How can I improvise a crankshaft pulley holder?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Jun 19, 2015.
  1. Jun 19, 2015 at 10:14 AM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    I need to take my cylinder heads off and I ordered a crankshaft pulley holder from Amazon but it takes them time to get prepare my order and I won't have it until next week. It is a really frustrating situation because the weekend, when I actually have time to work on the truck, will go by without me having the necessary tool.
    Is there any way to macgyver something that can do the job this tool does on a Tacoma V6 crankshaft pulley so that I can move forward?
  2. Jun 19, 2015 at 11:28 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    It's possible. I made one a couple of decades ago to hold the crank pulley on my Eclipse GSX. I had a long piece of metal (may have been a mower blade but I seem to recall it being longer and completely flat.. you get the idea) and I cut have half circle notch out of the edge for the center of the crank that stands out to clear and then drilled two holes in it for two of the bolts to thread into. In that instance the bolts had enough threads to do this so maybe you can do the same but drill the holes large enough for the heads of the bolts to clear so you don't have to remove them at all? I always wondered if that would have been easier/better but it worked for my needs at the time and gave me the leverage I needed so if you can picture that and have the resources that may be an option for you. Personally, I would just get the right tool or wait to do the job unless someone posts with a surefire way to do what I described for our trucks. Either way, good luck.
    foampile[OP] likes this.
  3. Jun 19, 2015 at 12:05 PM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    O'Reillys rents tools for free (require Credit Card deposit). Try that route.
  4. Jun 19, 2015 at 12:09 PM
    foampile
    Mid-Atlantic
    Thanks but I think the Amazon delivery will come sooner.
  5. Jun 19, 2015 at 12:11 PM
    jessandjamie
    Arizona
    You must not have a O'Reillys near you. Because in my case I could walk to the store and back in less than a weekend.
    Autozone might rent tools too....
  6. Jun 19, 2015 at 12:13 PM
    foampile
    Mid-Atlantic
    That would be correct. I'm in the Mid-Atlantic. I was assuming they would need to ship it.
  7. Jun 19, 2015 at 12:17 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Here's another idea. Buy a new serpentine belt. Take the old one and cut it. wrap it around the crank pulley so that it overlaps with the cut end, then take a breaker bar or maybe a jack handle and tie to the other end so that it can't move. That ought to lock the pulley solidly (make sure you wrap it the right way of course.). I've done this more than once in the past. When you try to turn the pulley, the belt will tighten and stop the turning, if you get the handle/breaker-bar or whatever in a solid location. Always be careful when pulling hard so that if it slips or the belt actually breaks. you won't hurt yourself when the tension is released.
    foampile[QUOTED][OP] likes this.
  8. Jun 19, 2015 at 12:21 PM
    foampile
    Mid-Atlantic
    Haha, I'm not going that route but I love your out-of-the-box thinking. BTW, what you're describing is called a strap wrench and is sometimes used in plumbing to turn big heavy cast iron pipes.
  9. Jun 19, 2015 at 12:39 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Is your engine on an engine stand?
  10. Jun 19, 2015 at 12:40 PM
    foampile
    Mid-Atlantic
    No, it is under the hood
    xJuice likes this.
  11. Jun 19, 2015 at 12:42 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Transmission attached?
  12. Jun 19, 2015 at 12:46 PM
    foampile
    Mid-Atlantic
    Yes sir.
  13. Jun 19, 2015 at 12:47 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Put it in 6th gear. Engage e-brake. Breaker bar and possibly a cheater pipe attached. Done.
  14. Jun 19, 2015 at 12:52 PM
    amain
    amain Well-Known Member
    Brian
    Anacortes, Washington USA
    07 SC TRD FJ - The Black Lemon
    Fender Cracks
    I just finished doing this with a scrap piece of aluminum. I used a 1/4" thick, 24" long and 2 1/2" wide. Drilled a 1-1/2" hole and two 3/8" holes for the bolts at one end. Took me about 15 minutes to make and worked perfect. I also ended up replacing the pulley as it was groved pretty bad from mud and crap.
    Torspd and foampile[OP] like this.
  15. Jun 19, 2015 at 12:56 PM
    foampile
    Mid-Atlantic
    I was actually thinking about something along these lines. Thanks
  16. Jun 19, 2015 at 12:59 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This method works best for the automatic owners. :thumbsup:
  17. Jun 19, 2015 at 1:04 PM
    foampile
    Mid-Atlantic
    Can you explain why it matters?
  18. Jun 19, 2015 at 1:09 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    In the manual, the gear reduction and clutch will hold the crank from spinning. While breaking loose or tightening the bolt. No specialty tool needed.
    Not possible with the auto. So a strong compact impact gun, or this tool are needed. To prevent the crank from spinning.
  19. Jun 19, 2015 at 1:13 PM
    foampile
    Mid-Atlantic
    Wow !! Now that I think about it, it makes perfect sense. Thanks !
  20. Jun 19, 2015 at 1:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    Why do you need to pull the crankshaft bolt to remove the heads?
    Or is it that you will want reassemble everything in the same weekend, and need something to hold the crank then?
