how big of a lift before diff. drop req.?
Discussion in 'Suspension' started by smileys03taco, Sep 22, 2009.
  1. Sep 22, 2009 at 7:26 AM
    smileys03taco
    smileys03taco [OP] Member
    ky
    03 Tacoma Ext. Cab 4x4
    Custom Bull Bar, XD Rims, Flowmaster, K&N FILTER, 3 M3 Subs, 2400 Mojo Amp, ECT.
    How big of a lift can you put on the 01-04 taco 4x4 before a diff. drop is required? or is it even worth putting the drop on? I've heard both ways
  2. Sep 22, 2009 at 7:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its hit or miss on the diff drop. The diff drop only changes your CV angle maybe 2*. In many cases, it causes more harm than good. Better off lifting first, then seeing if you have vibes. 3" is the max without going long travel, or a drop bracket lift.
  3. Sep 22, 2009 at 7:32 AM
    smileys03taco
    ky
    I'm planning on maybe 2 in the front and leaving the rear alone more or less just trying to level things out
  4. Sep 22, 2009 at 8:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should be just fine with no diff drop. With 2" alignment should be easilly gotten into spec.
