How can I tell if I have LSD
Discussion in 'Technical Chat' started by raskal311, Apr 17, 2009.
  1. Apr 17, 2009 at 7:57 PM
    raskal311
    raskal311 [OP] Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    So I had LSD installed today, long story but it worked out in my favor. Visually looking at the truck how can I tell if they actually installed the LSD?
  2. Apr 17, 2009 at 8:11 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    crack open the diff cover and take a peek. There should also be a switch in the cab to engage the locker
  3. Apr 17, 2009 at 8:35 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    The Limited Slip Differential or "LSD" is not a locker. It is a "posi" rear end or traction aid...
    It will look different than an open diff if you remove the diff cover, though...
    Also, if you gas it on loose ground both wheels will spin. If only one wheel spins, you don't have a LSD...
  4. Apr 17, 2009 at 8:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No diff cover on the Tacoma rears. :)
  5. Apr 18, 2009 at 12:39 PM
    raskal311
    S. Cal
    So no real easy way to find out?
  6. Apr 18, 2009 at 12:40 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    check under your truck, on the differential for a sticker "LSD Oil only" or something like that....
  7. Apr 18, 2009 at 12:47 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    That would only be applicable if it was a TRD clutch-type LSD that was installed (and they bothered to put the sticker on ...) ...
  8. Apr 18, 2009 at 2:35 PM
    raskal311
    S. Cal
    LSD was installed by Toyota under warrenty so it should be a TRD LSD.
  9. Apr 18, 2009 at 2:57 PM
    no_werries
    no_werries Well-Known Member
    Simcoe County, Ontario, Canada
    2005 4x4 reg cab Indigo Ink 5 speed
    CAI, 2 1/2" rear lift AAL, Ready Lift strut ext. & diff drop = 2 1/2" front lift, tweaked clutch, Magnaflo Muffler & Custom exhaust 265/75/16lt Nitto Terra Grappler 8ply on stock rims. Huskyliners
    I'd say do what one buddy said, hammer down on the gas, if both tires spin, or if you leave to burn out marks then you know it is an LSD, dont forget also that the LS Differential needs to be serviced more often then an open diff!
  10. Apr 18, 2009 at 3:01 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Jack up the ass end, spin one wheel....If the other wheel spins opposite it's open, if it spins the same way with a definite clunk/click as it engages....LSD. I think......Chris?
  11. Apr 18, 2009 at 5:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Normally, Yes. BUT, I had an instance when I did this to a friends truck (who had an open diff) and BOTH wheels spun in the same direction. Also, An LS diff shouldnt make any noise when turning the wheels.
  12. Apr 18, 2009 at 6:09 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    question?????????
    why when u spin one tire on a open diff the other spins the other way??
  13. Apr 18, 2009 at 6:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Most of the time. Depending on how thick the diff fluid is.
  14. Apr 18, 2009 at 6:14 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    ok but why dose it do it??
  15. Apr 18, 2009 at 6:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Ring gear has power delivered to it via the pinion gear. From there, the ring gear transmits the power to the other side via "Pinion" gears. It allows a change in speed from one side to the other. It only works if BOTH wheels have traction. When the truck is lifted off the ground, and the TIRE is turned, instead of the Drive shaft, and on an open diff, when one wheel is spun, the planetary gears tansmit that movement to the other side, but reversed. Also, when doing this, the drive shaft will not spin. Not sure if Im describeing it propperly.
    This may help:
    http://auto.howstuffworks.com/differential2.htm
  16. Apr 18, 2009 at 7:29 PM
    TicTacOma
    Columbia,SC
    If you can get past the first 3 minutes of this it will explain the differential....LSD will be easier understood though it isn't really explained here.
    http://www.youtube.com/watch?v=K4JhruinbWc&feature=related
    And for a real treat, watch for Chris at the end doing his "Circus Bear" imitation.
  17. Apr 18, 2009 at 7:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO!!! Good find!
  18. Apr 18, 2009 at 7:46 PM
    09TRD
    09TRD it is what it is
    Oakwood GA
    09 TRD Off Road
    Not yet,
    :DI say get on a dirt road, stomp it, sounds like the funnest way to find out:D
  19. Apr 20, 2009 at 7:06 AM
    raskal311
    S. Cal
    So I have two other questions, if the LSD keeps the two wheels from spinning at different speed, what happens on a turn? Wouldn’t on wheel spin faster then the other during a turn?
    Also does the LSD only engage during acceleration or is it also deceleration?
  20. Apr 20, 2009 at 8:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes, An LSD lets one wheel spin faster or slower than the other. An LSD works by transfering more torque to one wheel or the other. When one wheels starts to "slip" and more throttle is given to the engine, the clutch pack in the diff tightens and transmits more torque to the tire that is not slipping. When the throttle is let off, torque to the diff is cut, therefore, the clutch pack in the diff releases a little bit.
