to me straight, how bad is this? This is a first for me but I’m willing to learn from my mistakes.
    I tried to shift it out of 4WD but it won’t seem to get off the blink 4WD light so I don’t think it has been successful into shifting it officially into 2WD
    CygnusX191 likes this.
  2. Nov 11, 2022 at 10:19 PM
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    Hard to say without pics, specifically with the skid removed.
  3. Nov 11, 2022 at 10:20 PM
    BlueFox18
    Wade
    Understood.
    Hopefully I’ll be able to get pics tomorrow when I get it out of there and back to where I can get under it and take it apart
  4. Nov 11, 2022 at 10:22 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Sounds like you blew the front diff up....
  5. Nov 11, 2022 at 10:23 PM
    alwaysHI
    2017 MGM DCSB
    I’ve broke shafts before (and that shit was loud). I’ve broken them on the outer joint where the ball bearings came out haha.
    I’ve also had diff fluid push thru the breather and that freaked me out. It’ll either do this if the breather is clogged, water/condensation builds in the diff, or the diff is simply overfilled.
    It’s possible the diff went with all the other factors, but I’d hate to assume right off the bat without pics. These electronic controlled trucks could have a bunch of causes, versus the ol reliable J shift 1st gen tacomas
    just keep us posted
  6. Nov 11, 2022 at 10:55 PM
    BlueFox18
    Wade
    That’s what instinct is telling me as well.
    Having never done this before. Will driving it out the mechanic cause more harm? Should I just get it to a road then call a wrecker? Seems to do okay and no signs of engine trouble or anything
  7. Nov 11, 2022 at 11:36 PM
    NickFox
    NickFox Active Member
    Nick
    2019 Tacoma TRD Off Road
    Stock
    Definitely don't drive it out. Without knowing the problem you could seriously hurt your truck!
  8. Nov 12, 2022 at 12:18 AM
    alwaysHI
    2017 MGM DCSB
    don’t drive it till you know what it is. Tow the truck - the tow bill will be cheaper than causing more damage or, something failing miserably and causing you to crash or hurt someone else. I work in the Fire Dept and pending on the type of accidents I respond to, that’s my realistic go to line to members of the community
  9. Nov 12, 2022 at 12:50 AM
    BillyE
    BillyE Well-Known Member
    I’m not really familiar with these trucks, but blowing apart a differential housing seems less likely than a CV shaft. My guess is it bound up in 4Lo and the weakest point has to give. Usually that means tires slipping but in your case, maybe a CV joint. Regardless, get it up on a flat bed and go from there.
  10. Nov 12, 2022 at 1:23 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Whatever it is that you’re leaking could be all be leaked out by now, so even without seeing any physical damage I wouldn’t drive the truck.
  11. Nov 12, 2022 at 2:55 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Probably your ADD tube or cv axle.
  12. Nov 12, 2022 at 5:16 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Following....
  13. Nov 12, 2022 at 5:18 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I would have thought something else would let go before the differential gearing disintegrated, but you never know!
    Good luck OP. If it's broken, then fix it. At least you were out there doing what these trucks were designed to do.
  14. Nov 12, 2022 at 5:24 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    :fingerscrossed: Maybe try to rotate front drive shaft between tcase and front diff, does it turn freely? Good luck. Stuff happens...
    Sounds like it's the front diff gears.
    CygnusX191 and BlueFox18[OP] like this.
  15. Nov 12, 2022 at 5:29 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    OP: Is the truck lifted? How much lift?
  16. Nov 12, 2022 at 5:46 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  17. Nov 12, 2022 at 5:50 AM
    bornxbackwards
    bornxbackwards Well-Known Member
    Bruno
    Sherbrooke, QC
    2021 MGM Tacoma SR5 4x4 DCLB
    Debadged, black sumos, brake controller.
    I was expecting a "I drove in 4x4 about 4 seconds on pavement" thread.
    That's a real bummer OP. Hope it all doesn't cost an arm and leg.
  18. Nov 12, 2022 at 5:55 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Ha! Me too!
  19. Nov 12, 2022 at 6:15 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  20. Nov 12, 2022 at 7:32 AM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    I doubt it's the diff gears, as them going would likely not cause diff oil to leak (the housing would contain all the carnage). The CV axle is meant to be the weak link in the front drivetrain, and when they go, they make a loud popping noise. It is quite easy to break one of these, and is the reason some keep a spare with them. It is possible that if CV did go, the release of energy could have allowed the portion in the diff housing to pop out, thereby allowing diff oil to leak.
