How bad would it be if...
Discussion in 'Wheels & Tires' started by DanGer, Apr 7, 2009.
  1. Apr 7, 2009 at 7:33 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    ...I didn't reinstall TPSM in my new wheels. I regularly check my tire pressure and find the pressure sensors to be completely useless and they do not display an actual tire pressure. Is there a problem with this I should be aware of?
  2. Apr 7, 2009 at 7:41 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    No problem other than the annoying TPMS light you will have on the dash.
  3. Apr 7, 2009 at 7:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Just get a small wheel barrow wheel and tire, throw the sensors in the tire, and air it up to 30 psi and keep it in your bed. Light wont go off. :)
  4. Apr 7, 2009 at 7:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ^^^yep......only the annoying light. you can make a pvc capsule for the sensors.......keep it in your truck to keep the light out, if you wanted to. just gotta have a 6 inch section of pvc, 3 end caps, some pipe dope and a valve stem. put the sensors inside and air it up....voila...light out!
  5. Apr 7, 2009 at 7:47 PM
    DanGer
    well i'm going to be taking my dash apart to resolder som LEDs to change the gauge color from the vomit orange, can't I just disconnect it?
  6. Apr 7, 2009 at 7:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Maybe. Or just poke the LED with a soldering iron. :D
  7. Apr 7, 2009 at 7:49 PM
    DanGer
    haha or unsolder it altogether if i cant disconnect a wire
  8. Apr 7, 2009 at 7:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you may be able to just pull out the led bulb and be done with it....not really sure.
  9. Apr 7, 2009 at 7:54 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Cops might think you have a pipe bomb taped to your frame
  10. Apr 7, 2009 at 7:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    maybe!:D keep it behind the seat, you're good to go.
  11. Apr 9, 2009 at 9:55 AM
    Evans381
    Evans381 Well-Known Member
    Ty
    Rome, Georgia
    06 PreRunner
    Toytec ultimate coilovers. 5% Window tint. 40% windshield. Kenwood DDX372BT Monitor. JL Audio 12w0v3 subwoofer set in ported Q-Bomb box. 20" Gear Alloy Recoil wheels wrapped in Cooper Zeon LTZ tires
    IDK what to do but I would advise that you do something to keep that dang dash light off! My dad did not get the sensors out of my stock wheels b4 he sold them so I am currently living with the only problem with my truck.... That dang light.
  12. Apr 9, 2009 at 10:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Pipe bombing from a car isn't a common technique...I wouldn't worry about it TOO much. There ARE lots of other places to hide those tho...
  13. Apr 9, 2009 at 4:57 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    haha i doubt it!
  14. Apr 9, 2009 at 5:28 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    If it was me, I would go with Will's idea. Make a small PVC capsule, with a valve steam. Cap one end using some good pipe glue. Then throw in your tpms sensors, and cap the top with your valve steam attached. Air your pipe bomb up to 32 psi or so, and then put it in the storage compartment under your rear seats. Be really careful not to over inflate the capsule or your could possibly blow the top of.
    IMO the tpms sensors are worthless. Anyone with half a brain will know immediately if their tires become dangerously low. If the tires are moderately low, this can easily be determined by simply taking a look around the truck, which should be done regularly regardless. On the other hand, I had two of my tpms sensors damaged by a bone head tire guy about a year ago, and the light would drive me nuts for about 6 months. Now I hardly ever notice it, but still would much rather it not be there.
  15. Apr 9, 2009 at 5:32 PM
    DanGer
    Well like i said I am going into the dash BEFORE I put my new wheels on so I think I will just unsolder the led :)
  16. Apr 9, 2009 at 5:37 PM
    SC4333
    Grant
    FL
    That sure would work, just be sure to use a desoldering tool. You do not want solder to fall on any of the circuits.
    Just curious, are you changing out the amber leds for a different color, or do you have some other kind of project going on in the dash?
  17. Apr 9, 2009 at 5:39 PM
    Sinister
    Sinister Well-Known Member
    Vegas
    11 Super White TRD Off-Road
    WeatherTech Liners, ICON Stage 3 front and back, ICON UCAs, ICON AAL
    New guy question here.
    Can't you just reset the sensor when the new tires are on? I thought I read something about that button under the steering column. Or is it just set for standard tire pressure?
    Converted from an 02 F150 to an 09 Tacoma.. Can't believe I didnt do it sooner...
  18. Apr 9, 2009 at 5:46 PM
    SC4333
    Grant
    FL
    You can if the new wheels have the same tpms sensors. I am not sure of the exact situation degerm is in, but I would assume he went from steel wheels to alloy wheels. The sensor neck angle is different from steel to alloy wheels, which will in turn require new tpms sensors. Although, people have been known to rig the sensors where they will work by flipping them upside down. If new sensors are installed, then you will have to have the dealer reprogram your tpms module.
  19. Apr 9, 2009 at 5:55 PM
    DanGer
    Close! I am going from the stock steel to the stock FJ alloys. What is a desoldiering tool exactly? I am switching out the Amber for white or blue. I was fine with it but since someone said they hated their I have slowly grown to the point where I cant stand it haha
  20. Apr 9, 2009 at 6:02 PM
    Sinister
    Vegas
