How Can I Raise the Rear End?
Discussion in '1st Gen. Tacomas (1995-2004)' started by old grouch, Sep 2, 2018.
  1. Sep 2, 2018 at 7:26 AM
    old grouch
    old grouch [OP] Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
    '95 Tacoma, v6 4x4, MT. Just put General Springs "stock" leafs on & the truck is lower in the back than the front by about 1/2". (in the length of a 4' level) Can I get some blocks to fit under the leafs to raise it up an inch? If so, where? TIA, Stan.
  2. Sep 2, 2018 at 9:22 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I would look into a an AAl or shakles.
    Both can be sound a wheelers or low range
  3. Sep 3, 2018 at 6:16 AM
    Brokebrute
    Brokebrute Well-Known Member
    Joe
    2004 Tacoma TRD
    Grey wire mod and 2 low mod
    If you haul much weight I would recommend an add a leaf, if not just get longer/ adjustable shackles.
  4. Sep 3, 2018 at 7:55 AM
    Tisoy281
    Tisoy281 Well-Known Member
    david
    Kerrville TX
    2002 PreRunner TRD, 2014 4Runner Limited 4x4
    I got some cheap Amazon 1 inch blocks for mine.
  5. Sep 3, 2018 at 9:03 AM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    Call Hugo at Toytec. They have a few options for rear lifts (aal, leaf packs, blocks, shackles)
  6. Sep 4, 2018 at 7:19 AM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    Don't want/need AAL. Just put new shackles on with the leafs. I hate to spend money replacing something twice, tightwad that I am. :)
    Yeah, saw some on there. Might be the route to go.
    I will check them out.
  7. Sep 4, 2018 at 8:53 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You're going to have to buy something whether it be lift blocks (which also will require new U bolts), or shackles, or an add-a-leaf. Lift blocks end up causing more issues than they solve (they tend to increase axle wrap) so I would avoid those if you can.
    Shackles will probably be the easiest to put on, and you can get the adjustable ones to dial in the right height.
    Have you parked it on level ground and noted what it looks like? Since the front and rear fenders are different shapes/sizes, sometimes a truck with a frame that's "perfectly" level doesn't quite look right.
  8. Sep 4, 2018 at 3:12 PM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    Yeah, I put a 4' level on the bed rail & it is 1/2" low, in the rear, in the length of the level. Probably will get the adjustable shackles.
  9. Sep 4, 2018 at 3:19 PM
    Wdwrkr
    Wdwrkr Well-Known Member
    Pete
    Nantucket MA
    2016 TRD Off-road DCSB
    None :-((. Yet :-))
    Do more squats
  10. Sep 4, 2018 at 3:22 PM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
