How big w/ out a lift?
Discussion in 'Wheels & Tires' started by chestnut35, Nov 25, 2008.
  1. Nov 25, 2008 at 10:57 PM
    chestnut35
    chestnut35 [OP] Well-Known Member
    tempe
    08 Off Road Double
    bixenon HID, chrome running boards, access tonneau cover, Bilstein 5100, rear TSB leafs, 18x9 XD wheels, 285/60/18 Nitto Terra Grapplers, Front Bull Bar
    This may be a stupid ? but would anyone know off hand how much bigger (plus 1,plus2,etc.) that you can go tire/wheel size w/out having to get a lift?:confused: I have a 2008 trd off road double cab. Or can anyone recommend a good place to go? i went by discount tires but they weren't much help
    thanks for the help
  2. Nov 25, 2008 at 11:40 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Should be able to get a 265/75 with no problem. Maybe some minor rubbing.
  3. Nov 26, 2008 at 1:47 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Tons of threads with this question but, yes a 265/75R16 is the max size, or an equivalent like a 265/70R17, etc. with aftermarket wheels you may have to either trim or remove your mudflaps to keep from rubbing depending on the backspace/offset, on a stock wheel i dont think there's an issue with it.
  4. Dec 1, 2009 at 1:28 PM
    apw100
    apw100 Well-Known Member
    Jacksonville, FL
    07 4x4 TRD Off Road, 17" MM 955's, etc.
    Bilstein 5100 front shocks, Clarion VX409 DVD/ipod head unit, aFe air filter, Grillcraft MX grille, color matched grille surround.
    I installed BFG A/T KO tires 265/70/17's on MotoMetal 955's and there is a lot of rubbing. I'm gonna remove the mud flaps, at least until I install Bilstein 5100's.
  5. Dec 1, 2009 at 6:53 PM
    apw100
    Jacksonville, FL
    Well, I removed the mud flaps. No dice. Still rubs quite a bit. I guess I'm gonna have to take it easy until I can get a couple of Bilstein 5100's installed up front.
  6. Dec 2, 2009 at 5:29 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Might be your backspacing that's causing the rubbing. Do you know what it is? Wheel spacers might help depending on what the backspacing already is.
  7. Dec 2, 2009 at 7:02 PM
    apw100
    Jacksonville, FL
    The backspacing on the wheels is 4.53". Here are the specs...
    Moto Metal 955
    • 17x9, 6 on 5.5 Bolt Pattern
    • Backspace 4.53 in.
    • Max Load = 2200lbs
    • Finish = Gloss Black Machined
    • Hubcentric = No
    • Offset = -12 mm
  8. Dec 3, 2009 at 3:21 AM
    ikataco
    ikataco Well-Known Member
    06 DC Sport
    My friend has TRD Sport with BFG TA KO 265/70/17 on stock 17 x 7.5" alloys. Really fills the wheel well, no rubbing of any kind.
