How bad did i f*ck up?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wilgray2010, Sep 27, 2015.
  1. Sep 27, 2015 at 3:29 PM
    Wilgray2010
    Wilgray2010 [OP] Well-Known Member
    Northbridge, MA
    01 2.7 5spd
    Billy 5100s, 20% tint, s13we tundra calipers/rotors, super turbo muffler
    I changed my calipers today and accidentally topped off my brake resivor with power steering fluid. Maybe. 1/4 of the resivor. It was in the system for 4 hours and I drove about 15 miles before i realized and immediately flushed the system. Now what?
  2. Sep 27, 2015 at 3:33 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Flush it till it's completely clear brake fluid at all 4 corners?
  3. Sep 27, 2015 at 3:34 PM
    Wilgray2010
    Northbridge, MA
    01 2.7 5spd
    Yeah
  4. Sep 27, 2015 at 3:35 PM
    Rmodel65
    Jawja
    1996 Yota 4x4
    Viper Red paint
    My tacoma calls for atf for power steering did you put red atf in there?
  5. Sep 27, 2015 at 3:39 PM
    Wilgray2010
    Northbridge, MA
    01 2.7 5spd
    No it was prestone PS fluid comes in a yellow bottle
  6. Sep 27, 2015 at 3:42 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    I'd get it out asap. It will damage seals very quickly. You might get lucky but the damage has been done.
  7. Sep 27, 2015 at 3:44 PM
    Wilgray2010
    Northbridge, MA
    01 2.7 5spd
    Yeah i flushed the system as soon as i realized.
  8. Sep 27, 2015 at 3:44 PM
    jmaack
    Justin
    Helena Alabama
    Good luck
  9. Sep 27, 2015 at 3:46 PM
    Wilgray2010
    Northbridge, MA
    01 2.7 5spd
    Thanks.
  10. Sep 27, 2015 at 3:47 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Well you still had brakes I assume, but yeah get alot of D.O.T. fluid & flush system
  11. Sep 27, 2015 at 4:59 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    Uh oh! :fingerscrossed:
  12. Sep 27, 2015 at 7:26 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Calm down everyone, its fine, just flush it out two or three times using a whole bottle of brake fluid.
    For those that disagree, then suggest what he should start tearing apart first.
  13. Sep 27, 2015 at 8:26 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    On a side note you really should use atf for your power steering....says it right on the cap.
  14. Sep 27, 2015 at 9:58 PM
    Fallguy6666
    Fallguy6666 Well-Known Member
    Flush it and your fine.....power steering fluid is a lotttttt less damaging than brake fluid....example- put a dab of power steering fluid on your paint.......then put a dab of brake fluid on your paint.lol.
  15. Sep 27, 2015 at 11:05 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    I personally don't think you did much of any damage. Both fluids are hydraulic fluids, even ATF is just a special hydraulic fluid, but they have different properties for stuff like compressability, or contaminate absorption, or lubrication capabilities like lubing the impeller of a power steering pump.
    being in the auto parts business, i've sold a lot of o-rings for multiple purposes, mostly for hydraulics on tractors. but i sell people the same o-rings for stuff like master cylinders, power steering lines, and some for rubber brake hoses.
    I've never had a single person come back ever saying the o-ring deteriorated because of any of the fluids. you can rest assured, you didn't do any damage.
    the real reason you shouldn't use PS fluid in your brakes is because PS fluid will compress more than brake fluid. so it will feel spongy under extreme/emergency circumstances. you just cant trust it like brake fluid. but yes, make sure to bleed the system properly and get every bit out that you can.
  16. Sep 28, 2015 at 5:44 AM
    DirtDriven
    DirtDriven Active Member
    I think if you flush it good you will be fine. I think it could damage the seals over time if left in there, but if you flush it good now I think you will have little to no damage.
  17. Sep 28, 2015 at 12:23 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I would agree, no harm no foul, because its just fluid used for hydrolic pressure so the ONLY thing I see as a problem is it may have different hydrolic compression rates.
    if you haven't already done so break the lines loose from master cylinder and flush it separately then reconnect and flush out the lines
  18. Sep 28, 2015 at 1:20 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    How can ATF damage seals?????????? Automatic transmissions and power steering units are full of 'em.
  19. Sep 28, 2015 at 1:32 PM
    jmaack
    Justin
    Helena Alabama
    Seals that aren't designed for it. Being he realized it immediately and flushed it's different. Feel free to top yours off and try it out though.
  20. Sep 28, 2015 at 2:11 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
