How bad did i screw up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BravesFan, Sep 30, 2010.
  1. Sep 30, 2010 at 1:03 PM
    BravesFan
    BravesFan [OP] The MOST Badass Offroad Truck
    Rob
    Brentwood, TN
    09 Super rock crawler
    So was driving down the road about 30 mph and noticed my rpms were like 2300 so i was confused, then i noticed i had put it in second (on automatic trans). So really quickly i threw it forward and it made it all the way to park. Horrific screeching sounds followed by me throwing it back into D about a second later....So I really dont think anything is bad, but im just making sure....
  2. Sep 30, 2010 at 1:04 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I didn't think the computer would let you shift into park at speed. the screech is concerning though. Any weird noises now?
  3. Sep 30, 2010 at 1:05 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    it let my 01 switch into park :( if it was pretty quick you should be okay, probably some damage but itll take the abuse.
  4. Sep 30, 2010 at 1:05 PM
    BravesFan
    Rob
    Brentwood, TN
    No it drives fine and everything so im not really worried but i was just making sure i didnt screw up the trans or anything
  5. Sep 30, 2010 at 1:06 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    well if it drives fine than I wouldn't worry.
  6. Sep 30, 2010 at 1:07 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Your gonna have to lay off the pipe my friend!!:rasta:
  7. Sep 30, 2010 at 1:08 PM
    BravesFan
    Rob
    Brentwood, TN
    I Hate You
  8. Sep 30, 2010 at 1:09 PM
    rcbs204
    :laugh:
  9. Sep 30, 2010 at 1:19 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Park your truck on the hill, put in the P and see if it rolls down or stays in place. P has lock for tranny if you shift into P while driving it may have broken off.
  10. Sep 30, 2010 at 1:20 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Your truck is now worthless. It's going to explode leaving nothing but metal dust in a puddle of transmission fluid. I'll save you the disposal fee by giving you $100 for it...:rolleyes:
    But seriously, I did almost that exact same thing back when I was in high school. Nothing ever came of it. Make sure you didn't sheer off the park pawl by parking on a slightly sloped driveway and putting it in park without the emergency brake set. As long as it holds against the slope (and maybe you pushing it downhill) you're fine. :cool:
    I wouldn't make a habit of doing that, tho. :eek:
  11. Sep 30, 2010 at 1:23 PM
    Twiget
    Twiget Proud to be Awesome
    America's Vancouver
    654, 6 Cylinders, 5 Speeds, 4 wheel drive
    Alpine Headunit, Soft Tonneau Cover, CAI
    I have to agree. I used to have an old K5 Blazer with the shifter on the tree. I was rolling at ~10mph and tried to go from drive to neutral and ended up going all the way to park. Had some horrible popping and grinding noises for about 2 seconds until the truck stopped.
    I wasnt in a good mood at the time, so I said fuck it, put it back in drive and it drove fine for awhile. About 1000 miles later it would not shift past 2nd gear and I had to have it rebuilt.
    Take the truck to AAMCO or your favorite shop and have them check the tranny out. If you did damage it, maybe you can get it fixed before it requires a full rebuild.
  12. Sep 30, 2010 at 1:26 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Thats now going to show up automatically on your car fax report.................
  13. Sep 30, 2010 at 1:52 PM
    BravesFan
    Rob
    Brentwood, TN
    Did the park on a hill test and it didn't move so i think im good
  14. Sep 30, 2010 at 2:35 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Worth repeating; Don't do that again.
  15. Sep 30, 2010 at 3:31 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    "I hope you know this will go down on your permanent record..." :D
  16. Sep 30, 2010 at 3:39 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    First problem is that you're a Braves fan...:p
  17. Sep 30, 2010 at 3:41 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    ive done this once when i was in a hurry but i only did it right before the truck stopped so it was only from like 2-5mph. and then i let one of my lady friends drive the truck :)facepalm:) and she did the exact same thing. havnt noticed any problems with the tranny so far, or the parking break in the tranny
  18. Sep 30, 2010 at 3:45 PM
    Thucker
    Thucker Well-Known Member
    Portland, OR
    2010 Mag. Gray BC LB Sport 4x4
    You probably got a little bit of metal shaving in your transmission oil pan now, but should be alright. Don't do it again.
  19. Sep 30, 2010 at 3:53 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  20. Sep 30, 2010 at 4:08 PM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    I did something similar to my Cherokee once - reverse at 70 mph. Quite the oops, I know. It was fine. Never experienced any problems for the remaining couple of years that I owned it.
