How bad is the rust on your Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Guitar1616, May 4, 2016.
  1. May 6, 2016 at 8:04 AM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Looks fine my 09 has surface rust around every weld.. the paint is shit and you can tell the metal was never prepped properly (I sandblast for a living) I'll end up doing something with it probably next summer, I'm not worried about it I've had Chevy's that you could stab a screw driver through the frame
  2. May 6, 2016 at 9:14 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    I agree that it's technically not a big deal. On that note, this is still unacceptable. You pay 30+ for a vehicle you expect the frame to be treated properly. My 14k vw golf is 200k miles strong in terrible salt weather with not a drop of rust on it. There is no excuse.
    Markcal likes this.
  3. May 6, 2016 at 9:39 AM
    Markcal
    Markcal Well-Known Member
    Amen, I know I have enough stress/worries in my life, without thinking about my trucks frame, that I paid extra for because it has the word "Toyota" on it. After years and years of the same frame rot, you would think Toyota would invest the resources to make a frame that is treated properly in the 2nd generation.
  4. May 6, 2016 at 10:11 AM
    ral-fake-scoup
    ral-fake-scoup Well-Known Member
    2014 Double Cab TRD Sport
    Rust Reformer says it's for surfaces up to 200 deg. Won't oil pans and gear boxes get hotter than 200?
  5. May 6, 2016 at 10:43 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  6. May 6, 2016 at 11:38 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I live in a heavy salt state I used FF and hose wash underneath in the winter when I can. Zero rust. I think in some peoples cases they may have had rust before they used FF. So even though they started at a later date with the FF the rust had taken hold and when those areas get washed of from road spray the frame starts rusting again. Its a never ending battle.
  7. May 6, 2016 at 1:09 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Theres a big difference though between the underside of a car and the underside of a truck. A car is completely coated with a thick rubber once the vehicle is built. There are no trucks with full frames that have that coating on the bottom. In the salt states, no trucks go without rust. Lots of domestic trucks that look like rust buckets. GM has had the issues of rusted out brakes lines on newer trucks from the same corrosion issues.
    Im not saying toyota hasn't had its issues. The frames had specific areas that would rot out from the inside out. No matter what amount of inhibitor you applied. Supposedly they addressed this issue with the frame supplier. Time will tell. I spray mine off occasionally through the winter, but by no means religiously. If its gonna rot, its gonna rot. I'll just get a new frame sooner rather than later.
  8. May 6, 2016 at 1:26 PM
    Markcal
    Is that really Mr. Rogers giving the finger or was that just someone else doing it? That looks real if it was fake though.
  9. May 6, 2016 at 1:33 PM
    moondeath
    Pa, Gardners
    https://youtu.be/Xlow12sSdmc
    Markcal[QUOTED] likes this.
  10. May 6, 2016 at 1:38 PM
    Markcal
    LOL-- I thought those were my innocent days.... I guess I was mistaken. Thanks for the reply you made my day. :hattip:
  11. May 6, 2016 at 4:32 PM
    peiscooter
    peiscooter Well-Known Member
    Prince Edward Island
    2021 TRD Sport
    I personally think keeping these vehicles in a heated garage speeds up this problem. I almost bought a 09 until i put it up on a hoist and it was ungodly the amount of rust on otherwise an immaculate truck - owner couldn't understand it, said he always kept it in a heated garage
    Markcal likes this.
  12. May 6, 2016 at 5:02 PM
    moondeath
    Pa, Gardners
    No way. Keeps it out of the elements. Mines always been garaged.
  13. May 6, 2016 at 5:06 PM
    moondeath
    Pa, Gardners
    Corrosion requires moisture. Thats why vehicles in the desert states last forever.
  14. May 6, 2016 at 5:39 PM
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
  15. May 8, 2016 at 6:58 AM
    #35
    qwikz74
    qwikz74 Member
    Ontario,Canada
    2015 Tacoma TRD Sport 4x4 DCAB
    Belive it or not,people that garage there cars esp in areas that get lots of snow and salted roads will out rust cars that never see the inside of a garage. I live in Ontario,lots snow with fluctuating temps in winter and LOTS of brine on the roads,that stuff is 10x worse then rock salt.
    I have never had an issue with rust like some members on this forum have. I dont garage my vehicles ever,dont rust coat them and wash them maybe once or twice in winter. The moisture is whats causing your rust issue likely from being in the garage most of the time.Either park it outside or drive it more. Other then your leaf springs(a bit rusty imo) and the exhaust(most likely lots of short trips),everything looks normal.Ever see the under carridge of a domestic truck after 2 yrs??
  16. May 8, 2016 at 10:18 AM
    #36
    TYetti
    Mat
    They're usually rusted to shit. Although my f350 work trucks frame looks mint af considering it's an 08 with 450k km on it... I should also metion I wheel the crap out of my truck... Ive done touch ups here and there but rocks will be rocks lol...
  17. May 8, 2016 at 1:45 PM
    #37
    moondeath
    Pa, Gardners
    I garage mine every day, and live in pa. Truck is covered in salt and deicer for a good few months of the year. No much rust on mine at all.
