How bad is it to not use the locker?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pool Runner, Sep 21, 2014.
  1. Sep 21, 2014 at 4:44 PM
    Pool Runner
    Pool Runner [OP] Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    Just curious, I've read a few threads about lockers not engaging, or something frozen up, when you need it to work. I'm going to be honest, I might use the locker once or twice ever, but would hate to find it frozen at that one time.
    I'm going to wager there are thousands of Off-Roads out there, that have never had the locker used, probably let alone put in 4WD. One of my clients which is a house wife, purchased a new Off-Road about four years ago, looks like it's never been in the dirt ever. When I asked her about the features in the truck one day, she didn't even know what I was talking about. I'm guessing her rear locker might be frozen, if she went to use it??
  2. Sep 21, 2014 at 4:50 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    The first time I really really needed it it did not want to lock. I was stuck up to my doors in mud and I was starting to freak out thankfully it eventually did. I think the previous owner never used it.
    When I've needed it after that it has been a lot easier to lock up.
  3. Sep 21, 2014 at 4:52 PM
    slodc4
    slodc4 Conceal Carry
    Steven
    Winterville, NC
    Locked 17 trd sport
    I make sure to engage mine every couple of months. I've prob put a few thousand miles on my locker.
    Sometimes it won't engage unless I creep a few inches
  4. Sep 21, 2014 at 4:53 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Yep, if you don't use it the actuator rusts up. Every day use allows moisture to build up in the actuator, lack of use it gets rusty and eventually toast. The actuator is a really a cheap little motor that cost $$$ to replace.
    From day 1 the locker is difficult to get locked in, I think the Amsoil Severe gear that I used helped. I didn't lock it nearly as often as I should have, one day I got stuck and it let me down.
    Over all... cherish its existence... the electric LSD in the Sport sucks.... I've had both.
  5. Sep 21, 2014 at 5:00 PM
    Pool Runner
    Nor Cal
    So just to clarify, should I periodically, say once a month, or once a week. Pull into a gravel lot and engage it? Or is doing it in my driveway ok?
    On my old truck '13, Fx4 Ford, it was a dial on the dash you pulled out. You could actually hear it click on/ off with the motor off. Is the one on our tucks the same idea? or does it physically have to roll forward or back?
  6. Sep 21, 2014 at 5:03 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    id say once every month... you dont have to be on gravel, just do it in your driveway. Push the button, and roll a little bit slowly (you will probably have to turn to get the axles spinning at slightly different rates) and it will pop in. Once its in, you can push the button and roll slowly again and you might need to turn again in the opposite way to unbind. boom done.
    Really you just need to move the actuator back and forth from fully engaged to disengated, actually driving with the locker in is not necessary
  7. Sep 21, 2014 at 5:10 PM
    cheeseit
    Vancouver B.C.
    3 inch toytec lift
    I heard you shouldn't engage it on pavement because sometimes the wheels shift when they lock and it bad for the locker?
  8. Sep 21, 2014 at 5:22 PM
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    If I'm not hitting the hunting trails or messing around off-road for a while I'll swing by a local service drive and pop the truck into low with the locker engaged and drive a couple of hundred yards (straight shot), engaging and disengaging the locker a couple of times. No problems so far, engages whenever I push the button.
  9. Sep 21, 2014 at 5:33 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Well fuck... This thread made me go out and check and sure enough the locker won't engage...
  10. Sep 21, 2014 at 5:37 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Yea that's what they say, but the locker is stronger than the gears in the rear end. If 4wd needs to be engaged its a no go, in 2wd slow speed won't hurt anything but your tires.
  11. Sep 21, 2014 at 5:40 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Okay, I am new too the 4X4 world. I have engaged the locker a few times but how do you know it is engaged?
  12. Sep 21, 2014 at 5:42 PM
    tacomakid96
    Phil
    Out n' about
    The light should stop blinking and normally you can hear it click when it engages
  13. Sep 21, 2014 at 5:58 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    Shit, mine has 20k on it and I have never engaged it. Not sure it ever has been either (bought it at 7k). I will do so on my road trip next week and report back.
  14. Sep 21, 2014 at 5:58 PM
    Pool Runner
    Nor Cal
    This is great advise. Just like what has been said "Use it or lose it"
  15. Sep 21, 2014 at 6:08 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    I always had to rock mine, if that doesn't work, welcome to SNAFU.
  16. Sep 21, 2014 at 6:11 PM
    bigbarlo
    bigbarlo The Church of @ODNAREM OC Chapter 80085
    Chan
    Laguna Beach
    06 AC OR PR/96 FJ80
    When I bought my truck, the guy I bought it from had never used it. First time I tried it, didn't work. I put it in reverse and it freed it. I now engage the locker once a month and it works as it should.
  17. Sep 21, 2014 at 6:13 PM
    Shwaa
    Bay Area, CA
    Just curious, did you put it in reverse while engaged? Where you in D? Or some 4x4 speed?
  18. Sep 21, 2014 at 7:53 PM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    Great title for this thread, glad I took a look. I've had mine 2 1/2 years and never used or engaged it also. I plan to check if out tomorrow and routinely engage. Read last month about checking battery fluid level, for some reason I thought it was maintenace free. It was OK but now I will keep a check on it.
  19. Sep 21, 2014 at 8:14 PM
    Pool Runner
    Nor Cal
    How does the ECM know the difference between a PreRunner and 4x4? I'm sure there are countless threads about modding or working around this, but is there a plug & play part from the PreRunner TRD/OR that can be easily swapped in to use the locker in 2wd?
    You could use the e-locker on the FX4, F-150 in 2wd or 4wd, pretty cool actually.
  20. Sep 21, 2014 at 8:47 PM
    Pool Runner
    Nor Cal
    Got it, thanks.
