How big of a spare tire can i fit under the truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 17tacosport, Jan 5, 2017.
  1. Jan 24, 2018 at 5:13 PM
    scocar
    scocar hypotenoper
    Your assumption is mathematical, not practical. If you buy larger aftermarket tires and get stuck in the middle of fucking nowhere with a stock spare and have to get home alone over difficult conditions (that may well shred the OEM tire), and then drive on a freeway for any distance to find a shop, that's not a lot of fun and not safe or good for you or your truck. Not so much giving a damn about upfront mileage or cost.
    And what if I don't rotate that 5th in and end up at the point I need to buy tires and decide to change brand, or more importantly, size, and then I have to deal with selling a fifth new tire that is no longer useful to me? That's another PITA.
  2. Jan 24, 2018 at 5:36 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Most people pick a size and stay with it. My assumptions up front is for a regular owner, like most of us. They won't change size, they will buy the same size next time, they will rotate, etc.
    Sure, I can give you a situation where you need to buy eight tires but is that normal? Nope. Just like with your example. Who upsizes tires? Not many people. Who goes out in the middle of nowhere? Not many. Who that does go out in the middle of nowhere gets a flat? Not many. Pretty sure my assumptions cover way more people than your special scenario.
    Have a great night bro.
  3. Jan 24, 2018 at 5:49 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    BFG recommends a 5 tire rotation, but for those of us who have only 4 stock alloys with TPMS sensors and a steel spare rim, that 20% overall treadwear saved will not pay off the rotations and balancing. So, yeah- I’m a 4 tire rotator. In fact, so much so that I scribbed 4 small letters into my alloys next to the valve stem “a, b, c and d” to keep track of the rotation patterns, as I’ve been following this one on four different Toyota trucks with BFG’s over the last 22 years with great tire wear results:
    Big tall dave, splitbolt and hiPSI like this.
  4. Jan 24, 2018 at 9:11 PM
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    Pic of how you cut your muffler? Planning on this his weekend.
  5. Jan 24, 2018 at 10:05 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Same pattern I use.
    If you go by the owner's manual, the tires will have heel-toe wear.
  6. Jan 25, 2018 at 6:20 AM
    MrMccrackin
    MrMccrackin Well-Known Member
    Gilbert, AZ
    2004 TRDOR PreRunner, 2017 MGM TRDOR 4x4
    I was wondering if the spare had TPMS or not just the other day!
    hiPSI[QUOTED] likes this.
  7. Jan 25, 2018 at 6:23 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Haha your "assumption" of people not up sizing tires response in a thread called "How big of a spare tire can I fit in the under the truck" is invalid and nulled voided. Your "assumption" also takes into account 10k rotation when toyota recommends 5k rotations which only leaves you 5k left on a single $200/50k tire with a remaining $20 value. Your "assumptions" and calculations can not calculate true wear evenly across all 5 tires therefore that actual 10% left tread is minuscule when it comes to $ real world situation. Also your "assumption" doesn't account for an air tired or even cover dry rot tire that has to be replaces anyways with no wear costing even more. At this point why even carry a spare tire... when no one goes in the middle of nowhere?
    I run a 285/75/16 with an exhaust chop over axle and hammered back support.
    RSOTACO, davidstacoma, Mike O and 4 others like this.
  8. Jan 25, 2018 at 6:25 AM
    browndirtcowboy
    browndirtcowboy Well-Known Member
    Manteca
    All I had to do was push the exhaust about 1/2 inch toward the passenger side. There is quite a bit of movement on the exhaust thanks to the rubber bushings on the hangers.
  9. Jan 25, 2018 at 6:58 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Haha I love how people try to justify passionate decisions instead of using logic.
    Michelin recommends replacing tires every 10 years. Industry standard recommends every 6 years. Using my simple scenario and assumptions you need tires every 2 1/2 years. That means you can leave your original spare under there for 100K miles or five years and still be OK in regards to dry rot.
    Bottom line: Five tire rotation does not give you a 20% savings. At best it is the same as a four tire rotation. Even if you upsize when the truck is new and add a upsized spare, five tire rotations save you nothing. It's a wash either way. It works out the same money.
  10. Jan 25, 2018 at 9:31 AM
    203 West
    203 West Well-Known Member
    2017 Tacoma TRD Offroad 4x4
    I do love the technical passion on tire rotation! I'm a sucker to looks though, so plan to keep the dirty spare beneath my truck at all times. With all the road grease and grime on it, I'd never get it clean enough to look like the other three. (yes, looks matter for me!)
    hiPSI likes this.
  11. Jan 25, 2018 at 9:35 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    People change five tires because their dad did it and their granddad did it or they heard it from a friend of a mechanic or something. It was a wash back then and it definitely is a wash now with TPMS and everything. It's like oil change duration arguments haha.
  12. Jan 25, 2018 at 9:39 AM
    splitbolt
    NW Arkansas
    It's funny...I use my spare when I do a 4 tire rotation, because I'm only jacking one wheel at a time.
    davidstacoma, TartanEagle and siznarf like this.
  13. Jan 25, 2018 at 9:40 AM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    Exactly why I rotate 5 tires
    davidstacoma likes this.
  14. Jan 25, 2018 at 9:43 AM
    splitbolt
    NW Arkansas
    I only use the spare as a 'placeholder'; it goes back underneath.
    RSOTACO likes this.
  15. Nov 16, 2018 at 11:15 AM
    #35
    Sauzacoma
    Sauzacoma IG: @Stancaban
    Southern California
    2017 TRD Off-Road (DCLB)
    This is exactly what I am about to do. Upgraded all 4 wheels to 17" with Wilpeaks 265/70r17 so I've been meaning to upgrade the 16" spare to a 265/75r16. Thanks for confirming fitment!
    Taco_Craig[QUOTED] likes this.
  16. Nov 16, 2018 at 12:34 PM
    #36
    Alnmike
    Alnmike Well-Known Member
    PNW
    '21 4R
    Your assumption that people drive 20k miles a year is about double what I do. Avg driver does 13.5k.
    Id rather use the spare instead of replacing a "brand new" tire every 6 years or so.
    It's a case of what I say rather than do. 5 tire rotation is better. But it's an extra step so I don't do it lol. Will probably change my tune the first time I need a spare and the mechanism is rusted shut.
    RSOTACO and davidstacoma like this.
  17. Nov 16, 2018 at 1:06 PM
    #37
    blind cowboy
    blind cowboy Well-Known Member
    Don
    Auburn CA
    2002 TRD XC 5sp
    My rationale for going to a 5 tire rotation is, assuming I can get 60K out of them and I rotate them every oil change 5K. What happens if a tire gets damaged beyond repair at say 30-40K, I didn't think it best to mix in an unused spare with 3 tires with 30 or 40K of wear. Then I'd just go to a 4 tire rotation till those 4 are worn out.
    Oh, and to the original question, I cut and welded in extensions to the factory spare tire carrier.
  18. Nov 16, 2018 at 3:48 PM
    #38
    BrianPVan
    BrianPVan Well-Known Member
    Brian
    BC
    2017 DCSB OffRoad
    I've got a 285/75/16 in my spare well
    RSOTACO and b3itz like this.
  19. Nov 16, 2018 at 3:51 PM
    #39
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    You can fit a 255/85r16 without rerouting the exhaust. Mine doesn't even come close, you just have to BFH the locating tabs properly.
    BRFab likes this.
  20. Jul 8, 2019 at 12:49 PM
    #40
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    That's the size of my trucks tires. Was this hard to fit up in there? I know this is an old post but maybe your still out there.
    oldirtywalker likes this.
