How can I fix these corner dents on the bed?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dangorah, Oct 1, 2017.
  1. Oct 1, 2017 at 6:18 PM
    Dangorah
    Dangorah [OP] Well-Known Member
    Dallas, TX
    Suction cup won't fit there. I tried getting something behind it to push it out and there's no room for anything.
  2. Oct 1, 2017 at 7:53 PM
    tony2018
    tony2018 Well-Known Member
    pdr
    or welded tabs and pull out
  3. Oct 1, 2017 at 7:58 PM
    Dangorah
    Dallas, TX
    Any options for doing it myself?
  4. Oct 1, 2017 at 10:44 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    I have a dent right under my taillight too. Also failed trying to push from behind.
  5. Oct 1, 2017 at 10:46 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    If you can’t get behind there, no.
    Any sheet metal with a bend or crease (like a body line) is the strongest area. I’d learn to love them or see if a PDR guy can do it. Otherwise for normal body repair that’s not a hard fix, but not a cheap one either, and will need repainting.
  6. Oct 2, 2017 at 1:22 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Drill or poke a hole and get a screw in that you can pull on to pull it out. I had a couple that I got rid of with a screw, an nail set, and a piece of water heater strap I used to pull on the screw with - pliers would work too.
    This was my first time doing body work - YouTube has a few good bodywork tutorials if you're a little unsure about it. This guy is the man at bodywork:
    You can repaint that with auto paint shop rattle cans (2k primer, 1k color match, 2k clear) for less than $100. Just take your time and be thoughtful about how you approach it.
  7. Oct 2, 2017 at 12:45 PM
    cooper4x4
    cooper4x4 Well-Known Member
    Dallas
    02 Tacoma SAS
    Pop the taillights and see if that helps with access.
  8. Oct 2, 2017 at 12:47 PM
    Dangorah
    Dallas, TX
    That's one thing I haven't done, I'll have to try this soon.
    The dents on the lower portion of the bed aren't accessible through there though. I've tried getting a silicon mallet handle in there but there is some metal bracket in the way.
