How Can I Break Into My Own Tailgate?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dde0485, May 30, 2015.
  1. May 30, 2015 at 4:31 PM
    dde0485
    dde0485 [OP] Well-Known Member
    Black Hills, South Dakota
    '10 Tacoma TRD Sport 4X4
    My tailgate (2010 Tacoma) is stuck closed and the handle just flops around like a raw hotdog. I have a hard top tonneau cover with springloaded handle latches that I had to force open a few inches and snap the latches off just to get into the bed of the truck.
    Is there a way to "pick" the latches open and see if they are just jammed, and unjamming them to get the handle to work again or what's the best plan of action here? Thanks in advance for the awesome replies, you guys never let me down ;)
    neverstuck likes this.
  2. May 30, 2015 at 7:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you are in to the bed of the truck, just remove the inside cover over the tailgate and see what is wrong.
    File IFR likes this.
  3. May 30, 2015 at 8:37 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    ^^ Bingo!
  4. May 30, 2015 at 9:01 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    It may just be that the latches are dry and stuck in shich case you can spray some lube in them and get them freed up but there's a good chance you've got some broken clips on the actuating rods.
    If you can get access then take the cover off and manually open it by pulling the rods. Watch the edges of the plastic cover, one of my friend's was really sharp. Be prepared to drop a couple of bucks at the dealer to replace the cheap POS plastic clips that Toyota used connecting the rods to the latch mechanism. Given that the dealer will likely not have them or will only have part of what you want and that they will break again I'd recommend going ahead and buying a spare set to put in your tool box. I've replaced parts twice now. While you're at the dealer go ahead and buy several of the POS plastic netsert things for the tailgate too as once you've undone them once or twice they don't hold snugly anymore. Do not use an electric driver when unscrewing or screw the screws into them- do it by hand or you risk stripping them.
    I'd also recommend cleaning the latch mechanism thoroughly and regreasing all of the moving parts.
  5. May 30, 2015 at 9:07 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Great post. Good luck with fix.
