how big can you go on 16"?
Discussion in 'Wheels & Tires' started by george2pak, Mar 1, 2010.
  1. Mar 1, 2010 at 3:57 PM
    george2pak
    george2pak [OP] Well-Known Member
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    Brute Force Fab front& rear bumper with winch, sliders, skid plates by Relentless, tires 285/75/16" , wheels by SCS , CB Stryker SR497 etc
    I bought new tires 285/75/16 on my standard 16" wheels, and i need new rims because my tires are rubbing againts my UCA. I'm thinking since I'm geting new rims ,why not get bigger tires? my question is: What's the bigest tire you can put on 16" rim?
  2. Mar 1, 2010 at 5:28 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    i wouldnt go any bigger than the 33's you got.
  3. Mar 1, 2010 at 5:30 PM
    Carone
    Carone Well-Known Member
    NOR CAL
    LOOK HERE!!! 02 TRD xtra cab v6 4x4 white
    Look at my Build
    diameter is not the issue width is
    to run a 285 you need a 7.5 inch wide wheel a minimum
    most people run 8s
  4. Mar 1, 2010 at 5:39 PM
    TacoSupreem
    Hayden
    Kentucky
    your stock trd off road wheels are 8 inches wide.
  5. Mar 1, 2010 at 5:41 PM
    TacoSupreem
    Hayden
    Kentucky
    i've seen 34's but i wouldnt do it
  6. Mar 1, 2010 at 5:46 PM
    Carone
    NOR CAL
    Look at my Build
    WIDTH IS THE ISSUSE they wouldn't make 37x12.5x15 if they didnt work on a 15
    My guess is the BS is wrong for those tires, dont most 2nd gens run 4" BSing
  7. Mar 1, 2010 at 5:51 PM
    TacoSupreem
    Hayden
    Kentucky
    12.5 is about as wide as you should go
  8. Mar 1, 2010 at 5:52 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    you could go 255/85/16 theyre a little bigger then a 33'' tire and a little over 10'' wide, or stick with 285/75/16 theyre shorter but wider. either way i wouldnt go no bigger then that. Do you have a lift?
  9. Mar 1, 2010 at 5:59 PM
    george2pak
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    My consern is on 16's. not necesery on my tacoma. in general..
  10. Mar 1, 2010 at 6:02 PM
    george2pak
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    Yes! I got a 3" lift. I wanna find out what's the biggest tire that you can put on 16" rim. Not neceserly on tacoma
  11. Mar 1, 2010 at 6:09 PM
    TacoSupreem
    Hayden
    Kentucky
    shit? i dont know?
  12. Mar 1, 2010 at 6:17 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    I have different rims then the stock ones and I'm going to put on km2 35s gonna see if they fit for sure soon i guess we will see
  13. Mar 1, 2010 at 7:28 PM
    george2pak
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    do they make the tires 315 wide on 16"? how tall? 315x ? x16
  14. Mar 1, 2010 at 8:02 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    315/75/16
  15. Mar 1, 2010 at 9:38 PM
    davidwitregtaco
    davidwitregtaco Member
    dave
    seattle
    08 5 lug tacoma
    can ne 1 help me out as well i have the 15" stock wheels and the width is 7 -7.5 was wondering if i could put a 32x12.50 tire on i have a 3" lift please help want to order them tommorrow
  16. Mar 12, 2010 at 3:35 PM
    george2pak
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    thank you everybody for the help. I will look to buy a nice wheel and see if i can fit 315x75x16". I think that will look sick on my tacoma.
  17. Mar 12, 2010 at 3:37 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    It won't fit without some major trimming/chopping.
  18. Mar 12, 2010 at 3:39 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    exactly...they make 15" wide tires, but u need a rim wide enough to run it
    IIRC, they are 7.5" wide
    better have a 6" lift or a 3" w/ chopping the body mount and lots of trimming of plastic
  19. Mar 12, 2010 at 3:42 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    They're only 7" wide.
  20. Mar 12, 2010 at 3:44 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
