How can i get more power out of my 2006 2.7l 4 banger?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006tacody, Sep 22, 2021.
  1. Sep 22, 2021 at 2:22 PM
    2006tacody
    2006tacody [OP] Member
    Cosy
    2006 tacoma 2.7l custom
    Stereo, rims, hood swap for scoop. Professional sound mapletech mids and tweets, 2x kicker solo barics 8, 2x pheonix gold power amps and cap.
    Has anyone modified a 2.7 engine?
    I love my base 2wd tacoma with the 4 banger 2.7....but where i live if i need to pass in the 80-120km hr range......its downright scary, kind of gutless.....how do i het better accelleration?
  2. Sep 22, 2021 at 2:25 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Turbo. It is the way.
    Welcome aboard:hattip:
    dirtdigginjoe likes this.
  3. Sep 22, 2021 at 2:32 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  4. Sep 22, 2021 at 2:38 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Loose weight. Remove the unused seats, lighter tires and wheels, run the truck through an acid bath. :mudding:
  5. Sep 24, 2021 at 4:08 PM
    2006tacody
    Cosy
    I have removed unused seats and recently lost 30 lbs.....that thread above wasnt helpfull....so nothing yet. ???
    I also have larger aluminum summer wheels and tires which does help a little especially cornering, but i want more zoom.
    I saw a turbo/supercharger online but for 5 grand u.s. and im not a great mechanic.....im wondering if anyones done any tuning or exhaust....ecu? Throttle body? Easy power ups.
    US Marine likes this.
  6. Sep 24, 2021 at 4:12 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Header , CAI and catback exh will wake it up
  7. Sep 24, 2021 at 4:14 PM
    eon_blue
    Azusa, CA
    Go to the first page of that thread above. It has tons of links to performance mods for the 2.7l.
  8. Sep 24, 2021 at 4:24 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Pop the number 4 coil out and see if it’s wet with oil or dry at the plug. If it’s wet you need valve cover and spark plug tube gaskets. My truck runs like Jack the Bear in those speed ranges you’ve described
  9. Sep 24, 2021 at 4:24 PM
    2006tacody
    Cosy
    Okay yes page 1 is where its at....and the first build after is intense....but question 1, will "cold air intake" gain me power.....i have heard it nakes more noise, but that stock the fender intake is cold air....?? Lots of those things are to pricey and conplex for me so thinking the exhaust i could have done??? Will it help though.....or just be obnoxious....i like how quiet my truck is (steroe aside)
  10. Sep 24, 2021 at 4:26 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Run the RPMs up to 4500 she can handle. I assume you have a stick shift. Right?
  11. Sep 24, 2021 at 4:26 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    All of that shit does nothing. Make sure the engine is running correctly, first
    9th likes this.
  12. Sep 24, 2021 at 4:58 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    If you can find - locate an old TRD " black case" supercharger and install it on your 3RZ , you're going to enjoy the new found power . This is what I'm running on my 3RZ and with a header , catback and CAI you'll enjoy it
    I'm not running a Party pulley just running at 5lbs boost and I'm making the same hp as a stock V6 . I used to live in the Socal High Desert and drove on the 4500ft Cajon pass . I could easily maintain 70 mph up this steep pass even passing newer 3rd gen tacoma's with ease
    2006tacody[OP] and Steves104x4 like this.
  13. Sep 24, 2021 at 5:09 PM
    2006tacody
    Cosy
    No auto....the truck is just about to hit 80000km....runs properly....just stck motor
