How Big of a coffee pot can I power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glamis, May 3, 2013.
  1. May 3, 2013 at 7:44 AM
    Glamis
    Glamis [OP] date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    I'm looking to power a coffee pot / maker off my in bed power. I had a 12V one for years. It will not keep up with my now wife's and I's coffee needs.
    How big can I go or what is one that work best for you? My home coffee takes to much power.
  2. May 3, 2013 at 7:52 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    can't be done with AC, even the smallest coffee makers draw >600 watts.
    stick with the 12v models out there
    you'd need to use an aftermarket inverter that has a minimum of 650 watts
    and more likely 1000 watts...hell most one cup makers use 1450 watts...
    better get a small gas stove to boil water and use a gravity coffee maker
    the power in the bed is best to charge batteries or power laptops, music equipment, air bed inflators...
    but for devices that heat things, they usually draw too much power
  3. May 3, 2013 at 7:58 AM
    McTrauma
    McTrauma Well-Known Member
    Daniel
    Riverside, CA
    08 DC TRD 4X4
    The bed outlet (I'm assuming that this i how you want to power the coffee pot) is rated at 400 Watts. Since you will be running AC power at approx. 120V, that gives you 3.33 amps to play with (400w/120v). So, you can power any coffee pot that draws less than 400w AND under 3.33 amps.
    *this is assuming that nothing else is drawing power, and that I did the math correctly. :rolleyes:
  4. May 3, 2013 at 8:12 AM
    Glamis
    Thanks for the info. Looks like we may just have to get a Honda 2000 and be done with it. I'll have to tell her she can have coffee camping or that new AR she has been asking for. We have a stove top one we both are not fans of it.
  5. May 3, 2013 at 8:45 AM
    oldstick
    oldstick Medicare Member
    GA
    I agree, If it's mainly just for coffee, I would just get a standard percolator pot and a two burner Coleman propane stove that uses the portable gas bottles from Walmart. Bring a couple pans then you can cook other stuff too.
    Not sure if you will be camping near others, but around here, the folks that are purposely camping in the quieter areas with no electric hookups tend to get perturbed when someone cranks up a Honda nearby.
  6. May 3, 2013 at 8:46 AM
    Glamis
    If I got the EU2000i it would be for more then just coffee. We have just been putting it off. The in bed power has worked grate for most of are small things that need power. I would like to bring my air compressor and power some lights. We have ATVs and side x side so it just may be time to bust out the cash and get one. My box trailer has 30amp beakers, with wall out plugs and lights. I'm still going to look for something that will work off the bed power. We try to camp on the cheap so we can go more.
  7. May 3, 2013 at 9:01 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
  8. May 3, 2013 at 9:18 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    You can run a bigger pot, it just takes a year and a day. Before I knew the in's and out's of my truck I had entered into a surf fishing tournament. Bought a $10 coffee pot looking to make coffee on the beach never once thinking about watts or amps, plugged it in, and made coffee a hour later. Turned out to be 1000 or 1200 watt pot. It did make coffee though, hot coffee, not the hottest, but it worked. If you have a coffee pot already just try it in your free time.
  9. May 3, 2013 at 10:26 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    If you're camping... why not just use freeze dried instant coffee? Add hot water and your good to go.
  10. May 3, 2013 at 10:39 AM
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    You can always calculate the watts an appliance will use by multiplying the amps x volts.
    I don't drink coffee but have camped and seen many different types. Try a french press or old fashioned percolator you heat over as stove.
  11. May 3, 2013 at 10:44 AM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    +1 here for the percolator- the coffe actually tastes better if done right ;)
  12. May 5, 2013 at 12:25 AM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    x2!
    JETBOIL is one of the first things I pack when I go camping/backpacking. Even When I'm in the field with my unit haha. not sure how 'milspec' it is, but it works GREAT and Quickly. You can even buy a coffee press for it.
  13. May 5, 2013 at 2:27 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Uh, That is not coffee.
    Kevinpd325 likes this.
  14. May 5, 2013 at 3:59 AM
    Del Scorcho
    Del Scorcho O-------l
    Eagle, ID
    DCLB 6 banger, 4X and Super Charged
    Magnuson Supercharger, 2.85 Stealth Pulley, TRD Baja Suspension, Walbro Fuel pump, Icon add a leaf, Method 701s
    I just use an old Coleman white gas stove and a percolator. That thing can even make folgers taste good.
    I thought about running a coffee maker off bed power, but I just didn't want my truck to sit and idle all that time.
    While on the topic of plugging things in... I did find you can make a (many) pretty mean margarita with one of these.
    The trick is not to concern others as you stumble over to your truck, keys in hand, and go fire it up... Honest occifer, I'm just making another! You want one??
  15. May 7, 2013 at 1:29 PM
    Glamis
    well after some testing with this coffee pot. I can make coffee. I get about 5mins of run time then the converter shuts down. This coffee pot must be right on the line for power draw. Now That I have a base line Ill go from here.
  16. May 7, 2013 at 4:51 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I have one like that it draws 1024 watts according to the label on the bottom. keep it up and you'll have a smoked converter. Boil water with gas then use a French press.
  17. May 7, 2013 at 6:05 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    that's funny you got it to work. . i have a little 4 cup one i tried once and it tripped almost as soon as i hit brew.
    i just keep an REI french press mug and some vacuum sealed grounds in my truck. i'll obviously have a cooking pot if im camping.
    if i have hot water, i have coffee. . . really convenient.
  18. May 7, 2013 at 8:56 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    I have the JetBoil system and I love it. I think that it's something easier than trying to find a coffee maker that may work. If you're camping why don't you boil water over the camp fire and use that, simple right?
  19. May 8, 2013 at 1:47 PM
    Glamis
    We never start a fire in the A.m. Are main goal of the day in ridding in the sand duns. I start the truck most mornings to keep the trailer battery up. Was hopping to just find a coffee pot to go with the morning start. The trailer has only one battery and it runs a fan, Cell phones, two lights all night. "one strobe on my flag pole and one porch light" So by sunup it has been worked hard. I'll just keep looking.
  20. May 8, 2013 at 3:22 PM
    Crom
    Nick
    San Diego, CA
    Millions
    x2 on the jetboil, or other stove based propane source. Extremely efficient and supremely portable. :)
