How big of tire and rim can i get???
Discussion in '4 Cylinder' started by Matt in Knoxville, Mar 4, 2011.
  1. Mar 4, 2011 at 8:25 AM
    Matt in Knoxville
    Matt in Knoxville [OP] Well-Known Member
    Knoxville
    2010 SR5 Access Cab
    Tint, Fat Bob's 3" Lift Kit, 30" Tires, 16" Blacked out Rims, 4 extra D-rings, K&N Drop in Air Filter, Tonneau Cover, Besttop Soft Top, Aries Nerf Bars...more to come...
    i have a 2010 4 cylinder access cab, long and low...i want it to be up a little higher so my plan was to get a bigger tire, bigger wheel, and maybe add a 1" block...my question is has anyone done this, if so can i see your pics, and if not, do you know what size i can go....i figured i can do 265/70/16...im at 215/?/15 and it is too small....thanks.
  2. Mar 4, 2011 at 8:42 AM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2014 MGM Double Cab
    2016 TRD Suspension upgrade, 1st gen TRD Wheels, 265/75/16 Cooper RTX
    look in the 5-lug section for how people have lifted the trucks and what trie/wheel combo they are running.
  3. Mar 4, 2011 at 10:08 AM
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
    I'd look through the 5 Lug forum too. Also the Wheels and Tires forum. I have, but you should make your own choice with your truck / money.
    You should have 215/70-15 right now.
    The consensus seems to be max size should be 235/75-15 for stock base suspension. It fills the wheel wells nicely, doesn't rub, doesn't throw off your gearing too much, and should put your speedometer to where it's correct.
    If you want to change your wheels to 16" or 17", use the tire size calculator (I think it's a sticky in Wheels & Tires also) to get something with the same overall size.
    I've got 16" wheels on mine right now so I think I'm going to go with 225/75-16 Michelin Latitude Tour. Not an awesome Off Road tire by any means, but it has a low rolling resistance and is Green X rated. By going to this larger tire I might actually see a MPG increase instead of decrease and they'll look better on my truck.
    If you put some sort of kit on it to take it more like a SR5... such as this one:
    http://store.fatbobsgarage.com/toyota-tacoma-sst-275-lift-kit-2wd-2005-2009-5-lug-p4235.aspx
    I know it doesn't say that it fits a 2010 but you could find something similar, then you could go with a 265/70-17 or 265/75-16
    You'd probably need to consider re-gearing the differential then.
    This is also a pretty cool wheel and tire simulator if you want to see what some wheels and tires will look like on your truck. Lots of options on it for customization. You can choose your color, wheel size, tire ratio. You can even add a little bit of lift to your truck to see if you like it:
    http://www.autowaretech3.net/nextwheels/perfplustire.htm
  4. Mar 15, 2011 at 2:28 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    The tires on my truck are 235/75R16(29.88" tall) the factory size is 215/70R15(26.85" tall). I have no issues of any sort with running this size.
    No matter what if you go up or down in tire size your speedo will be off.
