How bad is it to shift from 5th to 2nd while going 50mph?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crackedmirror, May 2, 2021.
  1. May 2, 2021 at 5:42 PM
    crackedmirror
    crackedmirror [OP] Well-Known Member
    This is the first manual trans I've driven, and a few (3-5) times, I've went into 2nd by accident instead of going into 4th (mostly when slowing down to to exit the hwy via an offramp). I've heard the rear wheels skid and RPMs increase to high 5000s.
    How bad of a damage would I have caused?
  2. May 2, 2021 at 5:46 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Try not to do it again. Send it and good luck! Drive it like ya stole it!
    davidstacoma and Taco critter like this.
  3. May 2, 2021 at 5:54 PM
    1997tacomav6
    Denver
    I’ve done that a hand full of times before I changed out the shifter bushing,
    Nothing has happened as far as damage but not a good idea to keep doing it, something might break
    Gunshot-6A and Strostkovy like this.
  4. May 2, 2021 at 6:02 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  5. May 2, 2021 at 6:12 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    My dad taught me in my very first car ($800) how you can lock up the tires and stop suddenly by doing that.
    The problem is every other moving part in the vehicle is going too fast to suddenly stop. And you change the effective gear ratio very suddenly. The engine is mechanically forced to a higher RPM faster than it's naturally supposed to do so.
    Something will ultimately break if that keeps happening.
    Sterling_vH111 and tcjacado like this.
  6. May 2, 2021 at 8:41 PM
    SLAPS 65
    SLAPS 65 Dirty deeds, done dirt cheap..
    Leif
    Nor Cal east Bay Area Ca.
    2000 Tacoma 4wd ex cab 3.4 auto.. manual hub, J shift
    2.7 or 3.4?
    I don’t have much experience with 2.7 but from a quick google search it appears to be an interference engine, so mechanically over-reving it could conceivably float the valves and seriously F shit up. Bent valves and such. If 3.4 you could probably continue to do it, but dont, just don’t..
    SR-71A and TacoBike like this.
  7. May 2, 2021 at 8:46 PM
    JCH
    JCH Well-Known Member
    Justin
    Colorado
    2021 TRD Off-road
    One thing to really help avoid this is to let the shifter do the work. If you just let it center itself in neutral you’ll hit fourth perfect every time. I know that seems obvious and it definitely isn’t the fastest way to shift. If you are new to a manual though, consciously doing this makes a huge difference.
  8. May 2, 2021 at 8:50 PM
    crackedmirror
    3.4
  9. May 2, 2021 at 8:58 PM
    SLAPS 65
    Leif
    Cool, great motor, rev it to the moon, even break a timing belt, no worries. Keep up on oil changes and keep any fluid leaks under control and don’t overheat it and it’ll last nearly forever.
  10. May 2, 2021 at 10:13 PM
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    I did this several times due to an incorrect shifter bushing.
    Go to neutral. Push all of the way left. Go back to neutral. Push up towards third. On my truck that would have been fifth.
    Any time the shifter was fully to the right, going to the middle and then down or up would be second or first gear.
  11. May 2, 2021 at 10:18 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The first bill you will have is towing the Truck Home because it will not move under it`s own power any longer.
    Then you can figure out just what has failed.
    Gunshot-6A likes this.
  12. May 4, 2021 at 3:57 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Are you sure it’s running ok cuz I thought I saw a connecting rod land in my lilac bush....
  13. May 4, 2021 at 5:09 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Depends then just how it was done.
    I have no idea what gear I am in quite possible I have been in 5th gear slowed way down to make a turn into 2nd gear and never noticed.
    Then the RPM and Speed would have dropped to a safe level to pull into second gear.
  14. May 4, 2021 at 6:25 PM
    latchlock8111
    latchlock8111 Well-Known Member
    I bet your heart skipped a beat.
    wiggler likes this.
  15. May 4, 2021 at 11:53 PM
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    Toyota kept the rpm limit for the 3.4 very conservative for the stroke of the engine. For guidelines, toyota could have done high 5k rpms and been good but its a truck motor and doesnt need it. Also if you swapped to a forged bottom, rpm could go up to 7k but thats with forged sooo... Either way not great for the engine to be up there for long, just that it can but the springs are not made for it in the valvetrain.
    Key-Rei likes this.
  16. May 5, 2021 at 12:40 AM
    Yoyo-2006
    Yoyo-2006 Well-Known Member
    Steven
    Reg cab 06 5speed 4x4
    None
    Not gonna lie, I knock mine in neutral and let her roll. I’m to lazy to down shift.
    Key-Rei likes this.
  17. May 5, 2021 at 1:10 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Why even downshift in this situation? If you are just gradually slowing down just leave it in 5th until you are going a lot slower. You only need to downshift into 4th if you need to accelerate and 5th gear is too high to do that, like going up a hill or carrying a lot of weight or pulling a trailer. And using the downshift as a brake is of limited value. I'd rather just use the brakes. If you are going down a long, steep hill then it would make sense so you don't overheat the brakes.
    SLAPS 65 likes this.
  18. May 5, 2021 at 6:00 AM
    BarnBoy
    BarnBoy Well-Known Member
    96 Tacoma 2wd
    Worst I've done is barely snicked reverse once instead of 4th, and shifted into 3rd instead of 5th ramping onto the highway. Key is to use light pressure and don't force anything. The shifter will align 3rd and 4th for you, gotta get a feel for it.
  19. May 5, 2021 at 6:51 AM
    Billison_
    Billison_ Why does beer pair so well with wheeling?
    Billy
    ‘01 Ext Cab With Spension
    I changed the air freshener to a new one, one time.
    When you hear a loud pop and some grinding it means you have accessed the engines super rpms and you can now go a lot faster.
  20. May 5, 2021 at 8:26 AM
    Strostkovy
    Alex
    White 98 Tacoma
    5th to reverse is my favorite, when the transmission sings the song of its people.
