How big of a spare tire can i fit under the truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 17tacosport, Jan 5, 2017.
  1. Jan 2, 2021 at 7:58 PM
    #61
    BRFab
    BRFab Well-Known Member
    BC
    '19 Alien Grey TRD OR
    255/85r16 STMaxx. Hammered the tabs down. No need to modify the exhaust.
    I like the touch of extra clearance with a 33" skinny and close enough to my 295/70r17s to get home
    Tacomod and tacotoe like this.
  2. Jan 2, 2021 at 8:44 PM
    #62
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I bought five used fj alloy wheels and put 265/70r16 tires on and the spare fits good enough but I can tell it’s a bit too big.
  3. Jan 5, 2021 at 4:13 PM
    #63
    voudou
    voudou Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro
    I was able to fit a 265/75/16 perfectly in the spare.
    Beardedbaxterholic likes this.
  4. May 1, 2021 at 9:51 PM
    #64
    daveleau
    daveleau Active Member
    2015 gunmetal gray Tacoma SR5
    3" lift, winch
    Will a 305/70R16 fit in the spare slot of a 2015 Dualcab Shortbed?
  5. May 4, 2021 at 10:24 PM
    #65
    dennguy08
    dennguy08 Well-Known Member
    2018 Cement Tacoma TRD OR
    265/75/16 fits just fine.
  6. Oct 19, 2021 at 4:37 PM
    #66
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Anybody see the chain not being strong enough to hold 80ish pounds? I got my 295/70/17 to fit, but just worried the chain may not be strong enough.
  7. Oct 19, 2021 at 5:25 PM
    #67
    daveleau
    3" lift, winch
    Several thousand miles (some offroad) on my daily driver with a 305/70r16 tire mounted on the factory chain under my truck. It's rock solid. No issues.
    HeliToast and Rustytaco71 like this.
  8. Oct 20, 2021 at 5:29 PM
    #68
    Beardedbaxterholic
    Beardedbaxterholic New Member
    2021 DCSB 4x4 TRD SPORT 6MT
    TRD OEM Lift kit 265/70R-17 Cooper Discoverer AT3 4S 4runner Wheels Rekgen Flaps
    Can you confirm if you had any issues? I'm going for the same setup. Thanks in advance!
  9. Oct 21, 2021 at 8:20 AM
    #69
    Rustytaco71
    2018 4Runner
    Thanks for the reply:cheers:
  10. Oct 29, 2021 at 8:59 PM
    #70
    Sauzacoma
    Sauzacoma IG: @Stancaban
    Southern California
    2017 TRD Off-Road (DCLB)
    So far so good!
  11. Oct 3, 2022 at 10:38 AM
    #71
    jb34r5e
    jb34r5e Member
    Jamie
    Toyota Tacoma TRD Sport 13
    Just wanted to throw my experience here in case it helps someone. I beat the guide tabs upwards as recommended. Cut off the exhaust hanger closest to the tire and it was able to fit a 285/75/17. Doesn't touch pumpkin, barely touches the heat shield and is pressed against the drivers side framework that the shackle and eye bolt is on. Happy trails guys
    HeliToast likes this.
