How big of a jack do you need to install a lift?
Discussion in 'Suspension' started by GEORGE STRAIT, Jun 13, 2014.
  1. Jun 13, 2014 at 10:07 AM
    GEORGE STRAIT
    GEORGE STRAIT [OP] (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    I'm a noob. Is 13 3/4" enough? Can a hi-lift jack work?
  2. Jun 13, 2014 at 10:10 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Hi-lift jacks are for recovery uses ONLY. Not to be used for maintenance.
    Mine lift was done in a shop with a lift.
  3. Jun 13, 2014 at 10:13 AM
    scocar
    scocar hypotenoper
    I dont' think 13 3/4 is enough. You want to be around 20 I think.
    It depends on the specific of your truck and the lift you want to install.
    Hi jack not recommended.
    You should do well with a pair of 6-ton jack stands for the front frame rails and a pair of 3-ton jack stands for the rear axle. Use a floor jack
    Look in your manual for lift points. Should be rear diff pumpkin and near your front cross members.
    You need enough height to have you truck in the air with your new left at full droop and still have the tires off the ground.
  4. Jun 13, 2014 at 10:13 AM
    Manwithoutaplan
    ID
    13 3/4 is kinda of short but if you have a block of wood that will help. I would not Rely on a high lift they are very finicky.
  5. Jun 13, 2014 at 10:16 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I used 2 jacks and 2 jack stands. The jacks weren't overly tall but I only used them to get the frame on the jack stands and then to put under the axle so I could raise and lower it with the jacks. Use blocks of wood if your jack isn't tall enough to reach the frame but don't get under the truck until it's up on stands.
  6. Jun 13, 2014 at 10:49 AM
    scocar
    scocar hypotenoper
    For reference on a 1st gen:
  7. Jun 14, 2014 at 11:57 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This
