How big of a deal is tire rub?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vengar613, Aug 8, 2018.
  1. Sep 25, 2019 at 11:01 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    If the OP is doing that in his 2018 Tacoma, tire rub will be the least of his worries :eek:
  2. Sep 29, 2019 at 7:57 AM
    Trucknorris
    Trucknorris Well-Known Member
    2017 sr5 double cab 4x4
    Several
    Rubbing is never good, but for the most part you should be ok with that wheel set up take a heat gun to the wheel wells and it should fix it if you do
  3. Sep 29, 2019 at 8:12 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    It seems pretty common sense. I'd just put on what I like and see where it's rubbing. Flaps, plastic or cab just start trimming. Or just drive it and see if rubber or rub wins.
  4. Sep 29, 2019 at 8:23 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    My 2nd gen had 265/75s that rubbed when I went over driveways when turning hard. I barely noticed it and was used to it. Wife would ride and get startled each time it happened. Friends understood, but it was super embarrassing taking co-workers anywhere to business functions. More weight in the cab = more rubbing. I seriously got so annoyed with it. Liked the look, but it was exhausting explaining why it sounded like that each time I took people places.
    Trucknorris likes this.
  5. Sep 29, 2019 at 8:24 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    If it aint rubbing , ladies wont give you loving.
  6. Sep 29, 2019 at 8:37 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    If you are rubbing because you bombed into your driveway or hit a speed bump at the mall then sure it may not be a big deal other than maybe your ego because your truck is making a wierd sound and it looks like you dont know what youre doing.
    However, tire rub can mean more things on a trail, but ultimately depends on how much and how much you care. Tire rub means theres an external limit preventing full wheel travel or articulation which will make things much harder for you on a trail. Your tires can also easily grab mud flaps and the innner fender liner and rip all of those things.
    It just depends, tire rub is never good but if you can keep it to a minimum its not a complete deal breaker.
    For me its more important to understand when/how you have tire rub and being aware of it.
    From a TW perspective I think its important to at least make people aware of it and leave it up to them whether its something they can live with or not
    Navigator1 likes this.
