How bad is $1,632.65 to replace timing cover gasket?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fast5speed, Mar 5, 2018.
  1. Mar 5, 2018 at 9:21 AM
    fast5speed
    fast5speed [OP] Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    staaaaaaaaaaahhhhppppppppppp
    Stop publicly roasting them, they have families to take care of :rofl::rofl:
    P.S. Will post dealer name after my truck is off their lot lmao. Putting them on trial for grand larceny might not go over so well :p
    scottalot likes this.
  2. Mar 5, 2018 at 9:23 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    DOUBLLD AKA Danial he does a lot of work for the local guys here does some top notch work....Check him out just send him a PM and see what he says..
  3. Mar 5, 2018 at 9:24 AM
    IPNPULZ
    going to be fun!
    Oh hell NO!
  4. Mar 5, 2018 at 9:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It is not plastic. It just hardens with age.
  5. Mar 5, 2018 at 9:37 AM
    IPNPULZ
    going to be fun!
    Are these clowns in MD or VA?
  6. Mar 5, 2018 at 10:17 AM
    fast5speed
    Washington D.C.
    I’m ecstatic that you called them clowns.
    That’s been my go-to ‘term of endearment’ for a while now and I love it.
    The dealer is in Montgomery County, MD
  7. Mar 5, 2018 at 10:27 AM
    IPNPULZ
    going to be fun!
    Im safe I dont go there...
    thieving Fucking clowns.
  8. Mar 5, 2018 at 11:06 AM
    81shark
    81shark Well-Known Member
    do the belt yourself.
    they have to do an alignment when they do the frame. call em out on that..
    the valve cover gasket.. i'd be tempted to let them do that. they should be able to get you a deal on it, as they are tearing the truck apart. a proper swap includes pulling the engine and transmission, although some leave the engine and transmission hanging in the body.
    good luck either way
  9. Mar 5, 2018 at 11:08 AM
    81shark
    98tacoma27[QUOTED] and scottalot like this.
  10. Mar 5, 2018 at 11:15 AM
    2017toy
    2017toy My new/uses 2017 Tacoma SR
    Dan
    Decatur,Il
    2017 Toyota Tacoma SR 4x2
    stock
    I'm not a mechanic but I do know that changing a timing belt. You have to fix everything so it won't move. It will throw it out of time and ruin your engine
  11. Mar 5, 2018 at 11:17 AM
    2017toy
    Dan
    Decatur,Il
    stock
    Speaking about dealer scams My truck did not come with intermittent wipers. I was quoated $707 to but in a new motor and a new switch. All I did was pay $50 for a switch that came off a wrecked Camary . I now have multi speed wipers.
  12. Mar 5, 2018 at 11:21 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Book time (timing cover gasket) is ~13.0 hours plus parts at a likely labor rate of 120-150/hour.
    Oh, and by the book there a 106 steps from Toyota to complete the job.
    b_r_o and scottalot like this.
  13. Mar 5, 2018 at 11:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    That depends on if it is an interference engine or not. This particular engine has a chain.
  14. Mar 5, 2018 at 11:36 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  15. Mar 5, 2018 at 12:25 PM
    #35
    81shark
    wow... i did that swap as well.
  16. Mar 5, 2018 at 12:41 PM
    #36
    fast5speed
    Washington D.C.
    To clarify, [as far as I know] this quoted job is not for the timing belt. This job is for the timing cover gasket.
    As another member just posted, the 4cyl motor has a timing chain, which makes sense as I believe all Jap 4cyl motors made within the past 20 years have timing chains, with the V6 motors staying wit timing belts due to excess noise caused by having a chain go to a second bank.
  17. Mar 5, 2018 at 2:38 PM
    #37
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    I think your wrong the v-6 4.0 has a timing chain. The v-6 leaks at the area above the power steering pump right near the access panel for adjusting the chain. I don't even think it's a gasket rather its sealed with an rtv sealant.
  18. Mar 5, 2018 at 2:55 PM
    #38
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    did they use KY jell ?
    or just plain ole Vaseline ?
  19. Mar 5, 2018 at 3:13 PM
    #39
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct and correct.
  20. Mar 5, 2018 at 3:51 PM
    #40
    Beerline123
    Hey torspd, I know you know these motors like the back of your hand. I thought a read a post of yours where you talked about using a jb weld type of product and applying it to the leaking covers exterior without pulling cover off that would seal the leak. If I'm wrong I apologize but if so could you reiterate the procedure. Tia
