How bad is this repair going to be?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WildcaTaco, Aug 18, 2009.
  1. Aug 18, 2009 at 8:10 AM
    WildcaTaco
    WildcaTaco [OP] Well-Known Member
    06 Access Cab V6 TRD Off-Road PreRunner
    Removed Secondary Air Filter
    Ok so I was out camping in the desert and wanted to move my truck closer in to the campsite and hit a rock. I was curious if this repair is something I can do myself (note I am not overly gifted with mechanical skills but always will to try and have someone who can help me that is pretty sharp). You can see what is damaged in the pictures. The metal housing is completely jacked and will need to be replaced, the plastic housing for power hook up is pretty well jacked up as well. Does the the entire housing need to be replaced? It looked liked it connected further forwards in the truck so I'm thinking that is all 1 part? Also anyone know where I can find a cheap set of OEM rear prerunner mudflaps the left side was ripped off.
    If anyone could give me the part #s for all the damaged parts that would be awesome! Also is anyone know how to get a copy of the Tacoma service manual legally (if by umm alternative methods you can just send a me a PM so as not to get this thread deleted)?
    Thanks for any help you can give me.
    I posted this over at TN too so if you responded there, no worries =)
  2. Aug 18, 2009 at 8:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If the socket is not damaged, remove the broken mount, and mount the socket in the bed or under the bumper to keep it free from happening again.
  3. Aug 18, 2009 at 8:53 AM
    WildcaTaco
    the socket is jakced up and will need to be replaced sadly.
  4. Aug 18, 2009 at 9:06 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Warrenty, it mutilated itself no impact occured.
    I dunno, I'd probably see if you can find one on the cheap at a junkyard from a head on or something... gotta be cheaper than the stealership, and it's just a plug so, :shrug:
  5. Aug 18, 2009 at 9:23 AM
    djs05tacoma
    djs05tacoma Well-Known Member
    Martinez, CA
    05 Double Cab TRD offroad 4x4
    3" OME Lift, 285's
    you can buy the plug at almost any autoparts store for $15-$20 and then just move it to the bumper, and never worry about it again.
  6. Aug 18, 2009 at 11:41 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    meh.. who uses electric breaks anyway.. i say F it.
  7. Aug 18, 2009 at 11:52 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Cheap. Buy the parts and fix yourself.
  8. Aug 18, 2009 at 11:55 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Yup. saw one on a tundra in a junkyard a month or so ago. I say find a used one somewheres
