How can I clean my engine compartment?
Discussion in 'Technical Chat' started by Sheepdog, Sep 1, 2010.
  1. Sep 1, 2010 at 10:57 AM
    Sheepdog
    Sheepdog [OP] Well-Known Member
    Gary
    San Diego, CA
    Black 2002 Tacoma Xtra Cab, 4x4, TRD, SR5
    Eibach/Bilsteins, Beefed shackles, Bushwacker Cut-Outs, Custom roll bar, TG Sliders, Elite Front Bumper, XRC8 Winch
    My engine is covered in mud and other crap from when I went mudding DAYS ago. I haven't cleaned it because I didn't feel the need to but I want to now and I need ideas. I don't want to pressure wash it because that can damage stuff and mess with the electrical mess. Any ideas?
  2. Sep 1, 2010 at 11:01 AM
    81shark
    81shark Well-Known Member
    i rinse mine with a garden hose once a year, regardless of if it needs it or not
  3. Sep 1, 2010 at 11:04 AM
    Sheepdog
    Gary
    San Diego, CA
    Should I put a bag or something around the distributor? and keep in mind it's not just the engine. It's the whole compartment that's filthy.
  4. Sep 1, 2010 at 11:25 AM
    ScubaCougr
    ScubaCougr Active Member
    Pacific NW
    '08 PreRrunner
    nerf bars
    Google "how to clean engine" for lots of links and tips. A favorite site of mine is "detailcity.org" for advice.
    Common points: cover all electrical and air intakes to prevent water intake. Don't go nuts with water pressure (think rainfall to light hose-blast). Use an all-purpose cleaner or engine-degreaser to help break up the gunk. And proceed at your own risk, the online advice might be from an idiot.:)
  5. Sep 1, 2010 at 11:37 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    All I did was buy some aerosol engine degreaser, soak the engine with it, let it sit for about 10 minutes, then used the pressure washer to rinse it off. Like said above as long as you don't get to close you wont hurt anything. I didn't cover anything up I just tried to go easy over the big electrical stuff.
  6. Sep 1, 2010 at 11:41 AM
    meckleystephen
    meckleystephen My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    honestly how I do it is I take it to the car wash and leave the engine running and spray it down if you hear the engine shudder or anything crazy then get the water away from there. It sounds nuts but I have done this many times on my 96 taco and at least 4 or 5 times on my 06. It gets the job done and never causes any issues
  7. Sep 1, 2010 at 12:19 PM
    81shark
    you gotta remember, the engine bay is getting water in it every time you drive in the rain. engines aren't scared of a little water and most things under the hood are sealed up pretty darn good.
  8. Sep 1, 2010 at 12:29 PM
    xroller
    xroller Blowin by em sideways
    X-roller
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    with a toothbrush.....
  9. Sep 1, 2010 at 12:46 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    use the green tire cleaner foam at the do-it-yourself washes, some places even have it labeled tire/engine wash.
  10. Sep 1, 2010 at 12:52 PM
    xroller
    X-roller
    1 hp mod
    ^^that's what I use. Let the engine cool off for about 30 min or so.... soak the engine bay in the green stuff.... let it sit for a few minutes to break down the grease...... spray it all off.
  11. Sep 1, 2010 at 12:53 PM
    southerntaco889
    southerntaco889 Well-Known Member
    Bartow, GA
    07 PreRunner DC TRD Sport
    5100's @ 2.5/285 BFG A/T's/blacked-red badges/strobes/siren/PA/roof rack soon to come/brush guard soon to come
    Just my 2 cents but I use a degreaser called Black Maxx. I get mine from NAPA...comes in a spray bottle for about 7 bucks. Just spray it all over the engine and let it sit bout 10 minutes then wash it off really good. If you do that you wont have problems but if you just leave it on there it will eventually eat the rubber up. I've always done it and never had any problems. Works freakin awesome on wheels and tires too.
  12. Sep 1, 2010 at 12:55 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I'm leery of cleaning it with the engine running or hot. Did it once per some instructions on a can of cleaner and probably won't do it that way again. Water off the road when it rains is one thing, but a large volume of cold water coming into contact with a hot engine can cause things (metal and plastic) to crack.
  13. Sep 1, 2010 at 3:04 PM
    Sheepdog
    Gary
    San Diego, CA
    So it sounds like I should get a can of engine degreaser, spray it on when the engine is cool and then use a hose and clean it off with that... Right?
    CoachRich likes this.
  14. Sep 1, 2010 at 3:07 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    IDK if you own an air compressor, but I used one and a paint sprayer filled with purple power. The spray is pretty strong and concentrated. Let the purple power set for a second, then refill sprayer with water .
  15. Sep 1, 2010 at 3:25 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I do this. Just keep the hose moving, don't blast one spot constantly. If there's a spot for a wash mitt, I'll try getting in there. Simple green is cheap and you can use it for other stuff too, so it's one of the most economical choices.
    There's also stuff that Costco sold called Oil Eaters that is some amazing stuff.
  16. Sep 1, 2010 at 3:34 PM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    Degreaser, pressure washer (on fan, with at least 2' between the nozzle and engine), with the engine just warmed ... run for a couple of minutes before starting. When finished, while the engine is still wet, fog the bay with Armorall. It'll look greasy for a day or so, but later it will look good.
  17. Sep 1, 2010 at 3:53 PM
    Sheepdog
    Gary
    San Diego, CA
    I try to stay away from things that say "green". lol
  18. Sep 1, 2010 at 3:54 PM
    Chickenmunga
    Keizer, Oregon
    Simple Green is not affected by hippies
  19. Sep 1, 2010 at 3:56 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    purple power followed by armor all
  20. Sep 2, 2010 at 3:20 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Just be careful with the simple green on aluminum, as it can eventually eat through it if left on for too long. Make sure to completely rinse it off.
