How bad did I screw up (block heater install)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by diverdriver64, Oct 24, 2014.
  1. Oct 24, 2014 at 7:44 PM
    diverdriver64
    diverdriver64 [OP] Well-Known Member
    Kodiak Alaska
    05 Tacoma 4.0 V6 6Spd manual
    So I recently bought and installed the Katz cartridge block heater for my truck. I installed it ok, but after looking back, realized I may have screwed the pooch a little. This product did not come with any kind of grease, but I had seen everybody mentioning using dialectic grease. So i bought some dialectic grease and used it in the plug end as is correct, but I also slathered the cartridge itself in dialectic grease rather than What I now know should have been thermal grease. So how bad is this? I haven't used the heater yet and am wondering if I need to pull it, clean it and the hole, and put thermal grease on. Or will it be fine?
  2. Oct 24, 2014 at 7:51 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Eh, it'll be alright. The flashpoint is pretty high on dielectric grease as it's mostly silicone. So is thermal grease, but it has some ceramic in it. Plug it in and let it cook for a while, it'll be fine.
  3. Oct 24, 2014 at 9:13 PM
    Cjanik
    Cjanik Senior Member
    Chase
    Vegas
    '11 4x4 Off-Road DCSB in MGM
    OME front & rear shocks, OME 886 springs, Dakar rear leaf pack, ICON UCA, Demello front bumper, BFG M/T 255/85r16
    sounds like its going to attempt to prevent the heat from transferring to the block.
    get a rag, clean it off, then use thermal grease. no harm, no foul.
  4. Nov 24, 2014 at 7:12 AM
    Pigpen
    Dan
    Northwest Montana
    It's fine. Enjoy your easy starts on cold mornings!
  5. Jan 26, 2017 at 7:55 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
  6. Jan 26, 2017 at 7:59 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I used whatever grease was supplied with mine. It was an OEM toyota block heater though. Cant remember what it came with.
