How can I improvise a crankshaft pulley holder?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Jun 19, 2015.
  1. Jun 21, 2015 at 10:37 AM
    #41
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    Lol. Check out his build.
    Torspd likes this.
  2. Jun 21, 2015 at 10:54 AM
    #42
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
  3. Jun 22, 2015 at 10:27 AM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How'd the progress go?
  4. Jun 22, 2015 at 10:32 AM
    #44
    foampile
    Mid-Atlantic
  5. Jun 22, 2015 at 10:48 AM
    #45
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Large spanner wrench/Crescent wrench to hold the cam. Long handle for 17mm socket on bolt. Sometimes it takes two people. Wear gloves.
    Torque that bolt back down to 75 ft-lbs. All of the 10mm bolts get torqued to 80in-lbs. The 12mm to 14 ft-lbs.
    foampile[OP] likes this.
  6. Jun 22, 2015 at 11:07 AM
    #46
    foampile
    Mid-Atlantic
    That's exactly what we tried. We had to resort to a 2' extension over the breaker bar with a 17 mm socket for the sprocket bolt. I (200+ lbs pretty strong dude) couldn't sustain the force with a crescent wrench when my GF was pulling the 2' lever to undo the bolt. Check the thread
