How bad is a 1/2" top plate spacer
Discussion in 'Suspension' started by CJH9980, Dec 10, 2009.
  1. Dec 10, 2009 at 1:05 AM
    CJH9980
    CJH9980 [OP] Well-Known Member
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    5100's, Eibach springs, Toytec AAL, Total Chaos UCA's, MetalMiller Skid
    I currently have these parts sitting on my living room floor:
    Front/Rear 5100s
    Eibach 1.6" springs
    Toytec 1/2" top plate spacers
    Toytec 2" AAL
    LR UCAs
    my original plan was to set the billys @ .85" with the eibachs and the top plate spacers, which would put me right at a 3" lift up front.
    Now I'm questioning the spacers, because everything I read about spacers is negative. Will a spacer as small as this cause me any problems such as shock breakage or ball joint wear?
  2. Dec 10, 2009 at 4:23 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When you say....1/2" top plate spacer....
    Is that the TOTAL lift amount that they advertise?
    Or
    Is that how thick the spacer is?
    If that's the total lift amount... 1/2" is fine.
    But, if the spacer is 1/2" thick in actual size...that's 1" of lift and I wouldn't recommend it.
  3. Dec 10, 2009 at 4:34 AM
    CJH9980
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    It's advertised as giving 3/4" total,
  4. Dec 10, 2009 at 6:03 AM
    Burns
    Burns Excellent Member
    NJ
    17 DCSB Off-Road
    None!
    Thats the setup I am going to be going with when I have to replace my stock shocks. You should be fine man! :thumbsup:
  5. Dec 10, 2009 at 6:07 AM
    CJH9980
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    Thanks man! It's good to hear some positive feedback. I got to reading about spacers breaking ball joints, etc..and got a little worried! I can't wait to get all this stuff installed and take some pics!
  6. Dec 10, 2009 at 6:11 AM
    Burns
    NJ
    17 DCSB Off-Road
    None!
    All the bad talk is about the 2.5 to 3.0 inch top plate spacers.
  7. Dec 11, 2009 at 12:20 AM
    CJH9980
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    Earlier today I went to autozone to grab a "free" spring compressor, but the thing looked pretty shitty. Those springs are pretty stout, and I'd hate to have the compressor break on me. I called a suspension shop and they said they'd assemble the shocks/coils for $40. I'm gonna run by there tomorrow and get em put together.
  8. Dec 11, 2009 at 9:42 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Those little top plate spacers are fine. They are not big enough to be a weak link. That's what I use to get that extra 3/4" of lift because I didn't want to pre-load the springs by setting the 5100's at 0.85". I want them as flexy as possible for trail wheeling.
  9. Dec 11, 2009 at 9:53 AM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    Why is it like that? What I mean is why would the total lift(1") be ~twice the size of the actual(1/2") spacer?
  10. Dec 11, 2009 at 10:03 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    The spacer is closer to the pivot points at the base of the control arms than the tires.
    To visualize, stick your arm straight out in front of you. Lift your arm so that your elbow rises about 1/2" from the starting point. Your hand actually raised a couple of inches though with the same move.
  11. Dec 11, 2009 at 10:05 AM
    tim920
    Tim
    Boston, MA
    Thanks! LOL that was easy to understand.
  12. Dec 11, 2009 at 10:26 AM
    gonzo6up
    gonzo6up Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    i ran a 5/8" spacer that my buddy made for me on three of my previous tacomas( 95.5/ 97/ 01 models) and never had any issues. On my 97 model i put about 90K miles on it for a total of 198K and i had to replace the CV boots. I can't really blame the spacers though since the truck had 175K miles on it when i replaced them.
  13. Dec 11, 2009 at 10:58 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Any type of lift is equally hard on CV boots. The only determining factor on wear of CV boots is the height of the lift, not the lift type. The cure to that problem is a diff drop kit.
    With that many miles though, things start needing replacement whether you took perfect care of them or not.
  14. Dec 11, 2009 at 11:48 AM
    Janster
    Jandy
    Lancaster, PA
    Thanks for explaining that. I figured someone was gonna ask about that (they always do).
  15. Dec 11, 2009 at 12:05 PM
    Its_Taco_Time
    Its_Taco_Time Well-Known Member
    Yorba Linda
    07 Tunda DC TRD Offroad
    CST spindles, Magnaflow, TRD intake
    Good description! Rep for you
  16. Dec 11, 2009 at 12:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    A diff drop doesnt really "Cure" the CV angle issue. By lowering the front of the diff 1", it is afectivly only lowering the drive shaft where it enters the diff 1/2". That 1/2" drop spread over the 13 or so inches of the front drive shafts, is only about 2* change or so. Many folks have had increased vibes due to the diff drop. Personally, I think its best left off, unless vibes are present. If the CV angle is poor, lower the amount of lift.
  17. Dec 11, 2009 at 2:55 PM
    CJH9980
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    Awesome. that makes me feel a lot better about the setup
  18. Dec 11, 2009 at 2:56 PM
    CJH9980
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    Actually, it was going to be my next question:D
  19. Dec 13, 2009 at 8:12 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Thanks for the reps.
  20. Dec 13, 2009 at 8:20 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    I find it hard to imagine dropping the diff to keep it closer to stock geometry could cause problems. Buutttt, I believe you though. I'm sure it does occasionally happen. Every truck is different.
    My personal philosophy is to keep the angles as close to stock as possible. That 2* may get an extra 10,000 miles out of those cv's. Who knows?
