How can i improve gas mileage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by S_cantrell_, May 17, 2016.
  1. May 17, 2016 at 10:30 AM
    S_cantrell_
    S_cantrell_ [OP] Well-Known Member
    Derrick Lewis
    My truck has a lift and 33s on it and it gets really bad gas mileage is there anything i can do to make it better while keeping the lift and tires? Its a 4.0l v6
  2. May 17, 2016 at 10:33 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Keep your right foot off the skinny pedal.
    JDawg562, RexsTaco and dantrd05 like this.
  3. May 17, 2016 at 10:34 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Lower your speeds.
    Lower your RPMs.
    Lower your application of throttle.
  4. May 17, 2016 at 10:34 AM
    Iasco
    Iasco Well-Known Member
    Baby throttle, and "predict" your stops.
    dantrd05 likes this.
  5. May 17, 2016 at 10:35 AM
    irish_11
    irish_11 Well-Known Member
    Everett, WA
    2011 DCSB
    Just keep throwin' money at it.
    How bad is really bad? The Tacoma isn't particularly known for its aerodynamics. To improve MPGs you would need to be more conscious of your gas pedal.
    Also:
    • Drop extra weight from the truck.
    • Drive less stop and go/short trips (commuting or little trips).
    • Make sure you air filters are clean as well as all parts properly lubed.
    • The 33's are going to have an impact too. Make sure they are properly inflated.
  6. May 17, 2016 at 10:36 AM
    dantrd05
    dantrd05 Well-Known Member
    Daniel
    Ottawa, ON, Canada
    2016 DCLB TRD Sport
    BF KO2 with FN Fx Pro's (Matte bronze) Levelling kit 2,75" Front and 2" Rear.
    Unfortunately, when you buy a truck, you are automatically not allowed to complain on gas mileage anymore. lol
    Only way: Change driving habits.
    RexsTaco, BDMcGuire and JB like this.
  7. May 17, 2016 at 10:43 AM
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    I seriously think my truck gets the same mileage whether it's floored or driving like a granny. After my lift and tires I try to use the gearing in first and second to accelerate harder and then let off and cruise through the other gears. This seems better than chugging it through second to fifth as far as work on the engine. Like i said gas mileage is negligible
  8. May 17, 2016 at 10:43 AM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    Switch to synthetics
    Just Dandee likes this.
  9. May 17, 2016 at 10:45 AM
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
    Only drive on the freeway
  10. May 17, 2016 at 10:48 AM
    S_cantrell_
    Derrick Lewis
    This is definitely wrong i know lots of people with diesels and get amazing gas mileage.
  11. May 17, 2016 at 10:51 AM
    memario1214
    Colton
    Missoula, MT
    What's "amazing"? Because most diesels I know of get about 13-15. Sure some will hover around 20 on the highway... But a diesel vs a gas powerplant are very different animals.
  12. May 17, 2016 at 10:51 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    They might get amazing FUEL mileage out of a Diesel but they defiantly do not get great gas mileage. Diesel engines have a tough time running on gasoline.
  13. May 17, 2016 at 10:52 AM
    abarber11
    ATX
    2011 DCSB
    There's your answer! Diesel swap on your Tacoma!
    BDMcGuire and big_jarv like this.
  14. May 17, 2016 at 10:52 AM
    irish_11
    Everett, WA
    2011 DCSB
  15. May 17, 2016 at 10:52 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Get a corolla
    Lester Lugnut, Aw9d and dantrd05 like this.
  16. May 17, 2016 at 10:57 AM
    S_cantrell_
    Derrick Lewis
    I obviously knew that, you didn't have to be a smartass.
  17. May 17, 2016 at 10:58 AM
    S_cantrell_
    Derrick Lewis
    What if i upgraded my intake, or any performance mods. Wouldnt an increase in hp help with gas mileage cause it would turn the tires easier?
  18. May 17, 2016 at 10:59 AM
    dantrd05
    Daniel
    Ottawa, ON, Canada
    2016 DCLB TRD Sport
    I'm not saying otherwise! lol I was making a joke! :)
    It's just a little funny when someone says: I have a truck, I have a 7" lift and big ass tires....how come does my truck needs that much gas!
    I'm not meaning to offend you here.
    How much are you making? If you are around 15-16 I'll say it's not that bad considering that the new 3,5 3rd gen makes around 19-20 stock...
  19. May 17, 2016 at 11:00 AM
    dantrd05
    Daniel
    Ottawa, ON, Canada
    2016 DCLB TRD Sport
    No.
    More performance also needs more fuel.
    More performance = more power = more combustion.
    *usually.
  20. May 17, 2016 at 11:01 AM
    scocar
    scocar hypotenoper
    You can improve your gas mileage by reading all the previous 7 million threads on it and using common sense. :thumbsup:
