How can I make my Taco sleeker ?
Discussion in 'Street Trucks' started by Poodle Head Mikey, Jan 11, 2014.
  1. Jan 11, 2014 at 8:25 AM
    Poodle Head Mikey
    Poodle Head Mikey [OP] Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    I like my 2007 Tacoma - base w/2.7 2WD - and use it as a working truck. Nonetheless; I would like to get the highest gas mileage I can manage.
    OK so -
    I need a cap on it - but I bought an all aluminum cap.
    I need to have a roof rack - but it is all aluminum too.
    I need to have a spare tire - but got a mini-spare on an aluminum wheel.
    I need a bedslide to stuff in the bed - but I built it out of aluminum.
    I use Mobil 1 0/20 oil
    I installed larger diameter tires with a low rolling resistance rating.
    Now I know you all seem to favor scoops and increased height and fat knobby tires under sut-away fenders and external lights and all sorts of things which do look very cool to me - but which would seem to create added air resistance and so seem likely to increase drag and reduce the mpg numbers.
    My question is:
    Can you all suggest any things which would reduce wind resistance? The aluminum mini-spare is high and up out of the air stream under the truck so that helps. I have to have the external rearview mirrors. How can I make my trick 'slipperier' ? <g>
    Any ideas?
    PHM
  2. Jan 11, 2014 at 8:46 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    With cap and roof rack, slow down or move to higher altitude.
  3. Jan 11, 2014 at 9:03 AM
    Poodle Head Mikey
    But I was hoping for something more practical than inflating the tires with hydrogen. <g>
    PHM
  4. Jan 11, 2014 at 9:08 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Cut the roof off and duct tape fender to hood gaps. [​IMG]
  5. Jan 11, 2014 at 10:27 AM
    worthywads
    Have you tried running maximum sidewall tire pressure.
    I run 44-50 psi with even wear and excellent tire life.
  6. Jan 11, 2014 at 10:46 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Fill the tires with helium.
  7. Jan 11, 2014 at 9:35 PM
    worthywads
    Drop 3-4 inches.
