How bad is this rust?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thehesher, Feb 11, 2020.
  1. Feb 11, 2020 at 4:21 PM
    thehesher
    thehesher [OP] Well-Known Member
    delete
  2. Feb 11, 2020 at 4:24 PM
    doorsidedown
    doorsidedown Well-Known Member
    looks like all surface rust to me, that’s not bad.
    If you want to take the time to restore it, wire brush, fresh paint and then fluid film it twice a year and you’ll be good.
  3. Feb 11, 2020 at 4:31 PM
    thehesher
    What about the parts that I cannot get a brush into or paint? Such as small crevices or parts directly touching rubber and whatnot? Won't those just continue to rust until they're eaten away?
  4. Feb 11, 2020 at 4:41 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Doesn’t look bad . Clean it and hit it with rust prevention every year . Fluid Film or Krown
    DG92071 and thehesher[OP] like this.
  5. Feb 11, 2020 at 4:42 PM
    lynyrd3
    Bill
    Welcome to TW :hattip:
  6. Feb 11, 2020 at 4:51 PM
    thehesher
    Thanks!
    DG92071 and lynyrd3[QUOTED] like this.
  7. Feb 11, 2020 at 4:57 PM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    I really wish my 2013 4runner was that clean haha. Even with regular scraping, brushing and fluid film applications, Pa salt sucks!
    lynyrd3 likes this.
  8. Feb 11, 2020 at 7:06 PM
    Chito346
    Chito346 Well-Known Member
    Ruben
    Los Fresnos, TX
    LA YOTONA - 2017 TRD OFF-ROAD
    Eibach shocks, 888 OME coils, SPC Light Racing UCAs, True North fabrication hybrid bumper, Bilstein 5125s, Icon RXT leaf springs, MBRP exhaust, Level8 MK6, Nitto Ridge Grapplers, Diode Dynamics lighting, Martin Off-road roof rack, BAMF bolt on slider w/kick out, Lil B’s bed stiffeners, RCI bed rack, Outgear Solutions rear bumper, Power Thirst tune.
    Doesn’t look bad
    DG92071 likes this.
  9. Feb 12, 2020 at 5:05 AM
    Kevinmang
    Kevinmang Well-Known Member
    Kevin
    Virginia Beach
    Black 2008 TRD Sport DCSB 4x4
    OME 885's, HD Dakars, 16" FN wheels, 265/75/16 Wildpeaks, KBVOODOO Full bed Rack, CVT Mt. Shasta RTT
    doesnt look bad, but Id really inspect the welds and areas right under the door area. mine didnt look bad until i went under and really started to clean it. and eventually put a needle gun to it. previous owner looked to have painted over the rust. I eventually was able to get the frame replaced by toyota under the recall.
  10. Feb 12, 2020 at 5:12 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    I sue a paint on product that goes on milky color and turns shiny black as it coverts the rust, I never sand anything, just do a hard wipe to clean it with a rag, paint on the converter, and repeat if necessary before my annual Krown treatment. It reallt has done a great job limiting the rusting, despite the WNY salted roads. There is no magic bullet, per say, as salt is nasty and they keep throwing it. You have to do the same and treat it annually.
    MTopp likes this.
  11. Feb 12, 2020 at 5:25 AM
    Kevinmang
    Kevin
    Virginia Beach
    also, POR15 is great for rust treatment and prevention, along with fluidfilm for upkeep. i'd recommend wire brushing, and using the POR15 cleaner and prep spray with the kit, and coat it with the POR15.
  12. Feb 12, 2020 at 10:48 AM
    Labwagn
    Labwagn Active Member
    My suggestion is to power wash the undercarriage. Let it thoroughly dry. And then apply POR15.
  13. Feb 12, 2020 at 11:03 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I agree w the surface rust assessment. But get a ball peen hammer and tap around especially those creavasy areas you ask about. You’ll get a better understanding of the condition.
    Where was it first put into service?
    Toyota has a frame serving campaign covering the Tacoma for certain states. If it’s from one of those states, you have to do it in order to be eligible down the road should there be any sort of replacement campaign. Alternatively, you can take it on yourself as has been suggested.
    Good luck!
    Kevinmang likes this.
  14. Feb 12, 2020 at 11:42 AM
    TacoBreaker
    TacoBreaker Well-Known Member
    08 Rust Bucket
    OME 885, 5100s
    If you find anything with that ball peen keep your mouth shut that you where ever even under the truck. Just call playing really dumb. But you’re not going to find anything on that worth worrying about.
    PzTank likes this.
  15. Feb 12, 2020 at 1:58 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Where is the rust?
