how big...
Discussion in '1st Gen. Tacomas (1995-2004)' started by s2kvtak, Dec 11, 2009.
  1. Dec 11, 2009 at 4:12 PM
    s2kvtak
    s2kvtak [OP] Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    how big of a tire can i put on my truck? i have 5100s and toytec AAL in the rear. overall its about a 2-2.5" lift. i want to go as big as i can to get the pumpkin up and over rocks and logs without getting hung up. plus it looks good!
  2. Dec 11, 2009 at 4:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Depends on how much you want to trim stuff.
  3. Dec 11, 2009 at 4:21 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    whats that involve?
  4. Dec 11, 2009 at 4:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cut off anyplace the tire rubs....
  5. Dec 11, 2009 at 4:26 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    would this just be the inner fender plastics? and how big would that be before i had to do that? i have a 265/70-16 now and it looks puny. im pretty sure that converts to just a 31. would a 33 fit?
  6. Dec 11, 2009 at 4:32 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    By any place that rubs he means every place that rubs :p
  7. Dec 11, 2009 at 4:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    With a 33, you just trim away want hits. Sometimes, you may need to cut, and Box the body mount....It varies from truck to truck a little bit, so you really dont know until you mount them,.
  8. Dec 11, 2009 at 4:35 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    box the body mount? i dont mean to sound noob but i am to 4wd. is this front or rear? whats involved in doing this
  9. Dec 11, 2009 at 4:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For the front. In some cases, the body mount must be cut back, and have a flat peice of steel welded in place of the cut off part.
  10. Dec 11, 2009 at 4:38 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    okay so a 33 would fit with minor changes. and thats a 285/75-16?
  11. Dec 11, 2009 at 4:40 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    yup :)
  12. Dec 11, 2009 at 4:52 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    You can count on removing the front mudflaps. You'll probably want to pound down the pinch weld at the rear of the front fender wells. A narrower tire may offer a little less rubbing issues. Are you using stock wheels or aftermarket? Wheel offset and backspacing will affect tire rub.
  13. Dec 12, 2009 at 8:09 AM
    Scottdl99
    Scottdl99 Well-Known Member
    Indianapolis
    06' DC
    5100's w/884's @0, Sliders, Headlight bake w/eyelids, Rears blacked,5% tint. AFE Pro dry S, All LED interiors, Sridertrax, a few more
    So I'm sure he can get away with 32" tires? No trimming?
  14. Dec 12, 2009 at 8:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    yes.
  15. Dec 13, 2009 at 12:29 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    they are stock steelies. what size would be narrower? im not super keen yet on tire sizing
  16. Dec 13, 2009 at 7:24 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I'm not sure what you would be able to find for a 16" wheel. There are 33/10.5's available, but they're for 15" wheels.
