How bad is it to shift from 5th to 2nd while going 50mph?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crackedmirror, May 2, 2021.
  1. May 5, 2021 at 8:59 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If you indeed damaged something, you'd know pretty much right away. It happens, but that's why you keep your foot on the clutch.
    You're probably fine, but yea, don't do that.
    Rachelsdaddy likes this.
  2. May 5, 2021 at 9:03 AM
    Sean42
    Sean42 Well-Known Member
    As long as the RPM's stayed under the redline I would not worry about it.
  3. May 5, 2021 at 9:09 AM
    terminus
    terminus Well-Known Member
    2023 Silver TRD Offroad MT
    In high school, I blew up a Tercel doing exactly this. Pieces of engine all over the interstate. Definitely do not recommend.
    eon_blue likes this.
  4. May 5, 2021 at 9:22 AM
    eon_blue
    Azusa, CA
    I did this once in my '06 Scion tC when it was practically brand new, I was maybe 21 years old. GF wanted to hold hands while driving, so naturally I obliged and anytime I needed to shift I just guided her hand to do it on the shifter.
    Well, the inevitable happened one day and I mistakenly downshifted from 4th - 1st or 5th to 2nd, I can't remember which. It was a big jump and felt like the car was basically thrown in park. GF not impressed. Pride hurt. Haven't done that since.
    That little car lasted another 150k miles before I traded it in so I doubt you hurt anything, don't make a habit of it.
  5. May 5, 2021 at 9:24 AM
    eon_blue
    Azusa, CA
    although I'm sure it royally sucked at the time, haha
  6. May 5, 2021 at 9:26 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You need to know where your RPM range is at certain speeds. If you're doing 50 mph and want to shift into second, you better mash the shit out of the gas to rev-match before engaging the clutch. There's not a lot of RPM room up there, but there's a little, I think. I usually only WOT in third doing 70 on the highway to pass people. It's sad. Lol
  7. May 5, 2021 at 9:29 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    It's not a problem if your motor can redline at 8K RPM.
  8. May 5, 2021 at 1:29 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I feel guilty seeing mine at anything over 2500.....
    Abeyancer likes this.
  9. May 5, 2021 at 1:43 PM
    eon_blue
    Azusa, CA
    like, catholic guilt?
    0xDEADBEEF and Billison_ like this.
  10. May 5, 2021 at 2:04 PM
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    You must be through three gears before you even get through an intersection
    Billison_ likes this.
  11. May 5, 2021 at 7:21 PM
    Nick1999
    Nick1999 Well-Known Member
    Arizona
    2004 Red Tacoma S Runner
    No
    Selective gear changing means you sometimes miss out gears, for example, by changing from fifth gear to second gear. This method is called ‘selective’ or ‘block’ gear changing. Unfortunately, you did this unintentionally and in a wrong way. To do this, you need to reduce your speed from 50 mph to 30 mph, and switch from 5th to 2nd gear. When you intend to go from 5th to 4th gear and you have 50 mph then you have to put the gear lever in neutral position. The gear lever will automatically spring to the central neutral position when not in a gear (against 3rd and 4th gear). This is very useful when trying to find and select the fourth gear. Just form your new habit.
  12. May 5, 2021 at 7:29 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    I used to powershift the ‘garbage’ truck for fun…:anonymous:
  13. May 5, 2021 at 7:32 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Thats how it is on mine. 28's and 4.30 gears :laughing:
  14. May 5, 2021 at 9:20 PM
    Strostkovy
    Alex
    White 98 Tacoma
    I downshift to third at 50 all of the time. Getting bored on mountain roads will make you pretty good at shifting all over the place before turns and hills.
    MNMLST likes this.
  15. May 6, 2021 at 7:49 AM
    #35
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    While I like to "row the lever" on occasion, this is pretty spot-on. Brakes are far cheaper than gears/engines/clutches. That stated, I use a 4 - 2 shift all the time when driving in town to make turns (slowing from 35-40mph to 10-15mph, or so). Also, didn't see anyone mention it, but a 5 - 2 shift in slippery conditions could result in loss of control. Lastly, when I do a 5 - 4 shift, the lever just falls into place. To execute a 5 - 2, I would definitely feel the lever resist as the synchros spool up. Any MT vehicle I've driven, a 4 - 1 wouldn't even happen without obvious grinding or really shoving on the lever...can't say I've ever had this happen. FWIW, I only shift into 1 either from a stop or if moving <5-10mph. When moving, I typically double-clutch if I need to get into 1, as the synchros are getting a little tired on my 2003.
    OP, you may need a new shifter bushing...shouldn't be hard to feel the difference between 5 - 4 and 5 - 2.
    Strostkovy likes this.
  16. May 6, 2021 at 1:31 PM
    #36
    adams9621
    adams9621 Member
    Gregg
    1996 White Tacoma 4x4
    Means you've added a gear, without even having to drop the tranny. I've done it before accidentally, doesn't make the truck happy that's for sure. If it's only once it won't blow you up
  17. May 6, 2021 at 2:34 PM
    #37
    jbrandt
    Justin
    Unless....
    it was on purpose?
  18. May 6, 2021 at 2:37 PM
    #38
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Its an odd trick where the engine can go a lot faster while you go a lot slower :rofl:
