? How bad is it ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cmack12, Feb 28, 2010.
  1. Feb 28, 2010 at 6:19 PM
    cmack12
    cmack12 [OP] New Member
    Jackson, Ga
    05 Prerunner TRD
    I was changing my front brake pads & i took apart the caliper. I don't think i should have done that because brake fluid was leaking everywhere. So i put the brake pads on & bolted back everything. I also bled the brakes & it did not hold pressure, so the question is since I took the caliper apart, is there a repair kit or do i need a new one?:confused:
  2. Feb 28, 2010 at 6:27 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    No idea dude. good luck.
  3. Feb 28, 2010 at 6:29 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    wait--- two cmacks?? im confused...
  4. Feb 28, 2010 at 6:30 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Why I never mess with brakes........................
  5. Feb 28, 2010 at 6:35 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Welcome to tw!
  6. Feb 28, 2010 at 6:44 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    2 cmacks wtf 1 is bad enough lol???? Im not 100% but my guess would be you need to bleed again you still have air somewhere
  7. Feb 28, 2010 at 6:52 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    who is this cmack?
  8. Feb 28, 2010 at 6:55 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    they do make a rebuild kit. its a pita though.
  9. Feb 28, 2010 at 7:02 PM
    cmack12
    Jackson, Ga
    05 Prerunner TRD
    Bama Dudes always have the best responses! Thanks for help! GO DAWGS!
  10. Feb 28, 2010 at 7:03 PM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    They are around $28 from toyota. contains new o rings dust seals ring clips. the easiest way to do it is remove the caliper drain any fluid left from the bleeder screw it all the way out and remove ring clips put a 2x4 where the pads would go and blow compressed air into the caliper the pistons will push themselves out then rebuild the same way it came apart just be sure to lube up the new seals with white grease before assy any ?s just pm me
  11. Feb 28, 2010 at 7:03 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    dude. what do you mean you took apart the caliper. popped out the pistons? what? what exactly did you take apart? sounds like a good time.
  12. Feb 28, 2010 at 7:07 PM
    BeardedWeirdo
    BeardedWeirdo Junior Mint
    Texas
    2010 AC SR5 PreRunner
    Barcelona Red Pop & Lock, Tint, New Shoes, Removed Rear Headrests, Grille(in the works)
    Nice seizure inducing signature. LMAO!
  13. Feb 28, 2010 at 7:18 PM
    xmixpixx
    xmixpixx Well-Known Member
    Lancaster, PA
    05 SR5 TRD Off Road 6 spd
    I was working on my last truck and did something similar. You have split brake lines (one to the front, and one to the rear). It wouldn't be a bad idea to take it to an auto shop and have them bleed the line, and refill it. Be careful driving, but with the split brake line you will still have pressure to either the front or back (whichever you did not mess up). The last thing you want to do is think you have it fixed, and find out the wrong way that it wasn't.
  14. Feb 28, 2010 at 7:21 PM
    BravesFan
    BravesFan The MOST Badass Offroad Truck
    Rob
    Brentwood, TN
    09 Super rock crawler
  15. Feb 28, 2010 at 7:38 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    x2 :confused:
  16. Feb 28, 2010 at 9:48 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x3 :notsure:
  17. Feb 28, 2010 at 9:54 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    2015 trd offroad
    its cmack in disguise haha
