How can I improve my gas mileage??
Discussion in '1st Gen. Tacomas (1995-2004)' started by mendezvinner, Jul 17, 2017.
  1. Jul 17, 2017 at 7:46 AM
    mendezvinner
    mendezvinner [OP] Member
    Vinner
    2001 Toyota Tacoma 4X4
    Hey guys, so I have a 2001 Tacoma double cab 4x4 and i have done some test and I am currently getting about 14-15 MPG when i should be getting close to 19-20. Is there things on my truck I should replace that will give me that fuel efficiency back? I don't run my truck hard at all, normally stay at 2kRPM's. Thanks!
  2. Jul 17, 2017 at 8:06 AM
    herbertgerg
    herbertgerg Well-Known Member
    Gary
    1999 SR5 4x4 5spd Access Cab
    Fluids and filters, tire pressure, cut weight by losing unnecessary items. Reduce rotating mass by moving to lighter wheel/tire combo. Clean MAF sensor. Make sure you're buying good fuel from somewhere with high turnover and low water content. That's about all you can do for these trucks.
    Fuergrissa likes this.
  3. Jul 17, 2017 at 8:29 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Hey Vinner! I have a '03 3.4 Auto and I average about 16. It's mostly all city and very little highway. I've used full synthetic since I purchased new, change the air filter/pcv valve once a year and running stock tires. I just don't think the 3.4's were meant to get great gas mileage
    Hamer95USA and TacomaJunkie8691 like this.
  4. Jul 17, 2017 at 9:11 AM
    Glamisman
    Glamisman Well-Known Member
    turn off AC check, tire air pressure, anticipate stops etc
    Hamer95USA likes this.
  5. Jul 17, 2017 at 9:42 AM
    Madjik_Man
    Colorado Front Range
    Intake system: Replace air filter if dirty, clean the MAF, clean the throttle body thoroughly. Clean IAC too while you have it apart.
    Spark Plugs: Make sure they are changed according to spec.
    Tire Pressure: Make sure the tires are properly inflated.
    Gas Cap: Make sure you are getting a good seal.
  6. Jul 17, 2017 at 12:42 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    15-16 is average. 19-20 is pretty unrealistic unless you're doing a stead 55mph with a favorable wind with no stops. The best mod you can do it learn to drive more efficiently. You can read on those tip endlessly on various forums.
    labrador01 likes this.
  7. Jul 17, 2017 at 12:44 PM
    eon_blue
    Azusa, CA
    When I first got my '04 v6 TRD 4x4 last year I was averaging 20mpg on the freeway with the supercharger on and (stock size) E rated tires.
    After I put my lift on, sliders, roof rack with lights and slightly 1/2" bigger tires I'm averaging about 16mpg now. Slightly under 18 on the freeway. These trucks are particularly sensitive to changes in weight (especially at the wheels) and aerodynamics it seems.
  8. Jul 17, 2017 at 12:48 PM
    eon_blue
    Azusa, CA
    Oh and if you go over 70 on the freeway your mpg's are going to tank big time. I'm running 2.7k-ish RPMs at 70mph in 5th gear, not so great by today's vehicle standards. 65mph is probably the best top speed to go at, here in SoCal though that's not always possible without getting run over even in the slow lane.
    labrador01, Toyko Joe and tcjacado like this.
  9. Jul 17, 2017 at 12:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    Automatic? Lift, oversize tires? Or all stock?
    www.fueleconomy.gov original estimates were 17/19.
    The formulary (for everything) changed a few years ago, and the revised rating for that truck is 15/18.
    Depending on modifications, tuneups (or lack thereof) and other factors, you may or may not be able to exceed those estimates.
    However, you're not far off, assuming your 'testing' methods are accurate.
  10. Jul 17, 2017 at 1:01 PM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    it's an offering to the gods, in appreciation for a cooler truck...
    eon_blue[QUOTED] likes this.
  11. Jul 17, 2017 at 1:02 PM
    AdventurousTurtle
    AdventurousTurtle Well-Known Member
    2005 Tacoma TRD Off Road
    2 inch leveling kit
    I'm fairly certain that's the only way
  12. Jul 17, 2017 at 2:25 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Get a daily driver...that's the only way to drastically increase your fuel economy. Also this is the best mod you can do for your truck. Between my daily driver and my truck I average about 38mpg. The daily gets 46, the truck gets about 15.
    EubeenHadd likes this.
  13. Jul 17, 2017 at 2:26 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Hello fellow Prius owner :)
  14. Jul 17, 2017 at 2:35 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Get a Sail?
  15. Jul 17, 2017 at 3:56 PM
    Madjik_Man
    Looks like his DD is a 2009 Suzuki DL650 V-Strom.
    But you can say hello to me, another Prius owner. :thumbsup:
    otis24 likes this.
  16. Jul 17, 2017 at 5:46 PM
    otis24
    Mark
    California
    Nah...motorcycle. If it weren't for lane splitting in CA I'd have a Prius. That's my second favorite car after the Tacoma.
  17. Jul 17, 2017 at 8:11 PM
    APACHETECH
    APACHETECH Well-Known Member
    central pennsylvania
    2013 MGM DCSB OR
    Trd Baja lift Wheelers Aal SCS Ray 10 16x8s Cooper AT3 4S 265/75/16 Trd shift knob Weather tech front and back Heated seats Auto start Immryo mirror mod Mods to install : 4x4 lighted switch Speakers/components/sub and box from Mr. Marv Redline hood struts One piece engine splash gaurds Wish list/looking for : Matching cap Light bar/pods Seat covers Roof rack Step bar Skid plates
    Ive become obsessed with calculating my gas mileage. Been doing it for years. The two things that have given me better gas mileage that was noticable was a AFE dry filter and when I bought Michelin ltx m/s 2. I also have a double cab trd. Just filled up and got 19.1. I average 19.3. I avg 21 on highway only trips. Other things that may help u that others have mentioned already is tire pressure, good alignment, keep it under 70. Maybe change fuel filter and if your o2 sensor is bad change it. Fuel system cleaner ? Ive read where those have helped others. My 02 sensor light is on but doesnt effect my mileage. Good luck with improving your mileage.
  18. Jul 17, 2017 at 8:17 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    A tune up ? I just recently replaced my plugs and air filter and my mpg went from 17.2 to 20.4 over 4 tanks of gas . I have a 4x4 TRD Off-road , 4.0 v6 automatic, 265/70R16 tires. The 20.4 is a mix of city and highway . I haven't been on a trip yet with the new plugs but I bet they are up around 22-23 mpg on the highway . I've been super stoked about my mpg increase . I still want to clean my MAF sensor , throttle body and maybe drop a bottle of Techron in the tank . See if I can squeeze a few more mpg out of the big truck .
  19. Jul 17, 2017 at 8:30 PM
    igno1tus
    Wrong
  20. Jul 17, 2017 at 8:37 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Its a truck, if you want good gas mileage, sell it and buy a Honda Civic.
    gugman likes this.
