How can I from stock to stud without goin broke?
Discussion in 'New Members' started by BigCountry561, Nov 25, 2011.
  1. Dec 3, 2011 at 11:15 PM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    Stay away from spacers. Spend money on the lift, don't go cheapo, because suspension is one of those things where you really, really, absolutely get what you pay for. Go to wheelersoffroad.com and check their kits out. One place you could skimp is by using AALs (add-a-leaf) in the rear, you can get almost 3" out of those. But I say throw down for the front end, you can really improve both handling and ride quality while lifting. Lots of folks go with OME 881 coils and NitroCharger struts. Toytec also offers a kit with pre-assembled coilovers, which is another issue. If you get your front shocks/coils separate, you will have to pay for them to be assembled or rent a spring compressor. Just order them assembled, them coils is DAN-GER-OUS if you don't do it right.
    For 3" lift, you will also want to include a differential drop kit for the front end and an extended rear brake line. Kits will comes with that stuff. Spend about $1500 and you can do it up nice with new leaf packs in the rear.
    Do you have some hot women that will ride around with you? That's a real cheap way to make yourself feel even better about your truck.
  2. Dec 3, 2011 at 11:31 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    offended
  3. Dec 12, 2011 at 10:19 AM
    BigCountry561
    BigCountry561 [OP] Member
    Has a pair, aint got a Yota
    Florida
    which do yall think is a better lift kit? AAL w/ Coilover nitro shocks? or Performance Strut with nitro shocks?
  4. Dec 12, 2011 at 10:20 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
  5. Dec 12, 2011 at 2:10 PM
    BigCountry561
    Florida
    what do you mean links?
  6. Dec 12, 2011 at 2:12 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    This part makes no sense, do you have links to these
    AAL - add a leaf, leafs dont use coilovers... a your truck doesn't have struts, it has coilover shocks up front, leaf pack in the rear, so saying your looking at an aal w/ coilover shocks to me means you want an AAL in the back and coilovers up front, if so, post a link for the coilovers. The strut makes no sense on a Tacoma.
  7. Dec 12, 2011 at 2:13 PM
    BigCountry561
    Florida
  8. Dec 12, 2011 at 2:15 PM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    Cheapo lift:
    AAL + spacers
    Quality lift:
    Coilovers + Replacement leaf pack
    Power upgrades:
    SC
    Aftermarket CAI just make more noise
    /thread
  9. Dec 12, 2011 at 2:16 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    You can get 4 5100's and an aal for cheaper from down south offroad.
  10. Dec 12, 2011 at 2:19 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
  11. Dec 12, 2011 at 2:23 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    drink this:
    wear this:
    put this on your back window:
    put this on your truck:
    have this lift:
    have these "reems":
  12. Dec 12, 2011 at 2:26 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
  13. Dec 12, 2011 at 2:28 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    LOL!
  14. Dec 12, 2011 at 2:43 PM
    takern
    takern Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    Welcome to TW. Home of assholes and shenanigans. Its a great place.
    As far as your question, go through the forum. there is plenty of information as far as lifts/power/mpg. for lift i would recommend just some Old Man Emu (OME) coils with some Bilstien 5100 shocks (billies). That is about your cheapest yet not useless front end option. for the rear an Add A Leaf (AAL) will give you 2-2.5". Or you can get a new leaf pack but unless you are going to do any offroading the AAL will be just fine.
    Or if you want to do some offroading you can buy a whole coilover for the front. I have Sway-AWay (SAW) coilovers but there are plenty of good companies. There are also lots of options for the rear. I wont go into that because you should do some research and learning if you want to get into the offroad world.
    Powerwise, pretty much your best option is the TRD Supercharger (SC). It will cost a pretty penny though and it can be difficult to install. a much cheaper option is to do the deck plate mod. There is debate to whether this helps at all. i think it does based on my 1mpg increase.
    But in all seriousness, just look around the site a bit and find what you are looking for. Also, try not to get butthurt.
  15. Dec 12, 2011 at 3:08 PM
    #35
    Sawyercomesclean
    Sawyercomesclean >:3
    Zell
    Tampa area
    2011 DCSB Prerunner SR5 TRD
    3" jacked up/ 33s/ Sockmonkey decals/ tailgate lock/ TRD FJ wheels/ tinting/ Black Hunter Bull Bar/ Devil Horns by Andres/
    Save up moniez.
    Then Pro Comp all the way.
  16. Dec 12, 2011 at 3:10 PM
    #36
    97yota4wd
    Eric
    Mesa, AZ
    now that i have had my laughs, this is your answer^
  17. Dec 12, 2011 at 3:15 PM
    #37
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    it's a trick question. Everyone know you have to spend money to be cool.
  18. Dec 12, 2011 at 3:23 PM
    #38
    Aw9d
    Aw9d That one guy
    Really just read up about your truck on here. You'll find a lot of stuff you can do, with great write-ups on how to do it. I planned on keeping my 2011 stock for the most part, those plans are long gone thanks to TW.
  19. Dec 12, 2011 at 3:41 PM
    #39
    WheelinJ91
    WheelinJ91 Well-Known Member
    Edmonton,AB
    2012 TRD DCSB
    Airaid Intake, MBRP Exhaust, Toytec OME 3" lift w/AAL, Flip-kit, LR UCA's, Weathertech Floor mats, hood and window deflectors.
    Get a smart car if worried about MPG but you will go broke and if you want performance you will go broke
  20. Mar 1, 2012 at 8:25 AM
    #40
    BigCountry561
    Florida
    Those of you that gave me legitimate advice, thank you, but I figured out a much better way to get my truck where i want it to be... I'm going to trade in that POS Tonka Toy and get myself a real man's truck, so while yall play with your little toys, I'll be in my ALL AMERICAN FORD.... again to those that gave me legitimat advice, thanks, but to the rest GFY..
