how big a tire can I run?
Discussion in '1st Gen. Tacomas (1995-2004)' started by gunnar#1, Feb 21, 2020.
  1. Feb 21, 2020 at 2:34 PM
    gunnar#1
    gunnar#1 [OP] Well-Known Member
    sam
    Mesa
    2001 Tacoma 4x4
    Silver xtra-cab,old man emu 3 inch lift, 2016 wheels, arb front bumper, receiver hitch, Automatic transmission cooler, tundra front calipers, new frame.
    I know this info is on here SOMEWHERE but I cant find it.
    I have the 2 inch old man emu lift kit and 2014 trd aluminum wheels and I am due for tires I was running 265/75/16's and the Copper AT didn't rub in there front the K)#'s same size DID rub the UCA a tiny little bit at full lock. I would like some more height without more work! I will get 265/75/16' again I was just wondering in anyone has advice on something else that might be taller an maybe narrower. I know the 255/85/16 are narrower but I am under the impression they are the same height as the 265/75/16's.
  2. Feb 21, 2020 at 2:59 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    This tool has been a great resource to me in comparing tire and wheel size combinations 'n such
  3. Feb 21, 2020 at 3:14 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    the 255's is a 33" tire, the 265/75 is a 32.
    Some guys are running a 235/85r16
    But if you insist on running the 2nd gen wheels, you'll likely need wheel spacers.
    Just do a search for 2nd gen wheels on a 1st gen, or something to that effect. Lots of people do it.
    Kwikvette likes this.
  4. Feb 21, 2020 at 3:18 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
  5. Feb 21, 2020 at 3:22 PM
    jbrandt
    Justin
    If this isn't the title page of the tires/wheels sub-forum, it should be.
    Hobbs[QUOTED] and Kwikvette like this.
  6. Feb 21, 2020 at 3:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :rofl::rofl::rofl:
    Hobbs[QUOTED] likes this.
  7. Feb 21, 2020 at 3:27 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    255/85/r16
    slander likes this.
  8. Feb 21, 2020 at 3:33 PM
    Wulf
    rock raisin
    If rubbing the UCA is the issue you could add a spacer. I'm running 1.5" spacers with 12.5" wide tires on 2010 4 runner wheels so they don't rub the UCA.
  9. Feb 21, 2020 at 4:25 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Here's a good overview of what comes into play with various wheel/tire combos on a 1st gen. Take a read through and by all means ask questions!
    What size tires fit my (lifted) Tacoma?
  10. Feb 21, 2020 at 8:13 PM
    gunnar#1
    sam
    Mesa
    2001 Tacoma 4x4
    does the 2nd gen wheel have a different offset that the 1st gen?
  11. Feb 21, 2020 at 8:33 PM
    jbrandt
    Justin
    yes.
    They are completely different trucks and share only the name, and the 6 on 5.5 bolt pattern.
