How can I add a second backup camera on my removable swingout on a 2020
Discussion in '3rd Gen. Tacomas (2016-2023)' started by StapleNut, Sep 25, 2021.
  1. Oct 16, 2022 at 7:22 AM
    #61
    Galileo7
    Galileo7 Well-Known Member
    19 Tacoma 4D 4x4
  2. Oct 16, 2022 at 7:33 AM
    #62
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Still too much in my opinion. Look at the product they are selling vs what I built a year ago. $225 vs $63. The only visual difference I see is the camera bracket and the plastic wire loom, ha.
  3. Oct 16, 2022 at 7:39 AM
    #63
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Finding a 6v camera is the key.
    if someone wants me to sell just the wire adapter for a specific 6v camera, I could likely try to add that to my store. I tend to focus on 12v cameras myself and run independent wire. But I get the benefits of using OEM wiring.
  4. Oct 16, 2022 at 7:43 AM
    #64
    Galileo7
    19 Tacoma 4D 4x4
    Agreed, I'll study your way when I get there. I'm too cheap to pay $225 for something I can do myself... but sometimes I'm tired of the learning curve.
  5. Oct 16, 2022 at 7:50 AM
    #65
    shaggy135
    Not hard at all. I think once I had all the parts, it took maybe an hour to wire up and test.
    Galileo7[QUOTED] likes this.
  6. Oct 17, 2022 at 1:06 PM
    #66
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Little bit “extra” overland build
    some welding required
    no issues running a 12V camera off the 6v source for me
  7. Dec 18, 2022 at 8:17 PM
    #67
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Does anyone have a diagram on how to do this? Shaggy 135s description doesn’t work on mine, I have the Natika camera, and purchased one of those four pin plugs. My camera video cable has a shield (video neg), yellow(video+) and red trigger wire coming out of the video plug and the standard red (+) and black (-) wire for the power, so I’m wondering how to hook these up to the 4-pin? On the four pin, gray is 1, 2 is black, 3 is yellow and 4 is blue. As shown below:image.jpg image.jpg
  8. Dec 18, 2022 at 8:21 PM
    #68
    OnHartung'sRoad
    I would rather make it myself, because I am going to eventually put in a hardwired camera for my trailer to it as well.
    Thanks guys!
  9. Dec 18, 2022 at 10:54 PM
    #69
    shaggy135
    No worries. I just helped someone else with this a couple weeks ago. Cut off the yellow video plug and trigger wire and then strip that cable. Should be two wires inside that housing.
    (1) Top left on the camera side of the plug goes to the red wire in the housing
    (2) top right goes to the other wire inside the housing
    bottom two will be the power and the ground. It'll be easier to just put a volt meter on it though.
    (4) my bottom right wire is power
    (3) bottom left is the ground
    the wire with power will go to your solid red wire (V+)
    last wire will go to the black with red striped wire (V-)
    OnHartung'sRoad likes this.
  10. Dec 18, 2022 at 10:59 PM
    #70
    shaggy135
    I'm borrowing mnguyenpdx's pic. Looks like the manufacturer of that plug changed the wire colors. This is what it should look like when done IF using that new plug:
  11. Dec 18, 2022 at 11:38 PM
    #71
    OnHartung'sRoad
    Awesome! Thank you so much, it’s so funny I used to do video work too, but the issue was really getting me where we had no diagrams, but you came through. Appreciate it, I owe you one!
    shaggy135 likes this.
  12. Dec 21, 2022 at 4:08 PM
    #72
    CementTruckUT
    CementTruckUT Member
    Hey Blueberry.Taco how did you mount the camera/do you have any pictures?
    Thanks!
  13. Dec 22, 2022 at 5:07 AM
    #73
    Blueberry.Taco
    Ryo
    originally i just mounted it under the bumper like this
    but later made a bracket on the camper like this
    306513563_10116389819122913_645578610958_1805f4f1676559916cc3a3e62df75f82b064326f.jpg
  14. Dec 22, 2022 at 5:24 AM
    #74
    CementTruckUT
    Awesome, thanks! I also have a 2020 Tacoma and the same FWC
  15. Dec 23, 2022 at 9:38 AM
    #75
    OnHartung'sRoad
    Anyone know what type of female connector that is on the truck end? I want to put a female panel mount connector on my truck near the license plate so I can easily swap the swingout camera to my trailer camera and forget about climbing under the truck to get to the connector behind the bumper!
  16. Dec 26, 2022 at 10:40 AM
    #76
    CementTruckUT
    Hey Blueberry.Taco I got the camera and connector in the mail. How did you wire it up? Did you cut off only the RCA plug, or did you cut it off on the other side of the weird connector that comes with the camera?
  17. Dec 26, 2022 at 10:58 AM
    #77
    OnHartung'sRoad
    Cut off only the RCA connector and strip back that cable insulation to expose about 3-4 inches of the red and the yellow wire by cutting off the bare shielding wire and foil away from it. You will only need to use the yellow and red wire, and the other red and black wires to do your camera set up.
  18. Dec 26, 2022 at 11:05 AM
    #78
    CementTruckUT
    Okay. The cable to the RCA had a red wire and a yellow wire in in. The red wire is video + and the yellow is a shield/video -? And the other red and black wires are +12V and GND? Looks like:
    Vid + to 8 pin plug pin 3
    Vid - to 8 pin plug pin 2
    +12V to 8 pin plug pin 6
    GND to 8 pin plug pin 5
    Is this correct?
  19. Dec 26, 2022 at 11:11 AM
    #79
    OnHartung'sRoad
    I just followed the picture on post number #70 above, it worked perfectly.
  20. Dec 26, 2022 at 12:05 PM
    #80
    CementTruckUT
    I'm not having any luck. Can anyone with an 8 pin wiring harness confirm that:
    And 12V is already on pin 6/no need to grab it from somewhere else?
